      Whole Site SSL   03/08/17
Alicia3
Old interesting lion head Baroque? Violin ID help
49 posts in this topic
I have been looking for a reasonably priced baroque instrument (or even a new one with baroque set up) just for my own use since I enjoy the sound. I took a (safe) gamble on a super poorly listed one on eBay and am now wondering what it is that I got. I honestly thought the listing might be a scam since it was a seller with 0 feedback and there were only a couple blurry pictures from far away, of only the front. All the listing said was “18th c baroque Hopf violin, ready for baroque play.” Where they got the Hopf part ,I have no idea. Anyway, I was super excited when a violin actually showed up!
I have been searching online for similar looking instruments and cannot find any. I would just like to get a rough time period, place of origin, or what it is modeled after, if anything. I will take it somewhere to be looked at as long as it is for sure not a piece of junk. It is completely unlabeled or marked. And is very uneven, there is about a 10mm difference, the base side being higher. It is visible in the pictures.
The lion head scroll is creepy and has remnants of red paint coming from it’s ears, eyes and mouth. The one red eye is slightly disturbing. It seems to have the original, or at least a really old, fingerboard but I am unsure about the neck since the peg holes do not seem to be bushed or repaired. Although it is possible that some work has been done since it seems to have been re-varnished around the pegs.
The violin has a long appearance, but I think it is just slightly narrower than average. The arching is also quite thin, the whole body is very warped but is only roughly about 1.75” or 40mm thick. The ribs measure at 30mm. The neck is pretty thick, and has a low angle but seems to be almost modern length (only slightly shorter).
Measurements:
LOB: 360mm
UB: 160mm
CB: 104mm
LB: 200mm
The construction is a little weird, and uneven. It seems like someone made it freehand. There are no corner blocks at all, just what looks like a lot of old crackled resin or maybe amber looking varnish in them. There is something that looks like lining but I think that the ribs might possibly just be carved thicker on the ends (to give it some surface area to glue?). It is hard to tell since it is very dark inside, and whoever put it together used a lot of glue. The base bar is not carved in from what I can see, and appears to be much newer than the rest of the violin as is the sound post.
There are also tons of cracks on the front, but I think they are all somewhat repaired. None are loose at least. Everything seems stable and solid. The violin overall is very light weight. I noticed even the neck is carved out when I look under the fingerboard. The perfling is nice looking, and I think well done. It also is continuous everywhere, even under the fingerboard.
The strange features are the 2 or possibly 3 small holes in the top faceplate under the fingerboard. And one under the tailpiece. The Fingerboard itself has 2 round ruts cut out of the bottom of it which used to hold dowels it seems since one is partially there still. There are also 2 weird round carved circles symmetrically on each side of the top plate on the lower bout.
The whole thing is unique, and a little odd but I love it. The sound is beautiful, and it is fun and easy to play. I love it’s character and the varnish, even though it is pretty beat up the violin really seems to glow. I think it is original varnish (except on the scroll).
Sorry for writing so much, I am just very curious about it and excited and wanted to share it with someone. I don’t know anyone in real life who shares my passion for instruments! Thanks!
Alicia
Here is the link to my whole album of pictures if anyone is interested in seeing more: additional pictures
I'd say 19th century Saxon. Many violins of this type have a "Hopf" stamp or label, but they are all early trade instruments, so a makers name doesnt mean much. You see a lot of these instruments set up as "Baroque" these days, but the instrument is pretty much set up as it was built. Still a good way to cheaply get into a "period" instrument. Looks like the varnish has issues. Cool instrument to play if you like the sound, but I dont think it has a lot of value, I'd say its worth what enjoyment you get out of it, which could be a lot.
