Rich Posted April 7, 2017 Report Share Posted April 7, 2017 So, I finished a violin and the G string sounds warm and the A and E sound good. The D string lacks warmth and seems not to have enough body. It is especially evident playing 3rd finger in first position (g pitch). I am wondering if there is something I should consider trying with the setup. What puzzles me is that the g is warmer, and the A and E are nicely bright. Ideas? Quote Link to comment Share on other sites More sharing options...
Rich Posted April 7, 2017 Author Report Share Posted April 7, 2017 I am wondering if there is any adjustment that seems to help the D string such as bridge adjustment or post or anything in the setup. Especially the third finger on the D string seems tinny (but the G string is ok.) Any thots? Thanks Quote Link to comment Share on other sites More sharing options...
Addie Posted April 7, 2017 Report Share Posted April 7, 2017 Bridge would be D and A, I think. Could be post. How is the A E volume balance? How much has the violin been played? Quote Link to comment Share on other sites More sharing options...
Melvin Goldsmith Posted April 7, 2017 Report Share Posted April 7, 2017 try leaving it to settle in for a bit Quote Link to comment Share on other sites More sharing options...
Rich Posted April 7, 2017 Author Report Share Posted April 7, 2017 The A and E volume balance is good. The violin has not been played much. More specifically, how would you adjust the bridge or post? I am not sure the post would make the difference on its own especially since the G string seems warm and good. Maybe a thicker, less dense post, but it is already fairly soft spruce. I have little experience in bridge adjustment. It is cut according to generally standard s parameters. I am thinking the answer could be there. Years ago I think I remember reading suggestions how moving the bottom of the post but not the top could affect the D string but I can't find that info anymore. It is interesting because there seems to be almost a reverse wolf tone on the g note on the D string. That particular pitch is the most unappealing. The same strings on one of my other violins is almost too warm and dark, so I am not inclined to follow that line of thought unless it is a bad string. How would you adjust the bridge? Quote Link to comment Share on other sites More sharing options...
Melvin Goldsmith Posted April 7, 2017 Report Share Posted April 7, 2017 3 minutes ago, Rich said: The A and E volume balance is good. The violin has not been played much. More specifically, how would you adjust the bridge or post? I am not sure the post would make the difference on its own especially since the G string seems warm and good. Maybe a thicker, less dense post, but it is already fairly soft spruce. I have little experience in bridge adjustment. It is cut according to generally standard s parameters. I am thinking the answer could be there. Years ago I think I remember reading suggestions how moving the bottom of the post but not the top could affect the D string but I can't find that info anymore. It is interesting because there seems to be almost a reverse wolf tone on the g note on the D string. That particular pitch is the most unappealing. The same strings on one of my other violins is almost too warm and dark, so I am not inclined to follow that line of thought unless it is a bad string. How would you adjust the bridge? It is really pointless trying to do immediate set up work on a brand new violin or a recently assembled restoration....they need time to settle in and take up the tension inherent in the violin's design....They will be changing a lot after being strung up....I'd say your D string will sound fine in two weeks if you just play the violin as much as possible and do nothing else.... Quote Link to comment Share on other sites More sharing options...
Addie Posted April 7, 2017 Report Share Posted April 7, 2017 1. What Melvin said. 2. Have someone play it for you, for evaluation. 3. It could be technique. That particular G gives me trouble if my hand is lazy and the third finger is reaching sideways too much. Quote Link to comment Share on other sites More sharing options...
martin swan Posted April 7, 2017 Report Share Posted April 7, 2017 I also agree with Melvin, but what you're describing is quite a common problem with strings that have a sympathetic vibration - like playing a G on the D string or playing a D on the A string. It's worth trying to work out if the problem is the same when the open G is damped or stopped. Once the violin has had a chance to make up its mind what it is, if the problem persists then there are little tweaks that can help. Quote Link to comment Share on other sites More sharing options...
Rich Posted April 7, 2017 Author Report Share Posted April 7, 2017 Thanks for the food for thought. I am thinking "patience" for awhile. Quote Link to comment Share on other sites More sharing options...
