jezzupe Posted September 2, 2019 Report Share Posted September 2, 2019 On 9/1/2019 at 7:24 AM, Michael_Molnar said: We had a family event in New York City, so we made a stop at the Met to see Stradivari 's 1711 "The Antonius". nice Quote Link to comment Share on other sites More sharing options...
Michael_Molnar Posted September 3, 2019 Author Report Share Posted September 3, 2019 15 hours ago, jezzupe said: nice Grazie Quote Link to comment Share on other sites More sharing options...
MikeC Posted September 3, 2019 Report Share Posted September 3, 2019 I agree about the F holes, that's a good photo and good reflections. Quote Link to comment Share on other sites More sharing options...
Michael_Molnar Posted September 10, 2019 Author Report Share Posted September 10, 2019 I am back on the air with the CNC. I laid out an entire new top trying to get closer to a Strad contour. I had to redo the f-holes. My program lets me tweak the position X,Y position and rotate them a few degrees around the vertical Z axis at the CNC machine. That f-hole "needle" end mill is only 0.75 x 6 mm going at 35K RPM. I go down to 5 mm in three passes at a snail's pace. Although this is a test plate of red spruce, 0.41 density, I may use it because it came out so good. I guess I am getting good at this. Usually I destroy one or two plates before getting a good one. If you look closely you can see a surface ripple that I blame on a cheap ball socket screw assembly on the Y-axis. However, I am not after a micron finish. This plate will easily clean up with a scraper. I am pleased with so little tear out. This contour cutter is a bull-nosed (not a ball end) 1/4" end mill from Precise Bits (0.06"radius corners 2 flutes. I immediately noticed from its cutting sound that it is s good cutter. Tomorrow, I will flip this plate over and hog out the inside. The f-hole center plugs will then fall out. I also expect to get in some brown oxide pigments for testing. I can never get enough pigments. Quote Link to comment Share on other sites More sharing options...
scordatura Posted September 11, 2019 Report Share Posted September 11, 2019 Thank you for the mill info. Comes in handy for us newbies. I think I am going to order those. Been chipping away at some modeling. Any particular reason for the tail at the bottom of the plate? Love the hold down setup! Quote Link to comment Share on other sites More sharing options...
Michael_Molnar Posted September 11, 2019 Author Report Share Posted September 11, 2019 The plate shape for a top is identical to a back. I use the same program for both. The neck button will be removed as well as the bottom tab from a top. There are three reasons I attach these tabs. 1. The tabs reduce breaking the glue seam due to router vibrations. This is insurance in a way. 2. I use these tabs for holding down and supporting the plate upside down to hog out the inside. 3. The bottom tab serves as a narrow extension for the end mill to start cutting the wedge end gently. Without it, the end mill does not know where the edge begins. My plate wedges are various lengths. The tabs cut the wedge down to size and avoid crashes. Of course, the button is not cut off a back plate. I committed that sin only once amd have been doing penance ever since. Quote Link to comment Share on other sites More sharing options...
Michael_Molnar Posted September 11, 2019 Author Report Share Posted September 11, 2019 Now here is a photo of hogging out the inside of the plate. Note how the f-hole cutouts fall out. You can also see how I use the bottom tab and tie-downs to raise and support the upside-down plate. After I cut off the tabs and tie-downs, I will start purfling. Life is good when everything works. Quote Link to comment Share on other sites More sharing options...
scordatura Posted September 11, 2019 Report Share Posted September 11, 2019 Ahh I see, dual use of the tabs for inside material removal! I was wondering how I would accomplish that. Assuming your outside arch is finished, what would you recommend leaving for final scraping? I was thinking .2 or .3 mm. Quote Link to comment Share on other sites More sharing options...
Michael_Molnar Posted September 12, 2019 Author Report Share Posted September 12, 2019 The amount of scraped material depends upon the surface quality and how close you are to the final shape. I like to leave some meat on the bones as it were. My CNC'ed plates are about 5mm thick overall. I then scrape the top to a final smoothed contour. Then, I remove the excess as I graduate the interior. A lot of handwork remains after CNC'ing. Quote Link to comment Share on other sites More sharing options...
scordatura Posted September 13, 2019 Report Share Posted September 13, 2019 19 hours ago, Michael_Molnar said: A lot of handwork remains after CNC'ing. Yes, like edge work. Quote Link to comment Share on other sites More sharing options...
Michael_Molnar Posted September 13, 2019 Author Report Share Posted September 13, 2019 2 hours ago, scordatura said: Yes, like edge work. Edgework is arguably the most important part of great craftsmanship. Quote Link to comment Share on other sites More sharing options...