Certainly not baroque. Looks like a German (Saxon) trade fiddle ca 1880 - 1915 that has been stripped and refinished. The fingerboard used to be painted black. The "lions head" looks like it was spindle carved, and is in the pattern of thousands of similar fiddles from that time. Don't know what to say about the body, or various pins and holes. Looks like it has a "through neck" with integral block, which was a feature of some Saxon violins.
i basically agree with deans, but the lack of value has more to do with the ugly cracks on the top, than the instrument being deficient, per se, i would price it based on the enjoyment you get out of playing and its tone, minus the embarrassment factor of being seen with it in public, its not a 1700s baroque instrument, its an 1800s transition instrument of a type that was made from roughly 1800-1880,
in perfect condition an instrument like this might have an insurance or full retail value of up to 2000-3000usd i would guess. this type of instrument is proof positive that cheap "shoddy" construction does not always mean bad sound, just as expensive careful construction does not always mean good sound. a lot of an instruments sound has to do with the tonal qualities of the wood used, ive worked on baroque setups for several instruments like this and have never been dissapointed by the sound, at least for the price.
by the way if you want this instrument to be authentic, and ever have it repaired with the top off, trim the new bass bar back to transitional dimensions, with the lower tension of the reduced neck angle this should work fine,
nonado, from what ive been told this type of through neck instrument stopped being made around 1880, after that a cheap violin like this would have a standard modern neck, youre right the top looks revarnished or heavily mucked with but the varnish on the back looks completely original(with perhaps a new surface coat) look at the wear spots in the middle where the varnish is missing, you dont get those with a revarnish
If the Bassbar and soundpost is new(ish) then perhaps someone has replaced or thinned the originals to get it nearer to 'Baroque'.
as far as i know baroque violins arent any thinner than any other period, if anything a lot of modern violins are being made thinner than baroque, because the're copying regraduated violins, not unaltered originals,
There is probably a 98% chance that this violin originally had a carved in bass bar, which probably didnt resemble any good fitted bass bar, either baroque or modern. Its possible that somebody removed this and glued in a bass bar, but I suspect though that the original 19th century Saxon "bar" is still there.
I was under the impression that Baroque Bassbars were thinner. . . or perhaps shorter? Soundposts thinner?
michael, sorry, i mistook you, i thought you were saying the violin might be thinned when you were talking about the bassbar, we have the OPs statement that the bass bar looks newer and more modern, which isnt really good if you want baroque or transitional, but its easily fixed if you have the top off,
baroque bassbars were all over the place, both thickness and width-height wise, almost always shorter, but sometimes really short ones were thicker and heavier in the middle, usually they werent as tall, but i wouldnt say they are usually thinner, as ive seen ones just as thick or thicker than modern,
theres nothing at all defective about using a carved in bass bar, as long as its in the right position, the crudeness or polish of its carving isnt going to make much difference to the tone, and structurally a carved in bass bar has a major advantage; it will never come unglued and start buzzing
That makes sense, thanks for all the quick replies. I still enjoy it, and personally think it looks neat. And got it cheaper than I could find any brand new baroque already set up violin so I am happy with this regardless. Now I just have to figure out how to play something on it!
I have this exact violin. Same wood, same copy (not sure copy of what yet, maybe a Klotz?), same varnish, even the maple on the back is exactly the same. That swirl in the top is matched by my own. My neck was replaced (very badly) and the violin was set up to be "modernized" in the 1920's, (the fine tuner has a patent pending mark on it).
The neck on yours is baroque style, definitely.
My bass bar is original though, so is the sound post.
My bass bar, when you look at it straight on is in the shape of a 'V' and is thin and there is no arching.
There are no corner blocks, but if that is a feature that was left out, it was done with purpose (there are master makers who left them out), they didn't cut corners on this instrument where most German factory shops would make elsewhere; Such as the purfling. Those bee stings are pretty, esp. on the back.
Also, the ribbing is quality work, and the smoothness of the wood on the interior is master work. I'm not convinced that it was German though. Mostly because of the arching and varnish. Mine sat in an attic for almost 100 years, there were two dirt bunnies living inside! It's pretty old that's for sure. We have the same maker, I'm positive of that. It'd be nice to know what this is a copy of at least.
http://i1045.photobucket.com/albums/b458/Maestrojobo1/2015-06-29%2020.24.29_zps6j0jivmk.jpg
I don't really see the similarity in style between the two violins. The OP's violin is a Hopf-style instrument, yours isn't. As far as the purfling and beestings go, it would be a red herring to believe that mass-produced Saxon violins have rough or inferior purfling.
