Levin Posted January 17, 2016 Report Share Posted January 17, 2016 Hi,Can you recommend me a good ground for the the violin before applying an oil varnish? Until now I used the water of glue or albumin but I want a background that perfectly isolates the wood.Thank you Quote Link to comment Share on other sites More sharing options...
~ Ben Conover Posted January 17, 2016 Report Share Posted January 17, 2016 If you want just one layer under the varnish (as you suggest) then rosin oil works well enough.Kremer sell it. Get the book called Violin Varnish, it lets you consider things as you read it. I think of it this way :1. Primer 2. Sealer 3. Ground4. Varnish Quote Link to comment Share on other sites More sharing options...
christian bayon Posted January 17, 2016 Report Share Posted January 17, 2016 Glue is not very popular in ground on Maestronet! Quote Link to comment Share on other sites More sharing options...
christian bayon Posted January 17, 2016 Report Share Posted January 17, 2016 . Quote Link to comment Share on other sites More sharing options...
~ Ben Conover Posted January 17, 2016 Report Share Posted January 17, 2016 Kuttner says you can use a thin solution of hide glue as a sealer. A primer / ground of rosin oil over that would work. I think Levin is talking about an all in one primer sealer ground, which is doable. Others use a clear shellac. Depends what his varnish is and how it will adhere. Whether he intends to flatten the ground or leave it au natural then tripoli the finish. Quote Link to comment Share on other sites More sharing options...
Levin Posted January 17, 2016 Author Report Share Posted January 17, 2016 Hi, What is a good sealer? I hadn't in mind the distinction between sealer and ground.I have tested my oil varnish and I like the result, however, with backlightI see the open pores of the wood and I would therefore products that fills the pores before varnishing. Levin Quote Link to comment Share on other sites More sharing options...
not telling Posted January 17, 2016 Report Share Posted January 17, 2016 http://www.cremonatools.com/old-wood This has been a helpful document in that it put gum tragacanth on my radar (had never heard of it before reading this). I prepare a light sealer that uses this and other ingredients. There are lots of good options, obviously. Quote Link to comment Share on other sites More sharing options...
not telling Posted January 17, 2016 Report Share Posted January 17, 2016 2x post Quote Link to comment Share on other sites More sharing options...
wellerwilliams Posted January 17, 2016 Report Share Posted January 17, 2016 Has anyone used a myrrh solution as a sealer? The reason i ask is I saw it in the Hammerl book, but have never used it myself except in tests. ww Quote Link to comment Share on other sites More sharing options...
jezzupe Posted January 17, 2016 Report Share Posted January 17, 2016 Quote Link to comment Share on other sites More sharing options...
DGV Posted January 17, 2016 Report Share Posted January 17, 2016 I have been using a sugar ground ever since I learned it from Jezzupe. Looks great and easy and cheap to make. Quote Link to comment Share on other sites More sharing options...
David Beard Posted January 17, 2016 Report Share Posted January 17, 2016 I know it's mostly a personal bias, but since we revere the old instruments, I also like to understand all the processes in an historical context. That said, concepts like 'sealer' and 'primer' are modern. So is the idea of a premixed product that covers several functions in one step. If you survey the literature on old Italian arts and related processes, you'll see that in the 17th century and earlier Italian practice, everything was in terms of the artisan preparing materials from basic natural ingredients. The few exceptions prove the rule. Oil varnish apparently at times was bought prepared. And certain colors and materials were sometimes but not always prepared to a very basic level for the artisan; white lead, vermilion, gall ink, etc. But recipes and process were known, and common across multiple arts. The artisan's training generally began with mixing materials. etc. , So.... If you take a broad look across the existing historical evidence, you'll see that gilding, painting, varnishing, dying, leather preparation, and wood finishing share many basic materials, recipes, and processes. And that almost all surface decoration and preparation processes repeat with variation through all the old Italian arts. Given this stuff, I'm always trying to understand the violin work and varnish/finishing in this context. Starting from in the wood(or other substrata) and building out to the final surface, here are things you do read about in the old arts: Treatments penetrating into the strata: Staining -- largely water based, but not entirely Mordants and preservatives -- Alum, garlic, many different washes Transparency or stabilization or waterproofing -- oil penetration and similar lye or acid applications Tannings and softeners (mostly from leather work) Burning or scorching work Right at the surface or slightly in: Scraping with steel and rubbing with rushes Cleanings and lighteners -- lemon, salt, etc. (many) Fills Sizing (usually glue, but casein or other binders are possible) Just into and immediately above the strata: Grounds (not exactly our common violin making meaning. though ideas can overlap) literally minerals ground up and in a binder -- generally white, but sometimes with tint added sometimes made transparent by penetration by oil, varnish, or similar always meant to visually and physically underpin the decorative finish False golds, and false tins, etc. various schemes for a reflective, transparent, colored glaze. Stabilizing sub groundsGross grounds -- sand and gravel or charcoal etc. boles to prepare gilding work Decorative coloring work: Painting (with the artisan generally preparing their own materials in shop)binders can be almost any -- protein, oil, varnish, etc the older idea is the physical pigment-- tempered with just enough binder. As opposed to a more modern approach of mostly binder and fill, tinted with enough colorant. Gilding Glazes Varnish Primarily to protect the decorative work, and modify the surface and appearanceperhaps tinted, but not generally meant to be the primary source of color or decoration.Polish Abrasive rubs like chalk, rouge, charcoal, tripoli, pumice, cuttlebone (from jewellery work), many others Oils (non-drying) or waxes Thin varnish like polishes and French polish, etc I think it's very possible to understand historical violin finishes simply as variations on these broader art practices. Not saying there's anything wrong with modern ways, or that anyone needs to follow this agenda. But for me, I'm happier working in this context. Quote Link to comment Share on other sites More sharing options...
not telling Posted January 18, 2016 Report Share Posted January 18, 2016 Wow, thanks. That's a lot. Reminds me, in the Plictho there is a recipe for creating a seeming gold on wood panels. It's made primarily of animal dung. Really logically consistent with what some have been saying here. One could probably create a refractive ground or layer with that recipe or at least would do well to be informed by it. Also, OT, I am curious if those who are painting golds on instruments are gold leafing it, or using some historical recipe like that. There is also a lot of information about 15th c. tanning methods in the Plictho that I would think would be potentially useful too. Quote Link to comment Share on other sites More sharing options...
