Stephen Churchill Posted May 10, 2012 Report Posted May 10, 2012 Hi, I'm touching up a friends 1/8 Suzuki (1974) for his daughter. I'm just putting in a new soundpost. I've never put in a 1/8 before. Any suggestions? going from the bass f-hole instead of treble? should I get a smaller post setter? Thanks Stephen
Jeff White Posted May 10, 2012 Report Posted May 10, 2012 Use a spike kindof set up. I take a needle spring (blued spring used for keywork on saxophones) and grab it with a pair of pliers. I put a maple 1/4" dowel in a bench motor spinning. Take the blunt end of the needle spring (guess you could use a thick sewing needle??)and drive it with pressure (remember you are grabbing it with a pair of pliers)into the spinning dowel. Goes right in and works real nice in setting soundposts-especially ones with small f holes. jeff
duane88 Posted May 10, 2012 Report Posted May 10, 2012 I usually take a coat hanger (remember those?), cut a piece, hammer the end out flat to stab the post and bend it to a shape that works for the size of the small fiddle. I tend to mis-place these, or even simply lose them, and seem to have to make another with every batch of small fiddles.
Jeff White Posted May 10, 2012 Report Posted May 10, 2012 How do you smash the plastic without it breaking!!! :lol:
Kevin Miller Posted May 10, 2012 Report Posted May 10, 2012 If you think you might ever do another small soundpost, a smaller setter is a good tool to have. I used to use the fractional size Herdim Duo. It works very well, and isn't all that expensive.
jacobsaunders Posted May 10, 2012 Report Posted May 10, 2012 I bought myself a second normal soundpost setter from GEWA and bent and shortend it to work for small violins. After all, it won`t be your last 1/8 soundpost, will it?
