fiddlesurgeon Posted December 28, 2013 Report Posted December 28, 2013 What were you taught about this? flat-top bass bar0003.jpg The plateau spans the length of the f holes where it stays a more or less uniform 12mm height. It is preferred over the conventional design by the maker that gave me a start in making. I'll just say you'd be in good company.
Fiddler45 Posted December 28, 2013 Report Posted December 28, 2013 So what does the plateau bar do differently for the tone?
curious1 Posted December 28, 2013 Report Posted December 28, 2013 I want to avoid any copyright infringements, so I scanned only the bass bar part. It is attached. What were you taught about this? flat-top bass bar0003.jpg Anyone else use this? I have made bars like this and bars in which the "corners" are blended in as well other types of bars. I believe it puts the most strength where the top bends the most. Which is not in the middle of the plate but approximately at the bridge.
Davide Sora Posted December 28, 2013 Report Posted December 28, 2013 I want to avoid any copyright infringements, so I scanned only the bass bar part. It is attached. What were you taught about this? flat-top bass bar0003.jpg Anyone else use this? I do, but I don't think it change a lot compared to other possible shapes. I like the added flexibility in the upper bout area and the strongest point under the bridge. Works very well, at least on my violin. Davide
Peter White Posted December 28, 2013 Author Report Posted December 28, 2013 Ok so here's more about bass bars. I like the photo above but I have always beveled the top of the bar, the highest point is along the length of the f holes and usually comes out even with the edges of the plate if you put a straight edge across the bar. In other words about 12 mm more or less. Further I was taught to measure the width of the upper and lower bouts, divide in half and then by 7. This means that the upper part of the bar is about 12 mm from the center line and the bottom part of the bass bar is 14 mm from the center line, more or less. I no longer taper the bar but make it a consistent 5.5 to 6 mm thick the entire length of the plate. Anybody have objections? How much weight does a typical bar add to your top plate in the white? Peter
Fiddler45 Posted December 28, 2013 Report Posted December 28, 2013 So what does the plateau bar do differently for the tone? ?
Don Noon Posted December 29, 2013 Report Posted December 29, 2013 So what does the plateau bar do differently for the tone? ? Nothing, apparently. How much weight does a typical bar add to your top plate in the white? Peter I'd say (for me) 4 grams is about average. I have ranged from 3.5 to 5, with the heavier ones used on fiddles that I thought were too thin, and the light ones on experiments in light weight. Curtin's article showed Cremonese bars (probably actually replacements) ranging from 4 to 4.5 grams.
Davide Sora Posted December 29, 2013 Report Posted December 29, 2013 So what does the plateau bar do differently for the tone? Very hard to appreciate a difference, too many variables in play for a reliable testing. For me it is simply a more logical distribution of mass and stiffness. I have the feeling that enhances the depth of the low register (G string in particular) but honestly I'm not sure that can be attributed to the bassbar shape....... Davide
Davide Sora Posted December 29, 2013 Report Posted December 29, 2013 Ok so here's more about bass bars. I like the photo above but I have always beveled the top of the bar, the highest point is along the length of the f holes and usually comes out even with the edges of the plate if you put a straight edge across the bar. In other words about 12 mm more or less. I do not follow this rule, high archings requires lower bars and low archings higer ones, so I think it is misleading Further I was taught to measure the width of the upper and lower bouts, divide in half and then by 7. This means that the upper part of the bar is about 12 mm from the center line and the bottom part of the bass bar is 14 mm from the center line, more or less. This is for set the tilt only and not to determine the position of the bassbar, that is set by the bridge. I no longer taper the bar but make it a consistent 5.5 to 6 mm thick the entire length of the plate. I glue the bassbar this way and put some taper afterwards, because I like full thickness bar ends. Anybody have objections? How much weight does a typical bar add to your top plate in the white? Peter Regarding bassbar weight I'm with Don Noon, about 4 gr average ranging from 3,5 to 5 gr Davide
Peter K-G Posted December 29, 2013 Report Posted December 29, 2013 I tune the top's M5 back to it's original frequency (no bassbar and without f-holes) by adjusting the bass bar. they end up 10-11 mm high, measured towards the middle.
Melvin Goldsmith Posted December 29, 2013 Report Posted December 29, 2013 Imagine lines across the widest parts of the upper and lower bouts of the front. I try to have my bar at near 90 degrees to the belly where it passes in these places. I also put the highest part ahead of the bridge....pic below is all I could find in a copy of 23mm high Belly Goffriller viola. (The high arch makes it an example to be taken in context)
curious1 Posted December 30, 2013 Report Posted December 30, 2013 This is about typical for me. image.jpg Basically like Joe Curtin's article in The Strad a few years ago. The heights of the bar follow a linear regression.
Peter K-G Posted December 30, 2013 Report Posted December 30, 2013 This is about typical for me. image.jpg Imagine lines across the widest parts of the upper and lower bouts of the front. I try to have my bar at near 90 degrees to the belly where it passes in these places. I also put the highest part ahead of the bridge....pic below is all I could find in a copy of 23mm high Belly Goffriller viola. (The high arch makes it an example to be taken in context) How dens wood do you use for those bass bars? they look heavy, over 5 g? Mine is typically ~0,45 g/cm3 and high ringing (speed of sound) around 3-4 g.
curious1 Posted December 30, 2013 Report Posted December 30, 2013 How dens wood do you use for those bass bars? they look heavy, over 5 g? Mine is typically ~0,45 g/cm3 and high ringing (speed of sound) around 3-4 g. That bar is .38g/cm3 (low for me) and 5800m/sec (avg for me). 12mm tall and 3gms.
