James Ansara
Toothed plane blade
At the risk of ruining a blade for my Stanley block plane. Iam considering filing grooves in the leading edge (of blade) to make it "toothed".I imagine I will also wreck a triangle file as well.While looking at M.Darnton's website it appeared to me that this is what he did to plane ribstock.Any suggestions or cautions would be welcomed.Thanks,James.
I seem to remember something about a Dremel and a cutting wheel, but it's been a while and I may be wrong about that.
In any case if you go that route, don't even think about doing anything without adequate eye protection.
I seem to remember something about a Dremel and a cutting wheel...
Yes, Michael said that he cut teeth in his plane blades with a cutting wheel mounted in a Dremel.
robertdo
I did that with one of my plane using a dremel and Diamond wheel. they will cut like butter the steel of your blade. I couldn't even dent it with a normal saw.
But I also bought some toothed blades for the thumb planes I have and they are definitely much better and not that expensive. It much easier to thin the ribs with them.
you can buy toothed blades for most stanley block planes from Ray Iles: http://www.oldtools.free-online.co.uk/
MikeC
I doubt you would be able to cut a plane blade with a triangle file. It would probably just skate off without even making much of a scratch.
I have used a triangle file to make a few toothed blades. The notch was a little on the slow side to start, but cut quickly. I also used "cutting fluid" on the file. The file looks ok afterwards.
Then I resharpened the plane's blade. The Dremel sounds like a great idea though.
I find the toothed blades made planing the maple ribs super easy.
Janito
it's quite a good exercise in "planemanship" to learn how to set up your plane well enough that you don't need a toothed blade for rib stock!
Sometimes it's easier to do what some of the Masters did - fit for purpose idea.
However you create the teeth, you'll want to do it slowly without creating much heat, otherwise you'll lose the temper in the blade.
Thanks again everyone.I feel my "planemanship" is good,having many years exp. as a cabinet maker (I've only made three violins and four guitars).When I got toothed blades for my finger planes they allowed me more freedom in maple.I like having the option of toothed and straight blades though and I will try the drill press Dremel cut-off wheel set-up in the link Newbie posted.Of course in the shop:"saftey first,and second."Has anyone experienced a dust collector fire when someone used the belt sander to sharpen a scraper? Take care, James.
If you do use the drill press method, which, while tedious, should work fine, PLEASE feed the blade from the other direction so that it doesn't become a lethal projectile.
I made a jig for a Dremel using a flexible shaft that is very easy to use and adjust, but I've only used it on small planes. Most of the time I have not found the toothed blades to be much advantage, but they do help on some pieces of maple.
What I think would be more useful is something I saw on the Woodwright's Shop. A couple of guys doing old fashioned hand veneering used a toothed SCRAPER plane with nice results. I have stooped to using one of my small toothed blades as a scraper on impossible grain. It was the only thing that worked short of sandpaper. I may try making a finger-size scraper plane.
Great memory!
Was it this??????
No, but thanks Newb, great link.
After I posted about what I remembered, I got caught up (as usual) mentally designing a jig to cut such a blade...
What he shows here looks like it would work well - not that I would ever make one, if a toothed plane blade wasn't available I think I'd just do without (I'm just too d@mned lazy...)
Luckily, I have commercial toothed plane blades for all of my thumb planes.
Galen
I've made toothed irons for each of my block and smoother planes using a Dremel tool and "cut-off" discs... Pick up basic replacement or used irons and give them a sharpening (square the edge, flatten the bottom side, and apply the basic sharpening angle)... Use your MM rule and a fine-point Sharpie pen to "lay out" the teeth on the edge of the iron... Place the iron in a vise on the flat, and carefully cut the teeth, then "scary" sharpen and hone...
An alternative, based on what a well known maker does, is to make the blade super sharp. If you have a blade holder to keep the angle, start with 15 micron silicon carbide mylar backed on glass, then 5 micron at a one degree larger angle, then 3 micron.
John
