Edward Byler
Edward Byler's Bench
It's evident I'd rather build then varnish though now it's time I spend a few months doing mostly that . It's not that I don't enjoy varnishing it's just that so much can go wrong and I really want to do more than straight varnish ( sorry all of you opposed to antiquing :) ). I've just dinged up stuff on straight varnished stuff that would have only brought character to a mildly antiqued instrument and also touch-up after putting on the fingerboard is hard to get right . I'm considering doing the ground coat and then putting on the fingerboard before finishing the varnish. I also threw in some photos of my shop and a couple earlier varnished ones .
On my way to removing all the varnish from the viola and violin I messed around with some shading/removing in practice for when I reapply the varnish and attempt to antique them. I put a bit of lamp oil in my varnish to extend drying and then noticed that it is not kerosene but paraffin :( so I'll start over .post-76408-0-24824300-1464371148_thumb.jpegpost-76408-0-95331900-1464371200_thumb.jpegpost-76408-0-26688400-1464371233_thumb.jpegpost-76408-0-90764200-1464371258_thumb.jpegpost-76408-0-15755400-1464371287_thumb.jpegpost-76408-0-06289600-1464371330_thumb.jpeg
Some photos of an earlier violin I built that I revarnished . I'm messing around with antiquing a couple others but since the wood was not antiqued much before I varnished this one I decided to just do some shading . What are your thoughts on lightened edgework and mild added dirt ? Does it look like a cheap production quality job ? This is some of my cooked varnish with a bit of zinc rosinate that I made .
It does not look like a cheap production quality job.
What's up with what appears to be a high overstand?  Hope I'm wrong about that.  What is the height of the outer pegbox between the d and e pegs?  Looks kinda tall.
  The edgework and belly finish, in addition to the fittings and strings, appear to make the violin ready for business.  It looks real good.
Thank you uncle duke for your input! My phone distorts the photo but I think my Plowden scroll does exaggerate the pegbox shape . The over stand is 7 mm which is a little over the 6.5 mm I'd prefer. The scroll dimension between d and e is 22 mm. Here's a photo less distorted .
Finally getting close on this 15-1/2 viola. I built it over a year ago and finally have it varnished and strung up . I need to learn how to color the boxwood pegs and touch up here and there yet . I got a tracing of the mold from a student of Zorans workshop in Tucson a couple years ago but I didn't have anything to go by for the scroll or F-holes and I'll not try winging it like this again. I welcome your criticism or advice
Ive finally finished this top that I’ve been carving the last several days but I think I’m going to reject it and build another .I’ve never made a single piece top before and maybe that’s not the problem but it is too heavy to have such a low and weak mode 5 . It is averaging 2.9 mm thick . Maybe the wild F-holes that I loved doing limbered the plate up too much . 71 grams with bass bar . Mode 5 is 355. I mistakenly put the wide grain on the treble side .
I like every one of the fiddles you have posted so far Edward!  I do hope we can meet in Weiser this year and chat. Your fiddles look fantastic to me!!
And I do hope you bring a few fiddles with you!!....: )
I'll have the Sultana for you to try...
15 hours ago, Edward Byler said:
It is averaging 2.9 mm thick . Maybe the wild F-holes that I loved doing limbered the plate up too much . 71 grams with bass bar . Mode 5 is 155.
That cant possibly be mode 5.  It's far more likely mode 2.  (another example of tap tones leading astray?)
Thanks Don, I rechecked because I agree it is abnormal . I also agree that religiously following mode numbers is misleading and that’s why the graduations and weight play in equally important . If the weight was 61 g and thickness 2.7mm I’d like it but I’ve not found it to work well to have these three not correlate better . I like using the tone generator with tea leaves because it is clearer which mode it is than looking at a computer screen showing peaks . The photo of frequency is a screen capture on my iPhone where I have the tuning app. This plate is clearly ringing lower when tapped compared to other free plates that have mode 5 at 372 .
