H.R.Fisher Posted October 19, 2012 Report Share Posted October 19, 2012 What should the rib corner joint look like on a strad model,should the corner be sharp with the joint in the center,or blunt with upper and lower bout extending over the C bout,??? Thanks in advance for your response Henry Quote Link to post Share on other sites
arglebargle Posted October 19, 2012 Report Share Posted October 19, 2012 The second for me, but it depends on your working methods. If you do the middle bouts first, which is most common, then the shaping of the upper and lower corner curves will make the joint "under" the upper and lower ribs. Quote Link to post Share on other sites
Addie Posted October 19, 2012 Report Share Posted October 19, 2012 Gleaned from the web... from a book by some Italian guy... Quote Link to post Share on other sites