Michael_Molnar Posted September 24, 2019 Author Report Share Posted September 24, 2019 I finally cut up the split billets of log 1704 from Kevin Prestwich. After sawing off the ends to view the grain pattern, I pick the straightest section (40 cm) and use the plastic template to find the cleanest cuts. The red tape on the template is needed to find it on my cluttered bench. I then use the planer to flatten and align the spine's grain lines. I feel that the Grizzly jointer/planer saved the day. The wedges are then sawn on my bandsaw. It's a helluva lot of work and sawdust - something that Rover, the robovac, can appreciate. Quote Link to comment Share on other sites More sharing options...
Don Noon Posted September 24, 2019 Report Share Posted September 24, 2019 One nice thing about resawing your own tops out of Kevin's billets: there's plenty of wood there for blocks and bass bars, and sometimes even an extra set. Quote Link to comment Share on other sites More sharing options...
Michael_Molnar Posted January 20, 2020 Author Report Share Posted January 20, 2020 After a long hiatus, I fired up the CNC after making a lot of repairs. Like me, the machine is showing its age. However, we are still functioning. These photos show the plate shape and hold-down tabs which are sawn off after the top surface is done. The next process is to do the surface contour tomorrow. Quote Link to comment Share on other sites More sharing options...
Michael_Molnar Posted January 20, 2020 Author Report Share Posted January 20, 2020 Here is the next step, contouring using a new model made with the help of a friend’s critiques. I am using a bull nosed end mill with 0.060” corners. This photo is taken through the window of the dust cabinet. Quote Link to comment Share on other sites More sharing options...
Michael Szyper Posted January 20, 2020 Report Share Posted January 20, 2020 Keep on working, Mike. Looks stunning. Can‘t imagine how much time you spent to make all that work. Quote Link to comment Share on other sites More sharing options...
scordatura Posted January 21, 2020 Report Share Posted January 21, 2020 On 1/19/2020 at 7:44 PM, Michael_Molnar said: After a long hiatus, I fired up the CNC after making a lot of repairs. Like me, the machine is showing its age. However, we are still functioning. These photos show the plate shape and hold-down tabs which are sawn off after the top surface is done. The next process is to do the surface contour tomorrow. It is hard to tell from the pic but is that a straight flute bit to cut the outline? From the fuzz on the top edge it almost looks like an up cut mill at work. Quote Link to comment Share on other sites More sharing options...
Michael_Molnar Posted January 21, 2020 Author Report Share Posted January 21, 2020 I use this straight flute for holes (!) and edges. It is neither up- nor downcut. Yes, the edge will have fuzz with this cutter, but what does that matter? I know you are thinking of chip removal, but wood does not behave like a metal. The wood chips fly out. I think it’s due to air turbulence. For deep holes, I stick with upcut spiral flutes. Quote Link to comment Share on other sites More sharing options...
Urban Luthier Posted January 21, 2020 Report Share Posted January 21, 2020 nice to see the 'nursery' shots mike! very cool Quote Link to comment Share on other sites More sharing options...
Michael_Molnar Posted January 22, 2020 Author Report Share Posted January 22, 2020 Thanks, UL. Here’s another family photo. Here is the flip side being hogged out. This end mill is a 1/4” 0.060” corner bullnose. The edge is about 7 mm thick and I’m taking the plate thickness down to 4+ mm. Quote Link to comment Share on other sites More sharing options...
Michael_Molnar Posted January 24, 2020 Author Report Share Posted January 24, 2020 Here are two photos of the top plate. First is the outside just before I fit the purfling; the second is the inside. Quote Link to comment Share on other sites More sharing options...
Michael_Molnar Posted February 4, 2020 Author Report Share Posted February 4, 2020 I am in the midst of rolling the edges with files. The first three left to right are crossing files 00, 0, 2 Swiss pattern. The fourth is a half round 0. Next I will be graduating the plate. Quote Link to comment Share on other sites More sharing options...
Michael_Molnar Posted March 23, 2020 Author Report Share Posted March 23, 2020 Life goes on here. At the bench I glued a top, garland, and back together Next I pulled from the shelf a neck/scroll done on my CNC a long time ago. I also inserted some stiff graphite rods as an experiment as you can see. Now, I scrape and gouge away this roughed out scroll. I will refer to this latest work in progress as my coronaviolin. Quote Link to comment Share on other sites More sharing options...
Michael_Molnar Posted April 2, 2020 Author Report Share Posted April 2, 2020 Work on the coronaviolin continues. Today I glued the fingerboard and nut onto the neck. I know this clamp setup is not kosher, but it works well for me. Tomorrow, I will remove the clamps and finish up this neck assembly. I hope that everyone is well and safe. Quote Link to comment Share on other sites More sharing options...
jezzupe Posted April 2, 2020 Report Share Posted April 2, 2020 2 hours ago, Michael_Molnar said: Work on the coronaviolin continues. Today I glued the fingerboard and nut onto the neck. I know this clamp setup is not kosher, but it works well for me. Tomorrow, I will remove the clamps and finish up this neck assembly. I hope that everyone is well and safe. Mike Molnar, Frank Sinatra..."did it my way!" looking good Quote Link to comment Share on other sites More sharing options...
