Joe Swenson
Davidov Poster Wanted
I was not going to start my own thread on this since there was one posted in Luthier Exchange.  Someone posted there inDecember 2012 with no replies.  So I'm just checking here if anyone has the Davidov Poster and would be willing to make a copy.
I just ordered the "Seveuse" poster from The Strad Library, and found a thread where it seems to NOT be the B form...   :huh:
I made a scan of the B&W dimension side of my Vuillaume cello posted and FedEx Office (formerly Kinkos) for like $7... That and shipping and your trouble I'd be willing too negotiate a fair price.    :rolleyes:
Heck, I'd be grateful if someone could just post some of the more critical dimensions off their poster...
Body Length =
Upper Bout =
C Bout =
Lower Bout =
Purfling distance to edge =
Edge Overhang =
Top Plate thickness at edge =
Back Plate Thickness at edge =
Rib height at Neck =
Rib Height at C-Bout =
Rib Height at Bottom Block =
etc ... and anything else you care to share!
I'm working on a tracing off the photo from Roger Hargrave's article from the 2001 Strad, but blown up, its a little sketchy.
Thanks!
Joe
P.S. Does the Strad mag ever reprint out of stock posters?
I was not going to start my own thread on this since there was one posted in Luthier Exchange.  Someone posted there inDecember 2012 with no replies.  So I'm just checking here if anyone has the Davidov Poster and would be will to make a copy.
I just ordered the "Seveuse" and found a thread where it seems to NOT be the B form...   :huh:
Body Length =
Upper Bout =
C Bout =
Lower Bout =
Edge Overhang =
Thanks!
Joe
It may not be necessary to limit yourself to one specific instrument when many of the forma B cellos have something to offer and in many ways are similar. Gore-Booth 1710, Duport 1711, Davidoff 1712, Bass of Spain 1713, Alexandre Batta 1714.
Bruce
Bruce
Thanks Bruce!
Absolutely a fine approach.  I like to mix and match and see what variations exist and then come up with my design.  That's the way I drew up my 16 3/4" viola..  For which, except for the points, the tracing I used for the viola form when scaled proportionally overlays the Davidov Cello tracing very closely.
I'd be happy to get dimensions on any one of these instruments, if anyone cares to share them! Sounds like the B Form exists or else how could so many makers utilize it.  Is it for sale somewhere?  Sacconi was only kind enough to share Stradivari's two violin moulds.   :D
Cheers,
Joe
Body Length = 758 belly - 757 back
Upper Bout =   342             340
C Bout =           232,5          232
Lower Bout =   437,5          436
Purfling distance to edge = 4.0-4.2
Edge Overhang =
Top Plate thickness at edge =from 4,2 to 4,5 - C bout 4,5-4,6
Back Plate Thickness at edge =from 4.2 to 4.7 - C bout 4,6 -5,0
Rib height at Neck = treble 109 - bass 108,5
Rib Height at C-Bout =        113               112,5
Rib Height at Bottom Block =114,5
I do not know if there are any legal issues to share photos of the discontinued poster, even if mine is not in good condition (badly folded).
Anyway I share this low resolution photo but I do not know if it will be possible to understand something......
Davide
Thanks Bruce!
Cheers,
Joe
Sacconi made a drawing from the Piatti of 1720 but I'll have to look for it.
Bruce
Davide
Much appreciated!
I have no problem with sharing something I paid for.  When I initially went to Kinko's to inquire on copying the Vuillaume poster, then initially mentioned not being able to copy copyrighted material.  But when I brought in the poster they had no problem.  I don't see any statement on the poster or website about copyright.issues.  If something is out of print and they aren't making more (so they won't be making any more money from it) what other choice is there?
Yeah, I can't quite get numbers off this.  If you want to PM me or email the higher res picture that would be great.
But in any case thanks for writing down the info!
Many thanks!
Joe
Bruce
You mean this one?
Doah! :blink:
It's been sitting right in front of me all the time and I forgot what I was even looking at.  All because the caption is on the opposite page. I get so focused I lose the trees for the forest!
It's a wonder I can find the coffee pot in the morning... :huh:
Thanks!
Joe
an architectural blueprinting shop can run a cello poster through their scanners
for a few bucks in color or black and white on glossy paper it you want.
It can also be resized, nothing wrong with copying them if you are using the copy's to build from.
Much appreciated!
Many thanks!
Joe
Ok, here are more readable pictures, I hope.
If the forum moderator deems it an issue please feel free to remove them.
Davide
If the goal is to rejuvenate a poster with multiple and deep folds in it, getting the poster laminated with clear plastic on both sides might do the job.  The folds won't disappear completely, but their presence will diminish.  I've had laminated (at Staples) a number of Strad posters, including cello size ones.  The posters were as they come with the magazine, folded.  After lamination the folds are barely visible.  Given that the poster, above, has more wear than a newly arrived, folded one, you might have a discussion with the employee doing the lamination to be sure they can do no harm with lamination.  At the very least, the lamination stops further wear.
The lamination cost me, as I remember, anywhere from $2 when on sale to about $10, maybe less, when not.
Davide
Beautiful!  Thanks so much!
Cheers,
Joe
I might have mentioned that I took my folded Vuillaume poster to Kinko's (FedEx Office) in November and for $7 they scanned the B&W dimension side in their large format scanner.  Full sized 24" x 36" ... Running it through the scanner flattens out all the folds.  It would cost a bit more to copy the color side.  But the line drawings and dimensions are the most important part.
Might be worth doing that for some of these more important posters that are out of print.
