chinese finishes
jim mcavoy
Hmm...interesting.  The two Chinese instruments that I have available for a kids/youth program have a rock hard finish.  It's almost like they were dipped in glass.  I kind of wish they were softer.  I suppose Chinese instruments spans the entire gamut in many ways.
From my point of view you are the lucky one
Chinese instruments spans the entire gamut in many ways seems to be the case
I find your question a little hard to understand. How big are the scratches? do you wish to know how to do touch up? If that is the case, I can't help you. But if you are only talking about dulled down varnish because of small scratches, and you'd like to restore the former shinyness, then you should use Super Nikco. That will polish up almost anything. (I even repaired a photo camera lens with it!), however, it is an abrasive of a kind and it would not be good to use this on valueable instruments, but on cheap rentals I wouldn't hesitate.
I bought a new Guarneri copy from a small factory in  China as a sample. The varnish looked ok and was rubbed out to remove the gloss. When I spoke to the rep, he indicated it was a laquer of sorts, and his wife learned the technique from a Canadian luthier. She was the head luthier in the organization.
It could be. He indicated she spent a few years working with a luthier in Canada before they started up their manufacturing business. If this is true or not, I can't say.
I don't know of anybody here that would use laquer; perhaps he meant the method of antiquing and coloring moreso than the actual varnish composition.
I looked at all the replies
one of the lacquers looked like the best bet
so... having painted a few cars in my day, I decided to treat it like lacquer
and used a little rubbing compound...Turtle polishing & scratch remover
worked like a charm !!!&! ...looks better than new ...there was a slight wave in the finish and that's gone
then I went all crazy and tried it on a beat up violin that had been over coated with Tung oil varnish (HI Gloss) and it worked on that also ...whoopie
Thanks all, for your replies, I'm back to good.
Jim