~ Ben Conover Posted January 18, 2016 Report Share Posted January 18, 2016 Yes, a tincture of myrrh works well as a humidity sealer for inside violin, could also use it as a sealerfor under the ground. It's slightly brown in colour so don't use it on bare wood, size with gelatin first. Benzoin adds lustre to the mix, but it's soft.Both smell nice. Quote Link to comment Share on other sites More sharing options...
wellerwilliams Posted January 18, 2016 Report Share Posted January 18, 2016 Yes, a tincture of myrrh works well as a humidity sealer for inside violin, could also use it as a sealer for under the ground. It's slightly brown in colour so don't use it on bare wood, size with gelatin first. Benzoin adds lustre to the mix, but it's soft. Both smell nice. Thanks. There are so many options for pre-stains and sealers that I sometimes get overwhelmed by the variety, and end up sticking with solutions I've used in past, such as tea then dilute unwaxed shellac. I like the color of the myrrh in tests however. ww Quote Link to comment Share on other sites More sharing options...
David Burgess Posted January 18, 2016 Report Share Posted January 18, 2016 Yes, a tincture of myrrh works well as a humidity sealer for inside violin,... How did you come to that conclusion? Just curious, because there are lots of pretty good studies on water vapor inhibitors. Quote Link to comment Share on other sites More sharing options...
Advocatus Diaboli Posted January 18, 2016 Report Share Posted January 18, 2016 Not Telling, here are some microscope shots of the decorations on the 'King' A. Amati cello. It looked an awful lot like gold leaf to me. Quote Link to comment Share on other sites More sharing options...
~ Ben Conover Posted January 18, 2016 Report Share Posted January 18, 2016 Weller,Myrrh and Benzoin were both found in the remaining workshop contents of Padding, if a 'historical' context is needed. In the Violin Varnish book Padding shows how a 'Byzantine' system of layers is one way to look at it, but he also notes that his particular angle is just one way to do it. Quite good to remember that. Quote Link to comment Share on other sites More sharing options...
~ Ben Conover Posted January 18, 2016 Report Share Posted January 18, 2016 David,I read about Mrryh being used to seal the inside of a violin, in the violin varnish bookby a German author, can't remember the name.Mrryh does contain some rubber, so you don't use that bit.I just put some in a jar with alcohol and leave it for a few weeks. You can also use it in a solution of potash, apparently. Quote Link to comment Share on other sites More sharing options...
David Burgess Posted January 18, 2016 Report Share Posted January 18, 2016 Weller, Myrrh and Benzoin were both found in the remaining workshop contents of Padding, if a 'historical' context is needed. Someone going though my stores after my death might find everything from jars of snake snot, to hypo hymen. Doesn't mean that I ever managed to incorporate them into a successful instrument filler or coating. David, I read about Mrryh being used to seal the inside of a violin, in the violin varnish book by a German author, can't remember the name. Here's one decent vapor barrier study, and there have been many others. http://jpschmidtviolins.com/MVA_filler.pdf Quote Link to comment Share on other sites More sharing options...
Michael_Molnar Posted January 18, 2016 Report Share Posted January 18, 2016 Myrrh and gold leaf? All we need is frankincense to produce the Messiah. LOL Quote Link to comment Share on other sites More sharing options...
Davide Sora Posted January 18, 2016 Report Share Posted January 18, 2016 Myrrh and gold leaf? All we need is frankincense to produce the Messiah. LOL You forgot a comet star...... Quote Link to comment Share on other sites More sharing options...
David Burgess Posted January 19, 2016 Report Share Posted January 19, 2016 You forgot a comet star...... Unlikely that Mike Molnar forgot, since he has published a book entitled "Star of Bethlehem...". Quote Link to comment Share on other sites More sharing options...
Christopher Jacoby Posted January 19, 2016 Report Share Posted January 19, 2016 Not Telling, here are some microscope shots of the decorations on the 'King' A. Amati cello. It looked an awful lot like gold leaf to me. IMG_3013.JPGIMG_3017.JPGIMG_3021.JPGIMG_3028.JPGIMG_3029.JPGIMG_3032.JPGIMG_3039.JPGIMG_3050.JPG Definitely gold leaf. The respective significance of the gold and silver leaf in the decoration's been explored by Andrew Dipper in some fascinating ways. Also...... that's you, isn't it, Jordan?? Quote Link to comment Share on other sites More sharing options...
nathan slobodkin Posted January 19, 2016 Report Share Posted January 19, 2016 The violin varnish book and other writing by K. Padding sum up the steps pretty well but I think of the process as a sealer or sizing first just to prevent uneven or deep soaking in of subsequent substances, then a coloring substance such as a stain or chemically reactive ingredient and then a hard but quite thin layer of sealing varnish which forms the real ground layer on which the colored varnish is applied. I think the initial sizing can be water soluble as long as it doesn't remain as a layer on the surface but wonder whether those might tend to attract dirt when the varnish wears through. Quote Link to comment Share on other sites More sharing options...
