scordatura Posted June 30, 2011 Report Share Posted June 30, 2011 What type of wood do you use for bow blocks and spreader wedges when rehairing? Quote Link to comment Share on other sites More sharing options...
Brad Dorsey Posted June 30, 2011 Report Share Posted June 30, 2011 For 20 years I used soft maple (red maple) for plugs. I just switched to poplar. In theory, poplar (or basswood) might be safer because, being softer than maple, it would compress rather than exerting too much force on a bow head if the fit were too tight. Arnold Bone used striped maple, and I was told that the Wurlitzer shop used willow. I use basswood for spreader wedges. I found it amusing that when I started re-hairing I went out in the woods and cut down a whole basswood tree because I needed little pieces of wood from it smaller than my fingernail. Quote Link to comment Share on other sites More sharing options...
scordatura Posted June 30, 2011 Author Report Share Posted June 30, 2011 I have used various woods for the blocks and always basswood for the spreader wedge. I am thinking of going softer for the blocks (poplar or basswood). Funny story about the basswood tree. These days a bit "non green" though. Quote Link to comment Share on other sites More sharing options...
DonLeister Posted July 1, 2011 Report Share Posted July 1, 2011 Basswood for spreader wedges and currently european maple for the blocks, it's a little harder than poplar and a little softer than soft maple. I have all these scrap bits of maple from making violins, of which a lot is curly and not too good for making blocks but the plain stuff is good. Quote Link to comment Share on other sites More sharing options...
Josh Henry Posted July 1, 2011 Report Share Posted July 1, 2011 I've always resorted to maple for the head and frog plugs, and basswood for the spread wedge. My favorite maple for plugs is plain, unfigured, straight-grained quarter-sawn maple (cut so that the grain is vertical in the plug). Over the years, I've tried different woods for the plugs including birch, hard (Michigan) rock maple, mahogany, cherry, willow, and some other woods, but always return to a medium-hardness maple. I'm not afraid to use a harder wood for the plugs because I believe that if the plug fits properly, it can be extremely hard without causing damage to the bow. Damage (mostly to the head of a bow) occurs primarily when a plug is "squash-fit" into the mortises. Unfortunately, I see this fairly often from a local shop that uses oversize plugs from a soft wood that are pressed in with more pressure than is necessary--often cracking the tip plate, but occasionally cracking the pernambuco on the side or back of the head. For spread wedges, in addition to basswood, I have tried other woods like willow, poplar, cherry, mahogany, pine, cedar, and on one desperate occasion--balsawood (way too soft). The spread wedge does need to be a softer wood that is compressable. The whole purpose of the spread wedge is to hold the hair into a wide ribbon in the ferrule, so by design, the wood used for the wedge must be able to tolerate some compression (without too much pressure needed to insert it). Harder woods (like maple) are not so compressible, and if used for the wedge, tend to allow the hairs to pull towards the center of the ferrule over time. Quote Link to comment Share on other sites More sharing options...
Skywalker Posted July 4, 2011 Report Share Posted July 4, 2011 Maple for the head and frog blocks. Philippine mahogany for the spread wedge. Quote Link to comment Share on other sites More sharing options...
lousyplayer Posted October 2, 2018 Report Share Posted October 2, 2018 Hi all this thread is old but i try not to open a new thread just checking if someone has any suggestion where i can purchase these woods online with reasonable price of course ?? Thanks first. Quote Link to comment Share on other sites More sharing options...
