fernandocontra Posted November 30, 2011 Report Posted November 30, 2011 Hello, I´m trying the violins I made in Newark and I have a problem with number one. It is a strad model, 16mm high top, on the he thin side. It has a nice tone but not carriying. The sound does not travel mostly on the high register. I tried moving the sound post a little loose and it is getting better but not enough I think. I know it is the first one but, any advices?? Many thanks
Oded Kishony Posted November 30, 2011 Report Posted November 30, 2011 what kind of strings and tailpiece do you have on the fiddle? Some more details would be useful. However a high arch thin top often does not project very well. Oded
fernandocontra Posted November 30, 2011 Author Report Posted November 30, 2011 The strings are Dominant medium, the tailpiece is french model in ebony. String lenght 329, afterlenght 55, bridge is 33 high.
Doug Marples Posted November 30, 2011 Report Posted November 30, 2011 Perhaps fitting a sound post a little more in the treble direction (perhaps nearly even with the edge of the bridge foot), a bit closer to the bridge foot than usual, and/or a little tighter may help. There's going to be an element of trial and error, but that's where I'd start. Good luck. Doug
fernandocontra Posted December 1, 2011 Author Report Posted December 1, 2011 Thanks. I tried the same sound post tighter but it muted the highs. I will try a shorter one then. What about the bridge or string angle, do you think could improve proyection?? Fer.
Nicolas Temino Posted December 1, 2011 Report Posted December 1, 2011 Have you tried a thinner bridge?
Fellow Posted December 1, 2011 Report Posted December 1, 2011 Hello, I´m trying the violins I made in Newark and I have a problem with number one. It is a strad model, 16mm high top, on the he thin side. It has a nice tone but not carriying. The sound does not travel mostly on the high register. I tried moving the sound post a little loose and it is getting better but not enough I think. I know it is the first one but, any advices?? Many thanks ++++++++++++++++++++ Did you test how far the sound travel for knowing that it does not trval far enough? You need at least two persons, one plays and one listens at some distance. You need to have two violins to compare. For that reason, I have never had tests of my violins. I have head some expensive violins were played, and I did not hear any difference. They always say I have hearing problem. Most violins I know have some carrying power. Small percentage of those are very loud to the pount becomes disgusting. I do not like to play next to that guy or that gal.
kdj Posted December 1, 2011 Report Posted December 1, 2011 Under the ear volume and carrying power have an inverse relationship. But I would think the violin needs some vigorous playing before the high notes open up.
Doug Marples Posted December 1, 2011 Report Posted December 1, 2011 Bridge height is limited by what is reasonable in terms of string height over the end of the fingerboard (unless you want to reset the neck). A lower saddle can increase the angle slightly if you've got enough tailpiece clearance. Thinning the crown of the bridge (the portion under the strings) can brighten the sound. There are other factors that could produce a dark toned instrument independent of setup, such as excess internal air volume (ribs too high for instance). You can also brighten the instrument by changing string types. Evah Pirazzi's seem particularly bright to me. Doug
fernandocontra Posted December 1, 2011 Author Report Posted December 1, 2011 we tried the instrument in the rehearsal room, which is big enough for 1100 people. quite big. There was other violin for reference (mine too but much powefull). The text was quite reliable I think. Doug, related to the saddle, they talk here about a 157-158 angle but you can really have less than 157 quite easy even with a normal high saddle. That is confuse to me since in the Newark school they advise us to lower the saddle the most to increase load in the top, obviously the angle was always smaller than 157. Thanks
David Burgess Posted December 1, 2011 Report Posted December 1, 2011 Under the ear volume and carrying power have an inverse relationship. I highly doubt that, though I'll agree that one is not always indicative of the other.
