Addie Posted March 4, 2016 Report Share Posted March 4, 2016 I usually use Aubert violin bridges, but am trying out a Despiau. I noticed the Despiau is wider at the top than the Aubert of the same size. The string spacing I usually use (template) leaves a lot of "shoulder" hanging out past the strings on the Despiau. This looks odd to me. Do people use a wider string spacing? Live with it? Or... ? I seem to recall something in a previous topic, but where? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
duane88 Posted March 4, 2016 Report Share Posted March 4, 2016 Same string spacing regardless of the bridge. I use the Despiau for 5 string bridges because there is more width up top. I use 11.5 mm between strings, center to center for some, edge to edge for those who ask for it. What you do with the space outside of the G and E-flattening out or continue the radius-contributes to the look of oddness or not. Quote Link to comment Share on other sites More sharing options...
MaestronetLurker Posted March 4, 2016 Report Share Posted March 4, 2016 I don't change string spacing between aubert and despiau, but I usually use despiau. If you do change the spacing you should also change the profile. Since I work on many sizes of instruments I had to come up with templates to work with various string spacings, and have a pretty simple method to determine the appropriate arc. Hard to explain, but if you're interested I'll take a photo that should make it clear. Quote Link to comment Share on other sites More sharing options...
Addie Posted March 4, 2016 Author Report Share Posted March 4, 2016 Thanks, both of you. I see there are three things going on: 1. Despiau are wider at the top. 2. Most bridge templates flatten out past the strings (I posted a graphic a few years ago). 3. I'm making a new bridge because I replaced a thin, worn out fingerboard. This means a higher bridge, and that means a bridge wider at the top, regardless of the bridge-blank brand. Quote Link to comment Share on other sites More sharing options...
captainhook Posted March 4, 2016 Report Share Posted March 4, 2016 If you don't like it that wide it isn't extremely difficult to make it narrower. Quote Link to comment Share on other sites More sharing options...
