Question about Violin Varnishing
Kallie
  • Replies 74
Since I work with so many different finishing materials (epoxies, poly, oil, spirit, etc.) each material asks for a different application method, so I enjoy adapting to it instead of adapting the material to my preference, I am just finishing varnishing a violin with Joe's thick varnishes without thinning and I really like it, I can apply very thin coats without any brush marks, it is the only technique I know that allows me to apply a very large amount of color in a single very thin layer with lots of control, and it is fun. Historically it is correct as it was a technique used in Italy at the time in several fields.
Thinning, depending on the thinner you may add unpredictable qualities to the film, but I don't know enough about the long term effects of these to comment.
Carl, the violin that you mentioned just finishing, are you applying the thick varnish with a brush, or also by hand?
So when varnishing what works better? Applying it thick like that or thinning it and appling multiple very thin layers? Does it make much difference one way or the other?
Im not sure if it matters either way... The way that I apply the varnish, is I put a little blob here and there, then smear it over the wood, until it is even. By the time it is all evened out, it is a very thin layer. Not sure if there is any difference between using small amount of thick varnish, rather than using larger amounts of thin varnish.
I am applying as my memory allows from what I learned  (and not forgotten) from Joe Robson in his wonderful workshop, I use a thick brush to roughly spread it, than with a small dry brush as Joe posted I tap tap tap tap, I also like to tap with the finger and palm afterwards, depending on the area. I use the same technique for some types of epoxy which are impossible to get a good finish otherwise.
Joe's workshop is really worth it, besides being so much fun and the greatest vibe!!!!
Thin multiple coats gives you an opportunity to make corrections. Thick coats that puddle along the edge in the C bout become a problem. Also, if you decide to use a brush,  for vln or viola, something that will fit around two thirds or a half of the width of the ribs. Thickness of brush is very important- get the thinnest brush possible. You don't want a thick brush that loads up with a lot of varnish that just stays there. Hard to believe but Walmart has the best inst brushes in their Hobby section for very cheap considering the quality.
Re: brushes
I remember that 60 years ago,, varnish was laid down with a varnish brush.. which looks like a chip brush The bristles tapered from the ferrule to the tip so that the varnish didn't load up and were pricey (kind of)
the technique was a thin coat using one side of the brush wetted to 2 /3 up
these days, a one inch chip brush is cheap ...36 for $10 +/-
for what it's worth
Jim
Speaking of Joe's Varnish Workshop... Joe, Are you planning another?  I haven't seen any updates on this lately (as indicated on your website)... inquiring mind want to know.. ;)
Kallie, just one of the many methods and the one I used- when your varnish starts to develop a shine indicating you've sealed your ground coats, and the varnish is definitely dry, carefully polish with wet 1200 grit paper to smooth out the surface. Dry wipe then  wipe with a barely damp cloth. Your intent is to only remove those little picks, not much else.  Klingspor  located in Germany makes all grits if you can't find 1200 paper. Any remains from the polishing disappears with the next coat. Repeat if needed after next coat. It is an easy way to get rid of those bumps too small to pick. fred
Excellent advice, thank you Fred.
Kallie,
You can get all the way up to 12000 grit in "Micro Mesh" sanding sheets. Metropolitan Music and International Violin sell it.  I use 2400 grit in between coats with the little mineral spirits for a lubricant.  Works quite well.  Its a cloth "sandpaper" which you can rinsed and reused quite easily especially if you use some lubricant to keep it from getting clogged..
Check out the Google search
Cheers,
Joe
Joe,
The varnish workshop will be held from March 21st - 28th in Concord, MA at the Emerson Center for the Arts.  Here is some basic info.  I will post details on the Makers Forum next week.
Would you like to join us?
on we go.
Joe
Violin Varnish Workshop 2015.doc
Joe,
on we go.
Joe
Joe you are the master at surfing the fine line...kind of always tweaked me how you get away with it but enough time has passed that I now understand how and why. On you go...bro.
Joe,
on we go.
Joe
Simple answer...Yes. But life is always more complicated ;) I have to get approval from my social/business advisor...:)
Thanks for the info.
Joe
Joe Swenson, on 24 Oct 2014 - 1:39 PM, said:
Simple answer...Yes. But life is always more complicated ;) I have to get approval from my social/business advisor... :)
Joe
Social / business advisor    does that translate as 'wife' ?    lol   me too
Re: brushes
for what it's worth
Jim
Jim,
Those fine brushes are still available...and still a pleasure to use.  But such brushes are suited to a different kind of varnish.  Brushing varnish has its best finish off the tip of the brush and left undisturbed.  But these varnishes do not respond so well to polishing after they are dry.  One can drop the viscosity of a violin varnish to use these brushes, but they will not "feel" like the brushing varnishes.
You can hand plane the edge of a maple board with great skill and success....but is will never be like planing a piece of fine ribbon striped Cuban mahogany which cuts like frozen butter.
But I digress...on we go,
Joe
Was trying to find a good pic that my wife would approve of (without so much of her in it).
Here are the three pups.  Diego (top) Sweet Pea (lower left) and new addition, Henry (lower right) who is very camera shy.  The other two were too busy chewing their nyl-a-bones to care about posing for a photo.
  • 7 years later...
11 hours ago, michael breid said:
I made the Ed Herron-Allen benzoin and pure spirits of wine (Everclear 190 alcohol), but I'm having trouble getting it to layer to a gloss. It seems to soak into the wood (tiger maple). Should I use some Jap drier in my mix? Any info would be appreciated.
I do not think that the Japan drier can help you, it is used to accelerate the polymerization of oil varnishes, with benzoin and alcohol it would probably have no effect. I think your problem is a too diluted solution, you can try to decrease the alcohol or to seal the wood in advance to limit the absorption. However, alcohol varnishes are generally very diluted, without a sealing coat of some sort I think it will take at least a dozen varnish coats to start seeing a glossy layer.
PS I don't know the dilution rate of Ed Herron-Allen benzoin and alcool mix
The recipe actually says to powder some benzoin into three fingers depth of pure spirits of wine for a few days and then add five or six strands of saffron - with this one can varnish anything glittery gold that will last for years.  It is a 1550's Alexi of the Piemont recipe that was debunked by Charles Reade in the Heron-Allen book.  I think Reade says it is just a quick drying picture varnish.
Heron Allen used Reade's information on varnish and put it in his own book.  In other words the varnish chapters are all of Reade's research.
It seems unsuitable as a main varnish for a violin, and in fact as I understand it is not the purpose for which it was reported in the book, it seems more like a final varnish to put on top of the actual varnish.
I beg to differ with the author of the book that the color given by saffron lasts for years (well maybe just a few years...).
Saffron as a dye for varnish/ground/sealer gives a brilliant yellow color that, sadly, fades within a year from my personal experience.
Used as a dye for fabric, the mordants used to fix the dye to the fibers might extend the color fastness, but I never pursued to option for wood working.
