Greg F. Report post Posted April 14, 2017 In conclusion, this bow was authenticated as a genuine Lamy pere bow. The certificate did not note that any of the parts (adjuster, etc.) were replacements. It has been sold and the proceeds went to a good cause (a handmade violin). Quote Share this post Link to post Share on other sites
GeorgeH Report post Posted April 14, 2017 On March 3, 2017 at 6:17 PM, Greg F. said: buy a handmade American violin. Who was the maker? Quote Share this post Link to post Share on other sites
martin swan Report post Posted April 14, 2017 That's great news, even if I have egg on my face. I did find images of a Tourte copy with a rather large pearl eye, but yours has a regular Lamy head. I also never saw one before with an adjuster with a single collar. You went east, so I suppose that means Isaac Salchow or Paul Childs ... Quote Share this post Link to post Share on other sites
fiddlecollector Report post Posted April 14, 2017 59 minutes ago, martin swan said: That's great news, even if I have egg on my face. I did find images of a Tourte copy with a rather large pearl eye, but yours has a regular Lamy head. I also never saw one before with an adjuster with a single collar. You went east, so I suppose that means Isaac Salchow or Paul Childs ... I thought it looked right but didnt comment as" i didnt want egg on my face!" Quote Share this post Link to post Share on other sites
martin swan Report post Posted April 14, 2017 ah well, nothing ventured nothing gained - I did think it was a good French bow and I didn't doubt the brand on the stick but you have to concede that adjuster is far from typical! Quote Share this post Link to post Share on other sites
fiddlecollector Report post Posted April 14, 2017 Found this photo of a lamy pere cello frog /button. It appears to have a single collar but cant be certain. I think its probably just a matter of the maker messing up the second collar and deciding to remove it all together. Or it may be intentional. I notice on the one you have for sale it has the second collar almost filed off, giving an effect like Peccatte (and one or two others)collars. Quote Share this post Link to post Share on other sites
martin swan Report post Posted April 14, 2017 Makes sense ... I agree the 2nd cut is sometimes very fine, so I suppose if it mashes you would just remove it. In fact I have two Lamy cello bows, and I see one has no second cut to speak of ... perhaps I should spend more time looking and less time reading!! Quote Share this post Link to post Share on other sites
Evan Smith Report post Posted April 14, 2017 2 hours ago, martin swan said: Makes sense ... I agree the 2nd cut is sometimes very fine, so I suppose if it mashes you would just remove it. In fact I have two Lamy cello bows, and I see one has no second cut to speak of ... perhaps I should spend more time looking and less time reading!! What does second cut mean? Quote Share this post Link to post Share on other sites
fiddlecollector Report post Posted April 14, 2017 We`re refering to the collar rings on the button. The second cut (smaller collar ring )is rather misleading as its usually cut first . When the octagonal facets are filed on the button the inner collar is often messed up ,although Peccatte nearly always did it. When the button is filed to a slight taper the inner ring is removed where the flats are leaving just the remains of the ring on the corners of the facets. Hope this explains ! Many early French makers only made one collar ring. Quote Share this post Link to post Share on other sites
Evan Smith Report post Posted April 14, 2017 17 minutes ago, fiddlecollector said: We`re refering to the collar rings on the button. The second cut (smaller collar ring )is rather misleading as its usually cut first . When the octagonal facets are filed on the button the inner collar is often messed up ,although Peccatte nearly always did it. When the button is filed to a slight taper the inner ring is removed where the flats are leaving just the remains of the ring on the corners of the facets. Hope this explains ! Many early French makers only made one collar ring. That's amazing, I know you guys are looking at something,,, but I have not a clue what. I get it after reading it a dozen times, it's not you, it's me,,I can be a bit thick. Now it makes perfect sense,,,,kind of like a fingerprint and it's only one detail! I don't do bows, I see it could be highly engaging,,,maybe in another life time! The cart is full! Thanks! Quote Share this post Link to post Share on other sites
fiddlecollector Report post Posted April 14, 2017 I should also mention that if the second collar ring is cut too shallow ,it can disappear completely when the octagonal facets are formed. Some well known makers actually soldered a seperate piece on to form the collars from . Also if the collars are cut too deep they can cut right through the silver depending on how thick the silver plate was they used. Some makers used very thin silver bend around to form the octagonal facets instead of making two round rings and filing them from round. There are many different ways of doing it. Quote Share this post Link to post Share on other sites
Evan Smith Report post Posted April 14, 2017 18 minutes ago, fiddlecollector said: There are many different ways of doing it. and thus many different ways of identifying it! Quote Share this post Link to post Share on other sites
Greg F. Report post Posted April 14, 2017 15 hours ago, GeorgeH said: Who was the maker? Don Noon. I'm very pleased with it, although I cut the end of a finger the other day chopping vegetables so I haven't played it as much as I'd like. Quote Share this post Link to post Share on other sites
GeorgeH Report post Posted April 14, 2017 28 minutes ago, Greg F. said: Don Noon. I'm very pleased with it, although I cut the end of a finger the other day chopping vegetables so I haven't played it as much as I'd like. Great! Thanks for letting us know. I always like to hear about folks buying great American violins. I hope you heal quickly. Quote Share this post Link to post Share on other sites
Evan Smith Report post Posted April 14, 2017 48 minutes ago, Greg F. said: Don Noon. I'm very pleased with it, although I cut the end of a finger the other day chopping vegetables so I haven't played it as much as I'd like. Photos? .....................of the fiddle not the finger! Quote Share this post Link to post Share on other sites
Greg F. Report post Posted April 14, 2017 3 hours ago, Evan Smith said: Photos? .....................of the fiddle not the finger! Here's a pic. There are others on Don's Bench thread. Quote Share this post Link to post Share on other sites
