Peter K-G Posted February 25, 2013 Report Share Posted February 25, 2013 After a lot of posts and interesting discussions in: Body modes as violin sound equalizerand other topics, it is time for some action I visited a friend last night, who is professional violin maker and bought tone wood for two violins. Top - two halves MC < 6% (Meter showed 5 % in some places) Half 1. weight 330 g dencity 0,423 g/cm3 longitudinal celerity ~ 6036 (Don Noon way: Ridiculously easy way to measure speed of sound) Half 2. weight 405 g dencity 0,433 g/cm3 longitudinal celerity ~ 5928 Quote Link to post Share on other sites
Oded Kishony Posted February 25, 2013 Report Share Posted February 25, 2013 You can download a very good program first developed by Oliver Rogers that measures density, stiffness along, across and diagonally on a plate. (top or back) The link above is to Tom King's web site which has lots of useful information as well. The density of your top seems on the high side. If the wood is extra stiff then it's probably ok, but if it's not then I would find a different piece. Oded Quote Link to post Share on other sites
Peter K-G Posted February 25, 2013 Author Report Share Posted February 25, 2013 You can download a very good program first developed by Oliver Rogers that measures density, stiffness along, across and diagonally on a plate. (top or back) The link above is to Tom King's web site which has lots of useful information as well. The density of your top seems on the high side. If the wood is extra stiff then it's probably ok, but if it's not then I would find a different piece. Oded Thanks Oded, Both top and back plate pieces are in the owen right now so their dencity should go down a little. The wood is relatively new ~2005. Quote Link to post Share on other sites
Peter K-G Posted February 25, 2013 Author Report Share Posted February 25, 2013 I was uncertain of the back plate wood so I decided to get another piece It's probably the heating that caused the diffuse readings, I will save it for later tests. Back plate (new) 1396 g < 6% MC Half 1. weight 719 g dencity 0,61 g/cm3 longitudinal celerity ~ 4644 Half 2. weight 677 g dencity 0,59 g/cm3 longitudinal celerity ~ 4610 Quote Link to post Share on other sites
Peter K-G Posted February 25, 2013 Author Report Share Posted February 25, 2013 Fresh from the owen, Medium rare; Top Half 1. 330 g -> 305 g; M5, 574 Hz -> 578 Hz Half 2. 405 g -> 379 g; M5, 695 Hz -> 701 Hz New back plate Wood Back Half 1. 719 g -> 684 g; M5, 514 Hz -> 518 Hz Half 2. 677 g -> 643 g; M5, 468 Hz -> 471 Hz I am very suprised that the M5 modes did not change more !!!! (M5 is wrong term for the mode as Don pointed out) Quote Link to post Share on other sites
Anders Buen Posted February 25, 2013 Report Share Posted February 25, 2013 Is that a common way to write velocity in Finland to use the word "celerity"? Quote Link to post Share on other sites
violins88 Posted February 25, 2013 Report Share Posted February 25, 2013 After a lot of posts and interesting discussions in: Body modes as violin sound equalizerand other topics, it is time for some action I visited a friend last night, who is professional violin maker and bought tone wood for two violins. Top - two halves MC < 6% (Meter showed 5 % in some places) Half 1. weight 330 g dencity 0,423 g/cm3 longitudinal celerity ~ 6036 (Don Noon way: Ridiculously easy way to measure speed of sound) Half 2. weight 405 g dencity 0,433 g/cm3 longitudinal celerity ~ 5928 TopNotes1.png TopNotes2.png Top _C_Measure.png For the first piece of spruce, the radiation ratio is 14.27 before putting in the oven. Don Noon can comment about whether this is high or low. Quote Link to post Share on other sites
Don Noon Posted February 25, 2013 Report Share Posted February 25, 2013 Fresh from the owen, Medium rare; I am very suprised that the M5 modes did not change more !!!! For an uncarved hunk of wood, it's not really M5, but the first free-free longitudinal bending mode. Picky huh. If the wood stiffness (modulus) and dimensions remained unchanged after the bake, then the taptone would vary with the square root of the mass, not directly. In addition, there is usually some structural stiffness loss, and (probably most influential) shrinkage of the thickness, all of which tend to keep the taptone low. For the first piece of spruce, the radiation ratio is 14.27 before putting in the oven. Don Noon can comment about whether this is high or low. It's a little on the low-ish side, if you like to look at radiation ratio numbers. But so what? That's about the same radiation ratio as my #8 fiddle, which placed quite high in the VMAAI tone competion. I also got some offcuts from the first-place tone violin, and that measured out at a radiation ratio of 13.5. For spruce at C=6000 m/s, that is about as high as I have seen so far. For maple, the highest I've measured was C=4500m/s, so 4900 is pretty stiff stuff. I have not explored high speed of sound wood yet (that will be my next one). Peter... as yet the title of the thread is sortof hanging there. Presumably you intend to try to match some Strad's signature modes with the violin you plan to build with this wood? Quote Link to post Share on other sites
