Fjodor Posted June 26, 2013 Report Posted June 26, 2013 I started with #4 yesterday, on the same model as number 3. On #3 I used low density spruce, this is a much heavier top. This is my hi tech block sander
actonern Posted September 2, 2013 Report Posted September 2, 2013 Love that corner block sander! For the end blocks, I use this on a table saw... cheap, and precise and because the table saw top is bigger than most other sanding machines, you can more confidently control the mold/blocks as you work. http://www.busybeetools.com/products/SANDING-DISC-10IN..html
Fjodor Posted September 2, 2013 Author Report Posted September 2, 2013 Thanks for the tip actonern. I don't own a table saw but would like to have something better for the endblocks, it is not easy to get smooth curve there with my setup.
Fjodor Posted January 28, 2014 Author Report Posted January 28, 2014 It's a long time since i posted but the violin is finished now, so I thought i'd post some pictures. These are some that I took while varnishing. The violin turned out fine, and I think it is my best sounding so far. Maybe the high density spruce is to thank :-)
violins88 Posted January 28, 2014 Report Posted January 28, 2014 Fjodor, I love the varnish. What are you willing to share about it? Thanks John
Fjodor Posted January 28, 2014 Author Report Posted January 28, 2014 Thank you John. I used Joe Robsons products. I tried to get a dark base with tea and a short fuming with ammonia. Then sodium nitrite and UV. After that I used Joes ground system with aged wood color gold. Then greek pitch brown varnish with a little dark rose color concentrate.
~ Ben Conover Posted January 29, 2014 Report Posted January 29, 2014 Fjodor, the purfling detail is great and the varnish looks very good indeed. Since you can do the handwork to a high standard, you need not use many machines, it only complicates things in the end. Plus, people will always appreciate hand skills.
violins88 Posted January 29, 2014 Report Posted January 29, 2014 Fjodor, the purfling detail is great and the varnish looks very good indeed. Since you can do the handwork to a high standard, you need not use many machines, it only complicates things in the end. Plus, people will always appreciate hand skills. Ben, Is this you? I looked at some of your photos of violins and flowers. You know what you are doing with light.
Fjodor Posted January 29, 2014 Author Report Posted January 29, 2014 Thanks for the kind words.I don't use many power tools, and prefer to do things by hand.I was thought to finish the corner blocks with a sanding drum in a drill press and tried to make something similar.The sanding goes so slowly so there is no risk of ruining things.Cool photo of Ben!
Fjodor Posted July 10, 2014 Author Report Posted July 10, 2014 This graduation punch was completed today. It used a leftover birch board with nice figure as a base and finished it with tung oil.
Fjodor Posted July 31, 2014 Author Report Posted July 31, 2014 I took some pictures while doing the purfling in the corners on backplate I'm working on. This is how I do it: Mark the purfling channel with the marking tool and extend it a bit in the corner for a "bee-sting" Rinse the groove and even out the curve a bit for the beesting Glue in the c-bout purfling as this and leve it to dry. I leave a bit wood in the outer bout groove to help prevent hurting the corner "triangle" Then cut away half of the c-bout purfling in the corner, bend and try to fit the outer pufling strip as good as possible. All strips glued These are the tools I used.
Peter K-G Posted August 1, 2014 Report Posted August 1, 2014 Really nice work! How old is the birch and how does it "feel" compared to the maple of your last one. One of LK's first violins, with birch back, beat mine with two placements in Sibelius violin making sound contest (a long time ago). This was also one of the violins that stod out for more playing because it had a special sound, espacially on E string. LK and I was there when they played this violin a couple of times. It had very clean carrying higher notes, with lots of overtones. I have also heard the same phenomenon from a violin with rowan back, made by an amateur. I think I know why I have linked this particular sound also to one of curious1's violins with very high density back.
Fjodor Posted August 1, 2014 Author Report Posted August 1, 2014 Thanks, I would think that this wood is about 20 years old. (It's some leftovers from my grandfathers making) I think this birch behaves much like maple but it is a bit more prone to split along the grain when working it, so one has to be careful. I have several birch back fiddles (and made one my self) and they are all very different from each other, so I can't say there is some special quality to it. Personally i think the spruce and the model of the violin makes more difference. My latest birch back, a small model, I left very thick. It was developing nicely but recently I think it has gotten worse recently (dry g string), but maybe it's just a matter of adjusting the sound post...
franciscus Posted January 22, 2015 Report Posted January 22, 2015 @Fjodor, this violin certainly deserves much better presentation and I'd like to see it, FWIW
Fjodor Posted January 22, 2015 Author Report Posted January 22, 2015 Here are some more pictures. It is my fifth violin.
Peter K-G Posted January 23, 2015 Report Posted January 23, 2015 You really have talent! Great work with the scroll. The varnishing job is also outstanding, it looks like it's not too thick and yet full of colors. The whole violin is really nice. LK shouldn't have introduced you to violin making he has competition now
Ken_N Posted January 23, 2015 Report Posted January 23, 2015 Fjodor, That is really sweet. I like the model outline, what is it? It certainly isn't frumpy. I don't like frumpy looking violins. I used birch on one, and it is the most clear sounding of any that I've made. It had deep flames in it that you had to watch out for, and the ring tone was a little lower; but topped with a low density top it seemed to work. Nice scroll too. I haven't figured that part out yet. Ken
Fjodor Posted January 23, 2015 Author Report Posted January 23, 2015 Thank you Peter, It's still a long way to LK's standard. ( I think it would be for most makers We have to meet some time and play and compare the violins when you get yours finished. Thanks Ken, This is my own small model that I made when i had some nice wood with small dimensions. I have made 3 of them now and tried a bit of different things. I also find birch works fine for the back. Higher density spruce seems to work best for me so far.. I tried to follow the plowden graduations for the back, it ended up at about 100g. The tap tone in the middle of the back ( Ring tone ?) was 300hz, is that low? Anyway the violin seems to have a nice deep tone
Peter K-G Posted January 24, 2015 Report Posted January 24, 2015 300 Hz is low, but on the other hand if you like the violin it doesn't mean anything. For this low performance birch wood the arch should have been ~2 mm higher to get M5 ~340 Hz Have LK to show you next time you visit him.
