  • Replies 499
Looks great Melvin. Is that color from the varnish alone?
Hi Daryl, Thanks, This is just another experiment but I can confirm that all the color is from cooking the resin. I have been looking in the direction of the Brandmair book which tends to find that the primary color is not from pigment. I was also inspired to look in this direction from following the late & great Koen Padding's products and findings and a conversation or two. ( I am not privy to his recipes) I have no idea if my varnish sample is going to work in the long term. I added a bigger pic on the original post. both are scans rather than photo.
Thanks Melvin. If you don't mind, what is the resin:oil ratio? Also, how many coats of varnish on these samples?
Hi Daryl the resin oil ratio is 1/1 by weight but I had to add solvent for brushability. 4 coats on the lighter sample and 6 on the darker ( both the same varnish). I also experiment with different ratios with a view to making a lean mix to correspond with the ratio suggested in the Brandmair book with variable results, some of the lean mixes being rather prone to cracking...
Thanks Melvin. How would you describe it's thickness at this point? It looks thin but it's hard to judge from photos.
Hi Daryl, The paler sample is thin, the darker one is probably going to be about the right thickness once cured. I took a photo on macro of (below) it which seems to make it look thicker than it is.  I quite like the pin holing in the texture which reminds me of the Lady Blunt Strad ( not that I am making any claims for this humble sample which has yet to be cured and tested) I think one factor for the pin holing is the use of solvents which are making this varnish shrink wrap around the texture of the wood. I am experimenting a lot with different solvents in the mix recently i.e  turps, paraffin  lamp oil , white spirit, rosemary oil etc plus some more modern solvents of varying volatility that Kremer offer and finding that these effect the outcome a lot in regard to the look and outcome. What I use on my instruments is generally stuff that I know works reliably...what I am experimenting with here is not yet ready to be used. If I was sane I would buy all my varnish from proper varnish makers like the classic Cremonese probably did but I just can't stop experimenting...It's a compulsion.
I love the look Melvin. What about thinning to brushing consistency with linseed oil rather than a solvent? I'm slugging through the Brandmair book as well but i confess i simply don't understand how the varnish is cooked to achieve the wonderful colour you are getting!
lovely work
Chris
lovely work
Chris
Hi Chris, You are correct that adding linseed oil will ease brushing but it will also dilute the color of the resins because it remains as a constituent of the varnish. Thanks for your kind words re my varnish sample. I should say that the directions I lately have been looking in are from reading the Brandmair book rather than from recipes within the book but in the footnotes Peter Greiner does give a recipe they tried that was based on their analysis.
Thanks Melvin. When cooking the resins for color do you find temperature or time to be the critical factor? Cheers,
Hi Daryl,
Both. Most important thing is to keep close observation and make some rules and keep in mind that the next batch of the same species from the same source might not cook the same....
Interesting stuff Melvin.
I cooked three batches a couple of weeks ago, a litre of varnish each.
The first I made very lean. I found it reached a good string very early, and didn't want to leave it on much longer. It has a strong tendency to crack in a thick coat, and I wonder whether it's cooked long enough.
I made two using Krammer dark rosin, and one with a litre of thickened turpentine that I found I had. In the past I have usually started with pale rosin. I think cooking pale resin to dark gives a much brighter, clean varnish, with a much better yellow/red, than starting with the dark stuff. Any Comments?
Melvin, as a fellow varnish experimentation compulsive, I like to think of the affliction as an opportunity for personal growth.
Hi Conor,
Thanks for your comment. I can only comment on what you mention as a colleague because I am no expert.
I think that different resins cook differently, even if I order the same stuff from Kremer for example it seems to cook differently. I guess this is inevitable with natural ingredients until we know more about them.  I think that a lean varnish could be very dependent on having the right resins involved.
A set of linings fitted and glued in a few minutes...It's Sunday and sunny so the list of to do is for Monday.
That's how I use to do it too, with clothespins, the springs are a little bit too week though, so I have bought some better small clamps now. You have a thin enough mold to get it out? I have to take the mold out before glueing the top linings.
Hi Peter. I find that if the linings fit well there's not much pressure needed.  The Old Cremonese glued in both sets of linings before removing the mold. If you use the same type of mold and thickness they did it is no problem to remove the mold with two sets of linings glued in.
Clever!
Yes indeed!...BUT.....If you need a lot of muscle to clamp ribs and linings together you are doing something wrong and also running the risk of distorting your rib outlines...as I said it should be a very simple procedure to bend linings to fit the ribs in a few minutes for the whole structure....If you can't do this easily in a few minutes, you need more practice not stronger clamps.