Oded Kishony Posted February 26, 2013 Report Share Posted February 26, 2013 Matching the frequencies is nearly meaningless unless you can also match their relative amplitude. And, by the way, a spectrum chart is only a snapshot of a small percentage of what is going on in a violin. If you run a live FFT (continuous) you will see that mode frequencies and amplitudes are far from 'steady state' they shift with every nuance of every bow stroke. The peaks may rise and fall at different rates and the directionality, a very important constituent of sound quality, is not represented at all. That's not to say that spectrum output is meaningless, but IMHO it gets far more attention than necessary I've been thinking of looking at spectrum analysis much the same way as I look at photos of varnish. You can make a mediocre varnish look quite good to the innocent eye and a grand varnish can look very unimpressive in less than ideal lighting conditions. Oded Quote Link to post Share on other sites
Don Noon Posted February 26, 2013 Report Share Posted February 26, 2013 That's not to say that spectrum output is meaningless, but IMHO it gets far more attention than necessary The problem is that there aren't objective ways to measure tone that seem to be any better. And subjective opinions are, um, subject to opinion. I agree that signature mode frequencies mean very little without considering amplitude, and I'll also add my view that the signature modes and amplitudes are only a minor part of the picture. I still use impact spectra a lot, because it's quick and easy. However, I'm trying to look more into bowed response, as that is the real story, and there are some differences with the bowed vs. impact response. Quote Link to post Share on other sites
Oded Kishony Posted February 26, 2013 Report Share Posted February 26, 2013 The problem is that there aren't objective ways to measure tone that seem to be any better. And subjective opinions are, um, subject to opinion. I agree that signature mode frequencies mean very little without considering amplitude, and I'll also add my view that the signature modes and amplitudes are only a minor part of the picture. I still use impact spectra a lot, because it's quick and easy. However, I'm trying to look more into bowed response, as that is the real story, and there are some differences with the bowed vs. impact response. Yes, to someone with a hammer everything looks like a nail. That's why I get very skeptical with discussions that are too focused only on spectra without acknowledging (or possibly fully understanding) the limitations. Oded Quote Link to post Share on other sites
Peter K-G Posted February 26, 2013 Author Report Share Posted February 26, 2013 Is that a common way to write velocity in Finland to use the word "celerity"? No, it's from Patrick's book. I speak Swedish by the way, I'm not even good at the Finnish language. Quote Link to post Share on other sites
Peter K-G Posted February 26, 2013 Author Report Share Posted February 26, 2013 For an uncarved hunk of wood, it's not really M5, but the first free-free longitudinal bending mode. Picky huh. If the wood stiffness (modulus) and dimensions remained unchanged after the bake, then the taptone would vary with the square root of the mass, not directly. In addition, there is usually some structural stiffness loss, and (probably most influential) shrinkage of the thickness, all of which tend to keep the taptone low. It's a little on the low-ish side, if you like to look at radiation ratio numbers. But so what? That's about the same radiation ratio as my #8 fiddle, which placed quite high in the VMAAI tone competion. I also got some offcuts from the first-place tone violin, and that measured out at a radiation ratio of 13.5. For spruce at C=6000 m/s, that is about as high as I have seen so far. For maple, the highest I've measured was C=4500m/s, so 4900 is pretty stiff stuff. I have not explored high speed of sound wood yet (that will be my next one). Peter... as yet the title of the thread is sortof hanging there. Presumably you intend to try to match some Strad's signature modes with the violin you plan to build with this wood? Thanks Don, Yes I plan to match a Strad's signature modes. Does anyone know the Soil Stradivari's Quote Link to post Share on other sites
Peter K-G Posted February 26, 2013 Author Report Share Posted February 26, 2013 Matching the frequencies is nearly meaningless unless you can also match their relative amplitude. Exactly my point in Body modes as violin sound equalizer, so when we also know how to match their relative amplitude we might be pritty close ? Quote Link to post Share on other sites
Peter K-G Posted February 26, 2013 Author Report Share Posted February 26, 2013 And, by the way, a spectrum chart is only a snapshot of a small percentage of what is going on in a violin. If you run a live FFT (continuous) you will see that mode frequencies and amplitudes are far from 'steady state' they shift with every nuance of every bow stroke. The peaks may rise and fall at different rates and the directionality, a very important constituent of sound quality, is not represented at all. That's not to say that spectrum output is meaningless, but IMHO it gets far more attention than necessary I mostly run live FFT on an Ipad - Audiotools by Studio Six Digital. The only measurable way I know of is spectrum analyzes, but I agree that you can't know exactly how the violin sounds by looking at the spectrum. Maybe one could say that it's the violins KPI (Key Performance Indicatior) Quote Link to post Share on other sites
