Mat Roop Posted November 11, 2014 Report Share Posted November 11, 2014 Not an exactly scientific topic, but... How do you clean rosin from strings?... and what do you advise your customers? ... just curious.... Cheers, Mat Quote Link to post Share on other sites
Bill Yacey Posted November 11, 2014 Report Share Posted November 11, 2014 I use white lightning; It's truly a good thing to have in the shop for multi-purpose use. Quote Link to post Share on other sites
Muswell Posted November 11, 2014 Report Share Posted November 11, 2014 I use nail varnish remover, but I don't have any customers ....does that matter? Quote Link to post Share on other sites
martin swan Posted November 11, 2014 Report Share Posted November 11, 2014 There's a Pirastro string cleaner but it smells very much like acetone, so I use acetone/nail polish remover. Very important not to spill i on the body of the instrument - it behaves like that gloup in "Alien". Quote Link to post Share on other sites
FiddleDoug Posted November 11, 2014 Report Share Posted November 11, 2014 I use a cork. Something like a vine bottle cork cut in half lengthwise works great. Just rub it over the length of rosined area of the strings. I always worry about solvent taking rosin into the core of the strings. Quote Link to post Share on other sites
Brad Dorsey Posted November 11, 2014 Report Share Posted November 11, 2014 I clean off rosin with alcohol on a bit of paper towel. I tell my customers to hold the violin with the strings below the body to make sure no alcohol drips on the varnish. I remove black tarnish from silver-wound strings with the finest grade of steel wool. Quote Link to post Share on other sites
Rue Posted November 11, 2014 Report Share Posted November 11, 2014 I use a cork. Something like a vine bottle cork cut in half lengthwise works great. Just rub it over the length of rosined area of the strings. I always worry about solvent taking rosin into the core of the strings. I use the edge of whatever hand towel is in the bathroom. Don't laugh, it works. The thick edge does a great job of getting the rosin off the strings. The towel gets washed so it's always clean (and if not, I'll grab a clean one). I don't over-rosin to begin with - which really helps as well. Quote Link to post Share on other sites
ctanzio Posted November 11, 2014 Report Share Posted November 11, 2014 Cork works great even for large buildups. I occasionally throw out the cork so I have an excuse to open another bottle of wine! Quote Link to post Share on other sites
Rue Posted November 11, 2014 Report Share Posted November 11, 2014 String Cleaning Symposium at ctanzio's! Date and time to be announced! Quote Link to post Share on other sites
Yucca Posted November 11, 2014 Report Share Posted November 11, 2014 An old toothbrush or a cork. Both work well. Quote Link to post Share on other sites
Violadamore Posted November 11, 2014 Report Share Posted November 11, 2014 I remove rosin from the bowing area with a dry paper shop towel but cleanse the fingering area every so often with a towel with some alcohol on it to remove finger oils, but only if the fingerboard is real ebony (or other solid uncoated wood). If it's not real ebony, you'll find out really fast . Quote Link to post Share on other sites
Mat Roop Posted November 12, 2014 Author Report Share Posted November 12, 2014 Thanks folks.... appreciate the comments... I used to use a dry cloth then moved to an alcohol dampened cloth but what I have been using for the last few years is 0000 grade steel wool and find that it works exceptionally well by cutting the rosin off rather than flattening it out on the string, or soaking anything into the string windings.... So the purpose of my original post was to see what others do. As far as my customers are concerned, the steel wool idea seems to be safe advice. My final question then is to see if anyone has any reason to believe that the steel wool option is not a good idea. Thank everyone! Cheers, Mat Quote Link to post Share on other sites
FiddleDoug Posted November 12, 2014 Report Share Posted November 12, 2014 My gut feeling is that significant scrubbing with steel wool could eat through aluminum or silver windings. I don't have any experience to back this up, but I'll just stick to cork. Quote Link to post Share on other sites
Addie Posted November 12, 2014 Report Share Posted November 12, 2014 Microfiber dust cloth. Does a wonderful job. After reading that some strings are made with soluble stuff under the windings, I gave up on alcohol. And with a microfiber dust cloth, alcohol isn't needed anymore. Why use solvents that can damage the finish when you don't need them? Quote Link to post Share on other sites
MarkBouquet Posted November 12, 2014 Report Share Posted November 12, 2014 Steel wool does seem like overkill. I just use a dry cotton rag with my finger/fingernail behind it to scrape the rosin off. I do this at the end of every day, along with a thorough wipe down as I'm putting my violin away. Since it does the job perfectly adequately, I can't see any reason to take more aggressive actions. Keeping the strings clean isn't just about hygiene. My feeling is that they quickly become "false" because any rosin buildup causes an unequal distribution of mass along the length of the string. That may be a long held figment of my imagination, but the effect seems pretty real to me. Quote Link to post Share on other sites
HullGuitars Posted November 12, 2014 Report Share Posted November 12, 2014 I normally use alcohol on a lint free micro fiber rag.... Quote Link to post Share on other sites
