sinker cypress from South Carolina
boscoe
Anyone have building experience (any instrument type) with "old growth" sinker cypress from the south eastern US?
I acquired two rounds of sinker cypress about 1 year ago.  It had been in a South Carolina river for around 110 to 130 years.  I cut it into wedges about 2 months ago.  It rings very clear and loud, although sustain may be about 2/3 to 3/4 of the better European and American spruces I've encountered.  I measured the density at 0.46.  Grain is very tight, and grains per inch very consistent across the face (approximately 30 grains per inch (12 per cm)).  I was told that the tight and consistent grain was due to these trees being below the forrest canopy.  Streaking from mineral uptake is interesting in red and orange hues.
Thanks
I can't speak to "sinker" cypress but I believe there was an article on using cypress some years ago; perhaps in Strad Mag.  It led Joseph Rashid to make at least one violin with a cypress top.  When I played it it sounded more "Cremonese" than any of his other several violins I played during that visit.
I'd like to know if anyone on MN has tried cypress of any variety, and how it worked out.
Nelson Thibodeaux made has some out of sinker cypress,
I played on one and it sounded very good, but all of nelson's fiddles sound pretty nice.
As I remember,, we tried to bend some of it,,, no way would it bend,
seemed to have more of a relation to carbon fiber instead of wood.
It felt dense and stiff,,, it rang more like steel than wood.
I might get it to bend now with more experience, it seemed rather brittle across the grain,
so it would probably have high mode 2 properties.
It was greenish in color with brown and blackish stripes in it.
I have never tried it but would if I had the chance.
Will, there were roughly ten Rashid instruments with cypress tops.  He replaced a good number of them on the earlier instruments, for what I suspect to be tonal reasons.  I think a few did survive intact on later instruments.
I believe there is one cedar top violin as well.  I have an unused cedar top he received from a luthier friend that is dark chocolate color and smells wonderful.  :)
Thanks, a/l,
I don't remember at the time him telling me he had done 10.
What I remember is that the exchange was amusing.  I played the violin and was very impressed and said, "This is the most Cremonese sounding new violin (meaning contemporary violin) I have ever played."  He said, "I did something different on this one, I used cypress."  I wish I could have played another few to know if that sound was similar in ALL the cypress topped instruments.
A few follow-on questions:
Of those of you who have seen/played/worked with a cypress top, do you recall any arch characteristics?  I'm guessing cypress generally would produce a soft tone relative to spruce, perhaps similar to western red cedar.  In such a case, would a low arch be approriate if one wanted to aid in projection?  Would too low of an arch rob some of its sweetness?  Structurally, would it tolerate a low arch?
What I've learned to this point:
It split poorly on quarter (very fiberous), cuts nicely on the bandsaw, has vertical bug tunnels about 1-1/2" from the outside surface ("pecky" as the seller called it, which I gather occurs with some frequency, but randomly), can suddenly split during bandsaw cutting when the blade is aligned with a wedge's quartered grain (ouch - found out the hard way).  It is interesting visually and tonally.  Some of mine has the aforementioned grey, but also orange and orange/red streaking from mineral uptake (which I believe would vary based on the local water/mud mineral content).  Also, I cut a 3/16" thick slice on the quarter - what a great deep sustained tone.
Any pearls of wisdom are appreciated, as I intend to give this wood a chance.  A very mellow quartet set might be the ticket; and, classical guitar.  There's a part of me that would like to see this limited supply wood have an accoustical opportunity before it's all relegated to patio furniture.
Thanks for your input,
Boscoe
