larsdave Posted October 4, 2015 Report Share Posted October 4, 2015 Hi, does anyone have some advice on some methods for re-setting a neck that has a sunken fingerboard and needs to be removed and re-set? I've done shims, and added a piece to the button; and I've seen a chiseled block to angle the neck back. Thanks for your time. Quote Link to comment Share on other sites More sharing options...