Don't think "factory shops", think "cottage industry" where and outline is the basis of construction, not a mold, made it possible to mass-produce interchangable parts of instruments.
The original (?) pegs and the Baroque-style saddle on your violin would suggest a date close to 1800.
On the OP's violin, there is no mortise in the top - the plate edge continues uninterrupted past the neck root "step". What does your's look like?
Calling Jacob Saunders...are you there?
My pictures are terrible! I'm not even kidding. When I look at hers I thought I was looking at the same back piece. Thank you for the input.
Today I found faint writing inside, very very faint O.o, so faint I had to get my camera out. (imagine my excitement)
I barely made out 1783 written inside in the middle in faint ink in a falling script where the 1 is highest and the 5 is the lowest, plus some other writing that I can't make out at all.
I found an instrument similar to mine, I can't find any other images of this maker's instruments but the ff holes are the dead give away here, I haven't found a maker that have such long ff's yet and such a large hole at the bottom of the tail. She was made in Passau Germany by a Simon Schodler. Any thoughts on that?
http://www.netinstruments.com/violins/violin/simon-schodler-violin-1780/image/30907.jpg/
http://www.amati.com/maker/information-on-schodler-simon--violin-maker-in-passau-germany.html
I initially thought that it was a J.B. Schweitzer btw, but the ff holes just didn't match.
UPDATE: Above the 1783 is handwritten Simon Schodler as well, I'm 100% sure of it. Now is it an original and not a copy...that's the next step I suppose.
Mine looks the same.
I would imagine that Maestrojobo has a fairly grotty mid 19th C Klingenthal violin, whereas the (seemingly re-varished) OP one seems more probably to be from the Salzkammergut, where these black painted Maple fingerboards were standard. The Salzkammergut violins, as a rule started life without any purfeling, which might be a clue to solving any mystery there. Both Salzkammergut and Klingenthal used the “Built on back with through neck” routine, so one can easily get them mixed up. I certainly agree that the two makers were certainly not related, just as I am not even the ten millionth in line to the Throne!
The OP's fingerboard looks like American sycamore or a lacewood.  So you're sure it's a Schodler and not a Schonger.
I'm really interested in your spelling of purfeling Jacob. I've always spelled it purfling. I'm not English, and I wonder if, in the trade, the English makers used your spelling, which of course would be the correct spelling?
After 30 years in Austria, my English spelling is a bit rusty. Don’t know if I trust Irish spelling though :rolleyes:
Choose your ainmfhocal dar críochSomething like perfelaigh, perfeleachd, perfeleachaigh, or, you know, purfling...  :P
Beech.
Well since it's written inside, Simon Schodler in my instrument, my next question is: Is Mittenwald or Klingenthal known to make copies of S.Shodler violins rather than Amati, Strad, or Guar? Because as far as I can tell, the Schodler model is unique unto itself.
I don't get it, how you can see any kind of affinty between your fiddle and the" Schodler".
(if the instrument you linked is a genuine Schodler at all, it's just another "labelled as...")
Wishful thinking might be the only option here ;) .
Reg. Schodler, about whom I can't say that I'm really familiar with, I would expect something related to Mittenwald or Vienna, what is more likely to see here
http://www.brobstviolins.com/view/instr/a309.htm (Hi, BassClef ;) ),
but very different to both of the violins you presented.
First rule: Never trust anything what is written inside or outside a violin, or what you believe is written.
Regaeding Schödler, in Passau:
I have a viola in bits in my store room from Schödler, which you would be welcome to examine, should you ever visit, where I am afraid that I can't quite read the faded date. Passau is in Bavaria (just), where the Inn joins the Danube, but Austria is more or less within spiting distance. Schödler's work is firmly in the 18th C Bavarian/Austrian tradition, which one sees all along the Danube at that period.
This thread is becoming a bit confusing regarding which violin anybody is refering to, but the one linked to in post #11, which I refered to in post #17 as a fairly grotty mid 19th C Klingenthal violin, isn't a copy of anything, rather a typical example of budget work from there in it's local tradition, even should some joker have writen “Schödler” in it.