Craig Tucker Posted December 30, 2013 Report Posted December 30, 2013 This is about typical for me. image.jpg Curious 1, Nice bar. Mine look much like this now-a-days.
JohnCockburn Posted December 30, 2013 Report Posted December 30, 2013 That bar is .38g/cm3 (low for me) and 5800m/sec (avg for me). 12mm tall and 3gms.Hi C1. It looks quite a bit higher than 12 mm in the photo. Which side is this measured from? Also, would it be possible to outline the "curtin method" for those of us who don't have the article? Cheers John
curious1 Posted December 30, 2013 Report Posted December 30, 2013 Hi C1. It looks quite a bit higher than 12 mm in the photo. Which side is this measured from? Also, would it be possible to outline the "curtin method" for those of us who don't have the article? Cheers John 12mm measured from the inside of the bar. I remeasured just to be sure. Curtin's method is based on a triangle. I think Carl does a similar thing but with the high point in the middle. I'll write later with a better description.
Peter K-G Posted December 30, 2013 Report Posted December 30, 2013 Curious 1, Nice bar. Mine look much like this now-a-days. It very elegant yes, I use to make them like that, but now I do them like this:
Melvin Goldsmith Posted December 30, 2013 Report Posted December 30, 2013 How dens wood do you use for those bass bars? they look heavy, over 5 g? Mine is typically ~0,45 g/cm3 and high ringing (speed of sound) around 3-4 g. Hi Peter,It's a good question. My bar is from a front bought from Pahler dated 1969. The density is 0.42. The bar itself is not actually heavy. I use a much thinner basic profile than I see on your nice photos on post 35 in this thread. I'll add a picture to illustrate. I am aiming for lightness and stiffness in the bar generally so I try to shape the proportions in favor of height rather than width. I'll generally use higher density wood for the bar even if the belly is low density...but It's worked for me with low density bars also. EDIT The caption to the drawing should read ' bar profile at highest point'
Peter K-G Posted December 30, 2013 Report Posted December 30, 2013 So the weight is pretty much the same (3-4 gms) with both design. The main reason why I have change the bass bar style is to spread the load/movement over a longer area: http://www.zuger.se/Improving_the_dynamic.html (and it's easier to tune )
nathan slobodkin Posted January 1, 2014 Report Posted January 1, 2014 Hi Peter,It's a good question. My bar is from a front bought from Pahler dated 1969. The density is 0.42. The bar itself is not actually heavy. I use a much thinner basic profile than I see on your nice photos on post 35 in this thread. I'll add a picture to illustrate. I am aiming for lightness and stiffness in the bar generally so I try to shape the proportions in favor of height rather than width. I'll generally use higher density wood for the bar even if the belly is low density...but It's worked for me with low density bars also. EDIT The caption to the drawing should read ' bar profile at highest point' Melvin May I ask what led you to favoring lighter bars over heavier? My intuition is that a lighter bar will favor response while a heavier bar will increase the depth of the bass. I'm being partly influenced by the comments concerning the Verzi double bar system which enjoyed a brief popularity in the 1920s and supposedly gave a deeper tone to the violins it was installed on. In any case I started shaping my cello bars without tapering in order to add weight in the center and I think it gives a boomier bass which players seem to like. I generally like darker sound on violins also but am not sure I can hear any difference from different bar shapes. I haven't actually tried different bars on the same instrument but since I make only a few models and stick with the same wood for a number of instruments I usually can get an idea of what effect my experiments have.
Melvin Goldsmith Posted January 1, 2014 Report Posted January 1, 2014 Melvin May I ask what led you to favoring lighter bars over heavier? My intuition is that a lighter bar will favor response while a heavier bar will increase the depth of the bass. I'm being partly influenced by the comments concerning the Verzi double bar system which enjoyed a brief popularity in the 1920s and supposedly gave a deeper tone to the violins it was installed on. In any case I started shaping my cello bars without tapering in order to add weight in the center and I think it gives a boomier bass which players seem to like. I generally like darker sound on violins also but am not sure I can hear any difference from different bar shapes. I haven't actually tried different bars on the same instrument but since I make only a few models and stick with the same wood for a number of instruments I usually can get an idea of what effect my experiments have. Hi Nathan, That's food for thought because from what you say it would seem we are seek a similar bass sound although I also ideally seek fast response as I guess you do too. Whilst I seek to make a bar light I still want it strong and mine are on the deeper side. I'll try a heavier bar next time the chance arises and see what happens. I can share one experience of violins with bars that were very heavy in the center....Many years back I finished some fiddles off for a friend who'd had them made in the white in Italy. The bars were unusually deep and heavy in the middle ( about 16mm high and I was asked to leave them as they were) Most of the fiddles had problems like incorrectly shaped necks /boards,badly placed F holes ill fitting seams etc but they all sounded annoyingly good. The bass was variable between OK and great but the E string always divine! I have tried different bars on the same instrument a few times but I'm not sure that I reached conclusions so far other than kidding myself but I am very interested in your findings and I don't doubt them at all. Respect and thanks for sharing, M
Michael_Molnar Posted January 1, 2014 Report Posted January 1, 2014 Given that the height of the bass bar controls the ring mode E5, I imagine that going beyond the standard 12 mm peak height will produce a very high frequency response favoring the E string. The issue is to keep the weight down so as not to kill the total power output and muffle the lower frequencies. This is not a simple matter for sure. Happy New Year Melvin Mike
actonern Posted January 1, 2014 Report Posted January 1, 2014 Is everyone measuring bar height from the same side? Closest to the plate edge side, or closest to the centre of the fiddle side?
