lpr5184
Amati Viola
This is my first fiddle since a long break from the bench...I have a few more instruments planned in the next two years before retiring.
I'd like to post a few building photos as I build this viola. For those who know me please refer to me as lpr5184 or E. That would be appreciated and please don't ask about the dots. Now that's out of the way...
I build one fiddle at a time and this first one is the Amati viola in the Estense gallery. Please don't be bashful with your critique. So here it  goes.
5 hours ago, Tommy Coleman said:
Bros Amati, right?
edit.  I see now that it is not Bros Amati.
Tommy, I think it's attributed to only Girolamo.
3 hours ago, lpr5184 said:
 Made in 1625, so Hieronymus I.
Or the younger Niccolò........
Stylistically it's different than the 1615 Brothers on display in Cremona (Stauffer) which in 1615 was likely all Hieronymus I.
14 hours ago, lpr5184 said:
Conor, yes a ring on both sides of the block.
Referring to you as lpr is not going to work for me because that's what we call the "Lab Prep Room" at work.  I'll have to stick with E. :)
Can you show us a picture of the rings prior to installation.  Are they to prevent cracks, control wood movement, deformation, or what?
Thanks,
Jim
Bruce,  Indeed this viola is very different from the Stauffer. The book discusses briefly the issue of it's provenance and states that it remains unsolved. Thanks!
Thanks,
Jim
Jim,  You can go to Joe Regh's site and see a picture of the rings. I learned this from him when I bought his tool.
E
http://www.reghviolins.com/tools_pegringer.aspx
After 2 and a half years away from building I knew I was bound to make some mistakes. And already it happened.
I managed to glue in the upper ribs with the flames going in the opposite direction as the C' bouts. So I had to unglue the ribs and flip them over. I also shortened all the corners a little bit too.
I think opposite flames look great on a del Gesu, but not so much on an Amati. Oh well, over and done.
My choice of viola wood on hand is very limited.
For the back I have .55 or .60  quartersawn Slovakian Maple.
For the top I have .33 or .43 Swiss Spruce.
What would be the best choice? Would it be best to go .33 top and .55 back? ...and stay light? ...or go heavier?
I think Manfio likes low density spruce and I think he likes red maple...so I'm thinking low density for maple too?
Top arch is almost 18mm   Back 15mm and change...
14 hours ago, JacksonMaberry said:
.43 sounds very dense to me, I'd go with your lighter stuff. Beautiful garland!
Jackson,  I think .43 would be a little too stiff too, considering the high arch. Thanks
I also have a large cello billet of Sitka I purchased from Bruce Harvey. I'll see if I can measure the density today. It is large enough to get a viola and a cello top out of it. It would be nice if the density was low enough. I could get some nice one piece tops if I cut it down. I will not be building any cello's.
E
From the link above, I would be more than a little dubious using brass rings; or any metal for that matter.
I could see using  the carbon fiber for repair work, maybe it comes from a different source.
addendum:
Yes, I see now from my notes:  method developed by Jerry Pasewicz for inside pegbox repair , ref published article in the Strad(?)
https://trianglestrings.com/reinforcing-cracked-pegbox-wall/
I agree
On 3/26/2017 at 0:11 PM, lpr5184 said:
I agree
Nice enough looking corner however,  If I had the choice I would run the grain orientation into the  corner when  splitting out and fit blocks,
especially if I was using spruce. ;)   Good luck and have fun with your current viola build !
ex. illustration I plucked off the web:
I know that's what everyone does, Wee b., I mean, we all know everyone does it that way, but does it really matter (other than being prettier)? Is there a structural strength or a more pragmatic reason?
Curious why you chose to make those Amati corners shorter E. How much shorter?
On ‎3‎/‎26‎/‎2017 at 0:15 PM, Wee B. Bridges said:
Nice enough looking corner however,  If I had the choice I would run the grain orientation into the  corner when I splitting out and fit blocks,
Interesting point Thanks
EDIT- Looking at the closeup,I think I see what you mean now...I will do that on the next one, Thanks again!
I always assumed it had to do with future repairs, not to mention that it ensures the grain relationship between block and rib is the same for both bouts.
