What about instruments with the conical hole in the center of the back, does anyone know if the plate balances there? I've been wanting to experiment with graduating a plate to balance on a spike that would fit such a hole, but can't bring myself to drill an unsightly hole in the center of the back.
There are definitely nice instruments that have a pretty deep pinprick in the back center. (I know that's not what you're talking about.)
 I've known makers who've subscribed to the idea that the plate should balance around that point, and could actually balance the plate on the point of their scratch awl and spin it around!
 I'm interested if anyone has a good technique to being able to get the ribs convex from top to bottom. I've seen this effect on some nice Cremonese instruments, and have heard others talk about this phenomenon as being desireable.
Interestingly enough, using the wedge clamp method on the c-bouts can get this effect, but I often find that the ribs for the upper and lower bouts always end up a little bit concave with my current construction methods.
No problem. Glue the ribs to the blocks when the ribs are slightly moist, or scrape them to the profile you want after installation. Not that I'm in any way recommending either. When we see convex ribs on the upper and lower bouts of historical instruments, I think that's mostly due to contraction of the plates on each side of the rib, over time.
5/6 hrs minimum ,it will still be tender though, I tried speeding up the process once with some added heat ....not good
[/quote
James,
What kind of glue are you using that requires that much clamp time? I routinely take clamps off after two hours except for center joints and neck sets when I might give it an extra hour .On large patches I leave them for days but that is a special situation.
[/quote
James,
probably the same sort of stuff you use, I don't know that I do need that much time , just playing it safe before applying stress. I am comfortable pulling the clamps sooner , it's the working with it and stressing things that makes me nervous, I've had a few blow outs from pushing the limits.
Nathan, thanks for the correction.
I disagree with John above, and i bet he hasn't even tried the dowel and string method.
No,  I started making decades before the re-discovery of the old dowel and string method.  If YOU disagree with the end-clamping of the perimeter... have YOU ever tried it?  You may have to wiggle things to get them to seat.    It may not work well with thin moulds.  I always use full-thickness moulds.  I could never understand why it was not common practice.
Probably too many people trying to copy old methods too slavishly.
"...   That C bout clamping block method is the prescribed one at Newark,
and as I said to P.Bowers 22 years ago, it doesn't work. Sure, some people insist on
doing exactly what they were told, but it really doesn't work effectively.
The clamping forces are not directed to the glue line, but into the middle of the c bout,
and if you are doing corner shapes like Da Salo it will work even less well.
If you've made it work, then fine. I'd suggest using the dowels and string method. ...."
It works just fine  if you add ridges (very small steps) to the slant sides of the trapezoid.  This is easily done with a bandsaw.  Then the trapezoidal block can 'lock' on the rib and only one central clamp is needed.  Also you can adjust for more pressure by sanding the rib if it is not square.
You can also shape the trapezoid so that the ends are perpendicular to the rib.
I may have misread or misunderstood you,  David.  I thought at first that you meant rib height.  As for the rib depth having a convex curve,  I thought that clamping while wet,  and using a thin mould was supposed to do this as the wood shrank.
But ..  as said above,  I use a full-thickness mould,  one piece only and does not disassemble.  It works fine.  Also,  I glue it up with sheets of plywood.  I did a couple of violas once as you say.  Just make the first sheets total half an inch thinner than the end rib heights.   Then take quarter-inch plywood and bend over whatever central spacers you wish.  Gorrilla glue works well to glue the ends as it has gap-filling properties.  Then shim the ends and cut it out.
I showed my two violas to Carl Becker Jr when I did it.  He looked with interest but made no comments.  It certainly does not create a tone issue.  The bend helps the longitudinal arch in part,  the centes of the ribs were quite high without making the chinrest end unmanageable.
I agree with Mr. Truscott.  They looked handsome in profile.
I too used the end caul trapeziod method and it worked great. The ribs made full contact, even though they weren't bent to exact shape beforehand. I don't really see why this is such a hot topic. Very simple concept, very simple execution. If someone thinks that one method is superior, despite the same results, they may have problems outside of luthery that they should address.
I'm having trouble visualizing this..
Thanks David! Since I had already glued the ribs, I went for the latter to good results.
I mean that the surface of the mould is flush with the rib edges.  And you can make the mould have the profile of a double-convex lens.  You can do the same for just the top-upper-bout for a violin.   When the ribs are finished and before the blocks are cut away,  one can lay a medium coarse file on the surface of the mould and smooth the excess ribs flush with the mould surface.  It is very fast and percise.  (Why go to all the trouble to try to plane a particular taper?  The bent upper quarter inch plywood piece bends pretty close to a parabola,   Those eager to contradict can look up "the cantileaver beam" and see that it is a cubic equation,  I believe.)
  • 2 weeks later...
I know its not customary, but I like to remove the mould before I start the outline . I don't mind if the ribs lose their exact shape. I  mark the corners, length, and c-bouts, so that I can get a very close approximation of where everything should be.
This way, I can release any tension, if any, and it's much easier to get the ribs to register properly with my finished plates.