tango Posted November 12, 2014 Report Share Posted November 12, 2014 Microfiber dust cloth. Does a wonderful job. After reading that some strings are made with soluble stuff under the windings, I gave up on alcohol. And with a microfiber dust cloth, alcohol isn't needed anymore. Why use solvents that can damage the finish when you don't need them? I clean with cloth dampened with cigarette lighter solvent. But now, after read that, I am hesitating. Regards Quote Link to post Share on other sites
vathek Posted November 12, 2014 Report Share Posted November 12, 2014 Products like Swiffer dry sweeping refills work great for getting rosin dust off the instrument too. Quote Link to post Share on other sites
La Folia Posted November 12, 2014 Report Share Posted November 12, 2014 I use fine steel wool, gift of Carl Becker. It works fine. I'm sure almost anything works, but I would sure stay away from liquids. Quote Link to post Share on other sites
palousian Posted November 12, 2014 Report Share Posted November 12, 2014 I am in the midst of trying to figure out a new ritual of strings/cleaning. In my old days of a funky old fiddle and Dominants, it all seemed so simple...Now I've got a really nice instrument and I've been experimenting with Obligatos. I love the sound of these strings, but they seem to go about three months and then get slippery. In the first month or so, I get several days from rosining the bow, cleaning with the microfiber cloth after each time I play. When I see rosin on the strings that doesn't come off with the cloth itself, I follow up with alcohol, maybe once every week or two. At the end of two months I find myself cleaning the strings with alcohol most days and adding a touch-up of on the rosin to get a good response. When I first went through this, I thought my bow needed rehairing, so I had that done and still had issues, so I changed the strings, and all was well. Now it's three months later and I'm back to the strings getting slippery--it has seemed that the D string is always first to go. I wonder if anyone else has this experience with Obligatos. When my new strings show up, I am going to look at a new and old D strings under a microscope and see if anything is apparent. Is the alcohol cleaning melting something, as was suggested? I can't understand why a string cleaned with alcohol would get slippery, why alcohol would be a problem at all. What is soluble in a string? I suspect that under a microscope I will see some sort of goop made up of alcohol-melted rosin coating the windings or trapped between them, that rosin sticks too much to that, and thus I have to use the alcohol treatment to remove it more frequently once the coating has been established. Or is the deal that these $80 strings just poop out in three months? ...sigh... Quote Link to post Share on other sites
Mat Roop Posted November 13, 2014 Author Report Share Posted November 13, 2014 ...... Keeping the strings clean isn't just about hygiene. My feeling is that they quickly become "false" because any rosin buildup causes an unequal distribution of mass along the length of the string. That may be a long held figment of my imagination, but the effect seems pretty real to me. Absolutely right... its all about clarity of tone. Quote Link to post Share on other sites
Jeff White Posted November 15, 2014 Report Share Posted November 15, 2014 I occasionally throw out the cork so I have an excuse to open another bottle of wine! Occasionally!!!!!!!???????Really??? Should be a nightly ritual. Oh, it is. We all need those fresh corks. Seriously though, I used to have to maintain a HUGE amount of fractional rentals and I have always used 0000 steel wool. Granted, they had steel strings, but it always worked well. Since whatever I used had to be fast, nothing seemed better. I never considered anything else, I'll try the cork-that seems like a good idea. jeff Quote Link to post Share on other sites
Will L Posted November 15, 2014 Report Share Posted November 15, 2014 I don't like to have a string perfectly clean of rosin in the bowing area. It may be purely psychological, but when I clean off ALL the rosin it seems to take a while to have as good a grip with the bow. I wonder if other violinists sense this too. So when I do use steel wool, I'm only loosening and removing most of it, not trying to get right down to the metal and take off ALL of it. That might be one good reason to use steel wool instead of alcohol. Most of the time I'll knock it down with the fingernail, only using steel wool sometimes. To me the bowing area is one thing, and the area where the fingers contact the strings is another. For the fingerboard and fingered areas, I'm happy enough with damp alcohol. Quote Link to post Share on other sites
Muswell Posted November 15, 2014 Report Share Posted November 15, 2014 I agree. Some rosin helps the grip, too much affects the sound. I often clean off the excess with a damp finger to while away the time when the conductor is picking on the woodwind. Then every so often it's the nail varnish remover. Quote Link to post Share on other sites
ctanzio Posted November 15, 2014 Report Share Posted November 15, 2014 Speaking of rosin grip, with the cooler weather descending on this part of the U.S. I am having an issue with rosin performance. Awhile back, I changed to a rosin that offered a moderate bite, lasted for at least a week of typical play and practice, and had only a modest build up on the strings and dust on the violin. But now that the temperature in the music room is typically in the mid-60F (I like it a tad on the cool side), it feels like the strings are skating on ice. If I play a string hard for a few seconds, the rosin again responds. But when I take a break or cross over to another string for some play, the previous string returns to its super-slick state. Has anyone encountered a rosin that has decent cool-weather performance characteristics? Quote Link to post Share on other sites