Oded Kishony Posted February 26, 2013 Report Share Posted February 26, 2013 Exactly my point in Body modes as violin sound equalizer, so when we also know how to match their relative amplitude we might be pritty close ? When the bow is drawn across the string the first few milliseconds produce transients this initial sound is critical, it is the sound that the ear/brain uses to identify the source. If you take the recording of a violin and remove the transients, the first few milliseconds of sound, most people cannot identify what it is. Is it a tuba, a fog horn, a trumpet? At the next point the resonances start to define themselves, but they don't all emerge simultaneously, some become louder than others more quickly. This will also affect the perception of the sound quality. Then following that some resonances may fluctuate. For a given resonance if it is supported by harmonics (in the musical sense octaves, 5ths 3rds etc) then those resonances will change their timbre depending on the harmonics and what key the piece of music you're playing! That's why in developing a program to analyze and understand violins it is important to know which resonances are harmonically supported and the musical notes associated with those harmonics see screenshot below In this early version of the analyzer I've been developing with my colleague Bob Hoffman. You can see the history of each resonance, the size of the dot indicates amplitude and each resonance is identified by frequency as well as musical note (on left) The other part of the analyzer allows for user defined spectrum band display and identifying the location of the sample taken on a violin (still under development) Oded Quote Link to post Share on other sites
Peter K-G Posted February 26, 2013 Author Report Share Posted February 26, 2013 Back plate 1345 g < 6% MC Half 1. weight 640 g dencity 0,612 g/cm3 longitudinal celerity ~ 4985 Error Reading !! C ~ 3800 Half 2. weight 704 g dencity 0,623 g/cm3 longitudinal celerity ~ 4980 Error Reading !! C ~ 3800 Probably not suitable for back plate Edited Quote Link to post Share on other sites
Peter K-G Posted February 26, 2013 Author Report Share Posted February 26, 2013 When the bow is drawn across the string the first few milliseconds produce transients this initial sound is critical, it is the sound that the ear/brain uses to identify the source. If you take the recording of a violin and remove the transients, the first few milliseconds of sound, most people cannot identify what it is. Is it a tuba, a fog horn, a trumpet? At the next point the resonances start to define themselves, but they don't all emerge simultaneously, some become louder than others more quickly. This will also affect the perception of the sound quality. Then following that some resonances may fluctuate. For a given resonance if it is supported by harmonics (in the musical sense octaves, 5ths 3rds etc) then those resonances will change their timbre depending on the harmonics and what key the piece of music you're playing! That's why in developing a program to analyze and understand violins it is important to know which resonances are harmonically supported and the musical notes associated with those harmonics see screenshot https://plus.google.com/photos/106576171087568832231/albums/5849228392557800033/5849230936716622162 (sorry can't upload image) In this early version of the analyzer I've been developing with my colleague Bob Hoffman. You can see the history of each resonance, the size of the dot indicates amplitude and each resonance is identified by frequency as well as musical note (on left) The other part of the analyzer allows for user defined spectrum band display and identifying the location of the sample taken on a violin https://plus.google.com/photos/106576171087568832231/albums/5849237221920652481/5849237235724550354 Oded Very interesting! I can't open the links though. Quote Link to post Share on other sites
Oded Kishony Posted February 26, 2013 Report Share Posted February 26, 2013 Very interesting! I can't open the links though. screen capture on right below.... In this early version of the analyzer I've been developing with my colleague Bob Hoffman. You can see the history of each resonance, the size of the dot indicates amplitude and each resonance is identified by frequency as well as musical note (on left) screen capture on left below... The other part of the analyzer allows for user defined spectrum band display and identifying the location of the sample taken on a violin Oded Quote Link to post Share on other sites
Peter K-G Posted February 26, 2013 Author Report Share Posted February 26, 2013 Cool software Oded. I'm in the software business myself, so I know what it takes to acheive this. Quote Link to post Share on other sites
Peter K-G Posted March 3, 2013 Author Report Share Posted March 3, 2013 Done with analyzing wood. Started carving scroll/neck today - forgot how HARD maple is! Quote Link to post Share on other sites
Peter K-G Posted March 9, 2013 Author Report Share Posted March 9, 2013 Busy week, not much time for violin making. Scroll and pegbox is beginning to take shape, scroll still too big but has the right shape. Hope I can finnish this weekend. Great thing is that I can allready hear how wounderful the violin is going to sound Here is the targets for my next Strad sounding violin: Violin5_Targets_09032013.pdf Quote Link to post Share on other sites
Don Noon Posted March 9, 2013 Report Share Posted March 9, 2013 and here's my target for my next Strad sounding violin: The plan is to copy the archings and grads very closely, and see what happens. (I might un-distort the archings a bit). Ex-Jackson Strad, by the way. Quote Link to post Share on other sites
Peter K-G Posted March 9, 2013 Author Report Share Posted March 9, 2013 Interesting, that's an unusually full/high arched top. I'm going for the exact opposite and make the arching as flat as possible. Quote Link to post Share on other sites
Peter K-G Posted March 9, 2013 Author Report Share Posted March 9, 2013 First target acheived, edges still need some finishing but i'm happy with the shape. Neck: Target 70 g --> now 71 g, will be ~68 g when finnished Quote Link to post Share on other sites
