kevin Prestwich Posted September 30, 2013 Report Posted September 30, 2013 I have a bunch of Engelmann Spruce which is cut and split into sizes suitable for double bass. This is master grade wood cut from a tree killed in the "Blackwell Fire" in central Idaho in 1994. This wood was cut into 52" rounds and then split into quarter and eighth segments which measure 52" X 12"-17". The log has a density of .33-.34 and the moisture content is 7-9% with straight, even winter grain lines. I have about 30 tops, maybe more. Available individually or potentially as whole. If someone wanted all of them I'd guess the whole load would be about 1500-2000 lbs. Individual tops can be shipped via USPS but if someone wanted much more than a few tops he/she would have to either bring a truck to Idaho or arrange freight. The third to last photo is of about one third of the total amount of wood available. Individual bass tops are $400-$500 ( there is some variation of quality within the log). Cello and violin pieces are also available. Price for the whole load can be negotiated.
Christopher Jacoby Posted September 30, 2013 Report Posted September 30, 2013 Fairly wicked checking in the air there. How's the bug damage?
kevin Prestwich Posted September 30, 2013 Author Report Posted September 30, 2013 A few bug holes here and there. That said, most of the wood (85%) is pristine. I just included a cello top (image #355, the last image) which gives an indication of the level of holes which do show up every now and then. Note the holes at the top and a few at the bottom of the piece. Note that this wood has been dead for twenty years and all active Spruce Beetle activity happened many years ago. Here is a quote from the Alaska Division of Forestry website at http://forestry.alaska.gov/insects/sprucebarkbeetle.htm "Spruce beetles will not attack well-seasoned wood and are normally gone from trees that have been dead for more than one year ( though beetles and other insects may enter the wood). Old wood, free of spruce beetles, is not a potential spruce beetle infestation source." I hope this answers your question.