It looks like we have the same phone app.  If you click back to chromatic tuning (instead of tone generator), then click the gear icon in the bottom right corner you can change the tuning mode to FFT mode.  When holding the plate at the M5 node and tapping you can see the M5 spike clearly especially with multiple taps.  A long piece of sound post stock makes for a loud tap that the phone will easily pick up.  Just to double check your tone generator.
Does the plate feel weak in the hand?  Seems a shame to trash a completed plate without testing it first.
-Jim
I just now saw your post Jim . Yes I’ve used the other app features too and love it. The tea leaves clarify better which mode is ringing by its shape . The plate doesn’t really feel weak but with its weight and lack of response when tapping it’s not what I’m used to
I have a back and belly almost done that are both 350, the back maybe 347.  The belly is 70 g and the back is 100 g. They seem just fine. The low tone, (mode 2?) is 175  for both.   I just use an online tone generator, and move it until it matches.  I've never done the tea leaf thing, and gave up on fit stuff.
 I like your shop, and your instruments.   The f holes look just fine.   Maybe if the angle of the wings wasn't so steep, they wouldn't look quite so aggressive.  It's probably a subtle change that would make a huge difference.  Make sure that the top and bottom curves are round, and that the point of the wing doesn't coincide with the low point of the radius.  It is more important for straws, and everyone else.  Del Gesu didn't seem to care!
1717900930_DSC_7156r.thumb.jpg.30a47a304cf8bcc5f8abb4d8e8644fb8copy.jpg.08cb29e7e9892c42d6a7671e989f62cf.jpg
Even in the Vieuxtemps, del Gesu COULD have made the radiuii round, and followed the rules, but he didn't want to.  He wanted that look, that aggressiveness.  Totally different styles, so you have to embrace that.
I look at my instruments, and then others, and where I think my varnish has some texture that makes it nice; most are bowling ball smooth.  I don't get it.
I haven't seen too many instruments that are bowling ball smooth, except for an exceptional Peter of Mantua that was like that, and I'm sure that it has had over a hundred years of French Polishing on it.  But every violin that you see has a guitar finish on it.
Weird.
But people will look at a varnish with a lot of texture and think that you are OUT OF YOUR MIND. That you don't know what you are doing.  I know they will.  I've seen the look.
Yours you can get away with more, because you do some antiquing.  In that case, you can put dings, and all sorts of things on them, and it doesn't look out of sorts.  Straight varnish is harder in a different way.
Notice the texture on the Lipinsky Strad.  It has years of polishing, and the only thing that is immune to it is the little holes.  The Vieuxtemps is  like that too, only more so.  Some violins have wrinkling, or cracking; but just plain rough, I haven't seen except on mine!
I smoothed the varnish up on all of mine.  It made a world of difference.  They still don't look like bowling balls.  I'm sure that some still think that I don't know what I'm doing.   Maybe I don't.  I don't follow the rules.  I make up rules for my arching,  but everything is finished to how it looks and feels.
It looks like you are having as much fun as I am.
keep at it,
Ken
Thanks Ken, your mode numbers are probably fine . I decided to use the plate that was a little heavy after conferring with a few others . Don was right that my numbers looked like a mode 2 because I said it was 155 when I meant to write 355. I’m not overly picky about mode 2 unless it is way off . We’ll see if this works out . The first and 3rd place tone winners at the SVA 2017 were what I’d call way low on mode 5 and heavy . That convinced me to leave it .
  I see what you mean on the the f-hole about making the point of the wing placed at the furthest curve of the radius . The more I got carried away with cutting them the more I wasn’t sure where I was going with it . I was looking at distorted drawings that look cool in there own sort of way.
    As far as texture I totally know what you mean . I hear that a bowling ball look is not good but when seeing many of them in person many are . I overdid the texture on some of my earlier stuff not knowing what they should look like . I use a stipple brush to apply my varnish but depending on the consistency of my varnish it can get very textured especially because I don’t smooth it between coats . This violin shown has too much texture I think .
( I wrote out this reply days ago but my cell service is so poor it wouldn’t go thru with the photos-even now only one would send. Reading maestronet is one thing but replying with photos is another )