Joe
For those of you who would prefer to make a direct copy of the 1712 Stradivari 'Davidov' poster, I posted this thread earlier this month -
http://www.maestronet.com/forum/index.php?/topic/330010-discontinued-strad-posters-1712-davidov-1620-ba-viola-1580-gs-viola/?hl=%2Bjoel+%2Bpautz#entry616879
To summarize, this poster (and 2 other discontinued Strad posters) are available through inter-library loan to residents of the U.S.
Joel
Joel
Sorry I missed this post...  I only just got back on after being away...
Thanks for the info...
Joe
Thanks all so much for all the help with the Davidov Cello design.  You guys and Gals are ALL awesome! :D
I love my CorelDraw program.  Its great for laying out darwings and templates.  Here is Interesting comparison I was wondering if any one cared to comment on.  I took my tracing of ther Davidov Cello I derived from Rager's  2001 Article (PDF) and overlaid my scan (above) of the Sacconi B Form mould.
There is very close good agreement in overall dimensions and shape except for the lower points which are 7.5 mm lower in the Davidov Cello than in the original Sacconi B form drawing.  I assume Sacconi's drawing of the B Form is not off by that much.
What is the origin of this discrepancy?  Does this represent a variations Stradivari made in the B form cello.  And is this typical of the various cellos menitoned by Bruce above?
i.e. Gore-Booth 1710, Duport 1711, Davidoff 1712, Bass of Spain 1713, Alexandre Batta 1714.
Thanks,
Joe
Davide
Nice of you to ask! But then the Strad did not pay royalties either.
Joel
 Also nice to hear.
Hi Roger,
I realized later that the poster is your work and so I would have to ask permission to you first!!
I humbly ask forgiveness.... :)
I take this opportunity to ask you a question about the Davidov.
In the measures listed on the poster and in your article on The strad of Dec 2001 the stop length is missing ; could you be so kind as to fill this missing information?
Not a big issue (I dont use that particular model), only for completeness.
Davide
Hi Roger,
Davide
I believe I read these Form B cellos were adjusted at some point from a stop length of 405 mm to 400 mm.  I think that needs to be the case if its not already.
Joe
Hi Roger,
Davide
I'll check it out and get back to you.
Well I have extensive notes rubbings and measurements and about 60 photographs, (don't ask they are all slides), but no-where is there a stop length. I must have missed it, which is presumably why the Strad did not include it. I don't want to guess so maybe someone else has it. Sorry.
Thanks anyway for seeking.
Deducting the stop lenght from the photo on the poster comes out about 410 mm, a bit longer for my taste.
Maybe this could explain the low position of the lower corners of the Davidov superimposed on the Sacconi's drawing.
Davide
Davide
Yeah it's definitely long. I've been working off the poster trying to get a good tracing of the purfling this past week, and from this it looks like, if you scale the photo so the body length is 758 mm as specified, then stop length is about 709.3 mm...
At this scale length the lower bout and center bout agree with the printed specs on the poster for the Davidov Top measurements.
Top Plate:            Poster               Photo
Body length         758 mm            758mm
Upper Bout          342 mm            348 mm
Center Bout         232 mm            232 mm
Lower bout          437.5 mm         438 mm
The upper bout seems to be off by about 6 mm from the photo.   :huh: Maybe a type-o on the poster?
If I compare my tracing of the Davidov photo, with Strobel Cello pattern, it compares very favorably.
post-43707-0-29132800-1393527900_thumb.jpgpost-43707-0-79905400-1393527891_thumb.jpgpost-43707-0-43926700-1393527888_thumb.jpgpost-43707-0-37183900-1393527890_thumb.jpgpost-43707-0-29949500-1393527893_thumb.jpgpost-43707-0-29933000-1393527894_thumb.jpgpost-43707-0-70470800-1393527895_thumb.jpgpost-43707-0-88678500-1393527896_thumb.jpgpost-43707-0-57116200-1393527898_thumb.jpg
The points on the Strobel cello are a bit more pronounced.  But the bout width/shapes and point positions agree very nicely with the Davidov cello tracing when you alternate aligning the upper bouts or lower bouts.  The body length of the Strobel cello has been reduced by about 5 mm, presumably to correct the stop length, which is 400 mm in the Strobel pattern.  You can see when shifting around the tracing on the Strobel pattern, that he took the length out of the C-bout for his pattern.  Seems like a reasonable thing to do.
Does that mean Rostopovich, and Dupre, and Yo Yo Ma play(ed) the Davidov with the longer stop length?
The bridge and F-hole nicks line up perfectly with the line on the photo.  So the bridge position is where Strad intended it - at least in the picture. It's interesting to me anyway...
As to whether to make a 400 mm stop length cello or the longer Davidov stop length.  If I were a good cellist, I'd probably have a stronger opinion. However, I'm still leaning towards the Davidov dimensions. :)
Thanks Roger for the work on this poster!  Only wish I could have purchased one instead of piggy backing of someone else's photo's of your work!
Cheers,
Joe
Edited by Joseph Swenson
Out of curiosity what can be said about the apparent difference in shape of the tracing from the Davidov photo and the Sacconi B form cello mould?  It would seem the Davidov were made from a slightly different mould that the one Sacconi rendered in his manuscript.  And if the B Form was so prevelant why are there so many variations in Stradivari cello dimensions?
You know.. "inquiring minds" ..  yada yada yada..  :rolleyes:
I know this is an old thread but i was wondering if anyone has made a cello off of Sacconi's reconstruction of the cello b-form as posted above. Based on Joe's comments, it appears to differ slightly from Roger's  Davidov drawing (lower part of the centre bouts are lower in the Davidov)
