jezzupe Posted June 22, 2010 Report Share Posted June 22, 2010 Well here it is, it is made of: Jatoba back. ribs, tail, fingerboard and bridge, as well as a Maple/Jatoba neck. The top is Redwood. Poplar purfling, Rosewood pegs and endpin I appreciate the input,but, I will not be using these holes again. They do not comprimise the arch in a way that I like. The violin sounds good, but not as good as my F/A holes. Partially due to the shape not comprimising the top as stated, but also the location of the lower holes. The location is very close to where "normal" holes fall. I feel this to be in the wrong spot or not as optimal as possible. The "headstock" was elongated a little longer than what was pictured, this is done to aid in "under chin" tuning. If the top of the stock is too close to the A peg, it does not give ones hand anything to levrage against while trying to turn the peg. And I did make a hole on the head stock for easy hanging. It is a small diamond as suggested, just not inlayed. Well if any one else has any suggestion, and or wonders what any particlar idea they have may or may not do, or look like, let me know. As you know I enjoy it. A special thanks to Iburkard for the ideas Quote Link to post Share on other sites
COB3 Posted June 22, 2010 Report Share Posted June 22, 2010 Not that my opinion is worth anything much; but I think I find this instrument more attractive than most of the others I have seen of yours. Some of that has got to be the less aggressive headstock. It seems to fit the rest of the fiddle better. Some may be the increased gracefulness of the "J" holes...but if they don't work, they don't work. I wonder if you could extend the "serif" on the "J", inward (toward the center) on each side so that it would compromise the top more in the fashion of the traditional holes? All-in-all, a pretty instrument... hope you can work the bugs out to your satisfaction. Come to think of it, sometimes a perfectly competent craftsman, making completely traditional instruments still produces a dud...for no obvious reason. Chet Quote Link to post Share on other sites
jezzupe Posted June 23, 2010 Author Report Share Posted June 23, 2010 Not that my opinion is worth anything much; but I think I find this instrument more attractive than most of the others I have seen of yours. Some of that has got to be the less aggressive headstock. It seems to fit the rest of the fiddle better. Some may be the increased gracefulness of the "J" holes...but if they don't work, they don't work. I wonder if you could extend the "serif" on the "J", inward (toward the center) on each side so that it would compromise the top more in the fashion of the traditional holes?All-in-all, a pretty instrument... hope you can work the bugs out to your satisfaction. Come to think of it, sometimes a perfectly competent craftsman, making completely traditional instruments still produces a dud...for no obvious reason. Chet Hey Chet, thanks, I value your opinion highly. Thank you for the compliment. Actually its really not that bad, its just the G and D are a little thinner than what like. It actually sounds pretty good. The highs are great, its the open G that I find the weak spot. I'll try to put some samples up soon. It could be as simple as changing out the G to a heavy gauge. Quote Link to post Share on other sites
iburkard Posted June 23, 2010 Report Share Posted June 23, 2010 I have to agree that the workmanship is getting sweeter every time. The outline and purfling is really nice. I like the J holes and the new scroll as well! All of the curves seem to be working together. Maybe I will make a 3D model of more headstocks? Quote Link to post Share on other sites
Janito Posted June 23, 2010 Report Share Posted June 23, 2010 Chinois, but not cheap. (Just make the head a little smaller and the waist a little wider - to go with the metrics of the rest of the population). Quote Link to post Share on other sites
jezzupe Posted June 23, 2010 Author Report Share Posted June 23, 2010 Ya, I think thats what Chet is seeing, I'm just getting better the more I do it, like most people at most things. But don't you worry, its just 44 file swipes away from becoming a mini battle ax Quote Link to post Share on other sites
jezzupe Posted June 23, 2010 Author Report Share Posted June 23, 2010 Chinois, but not cheap.(Just make the head a little smaller and the waist a little wider - to go with the metrics of the rest of the population). Dockers, all the way Quote Link to post Share on other sites
Janito Posted June 23, 2010 Report Share Posted June 23, 2010 One thought regarding the sound...consider turning the top notch inwards so that the points are approx 42mm apart and consider making F hole a little longer. Just imagine you are GdG playing with F hole shapes. Quote Link to post Share on other sites
jezzupe Posted June 23, 2010 Author Report Share Posted June 23, 2010 One thought regarding the sound...consider turning the top notch inwards so that the points are approx 42mm apart and consider making F hole a little longer.Just imagine you are GdG playing with F hole shapes. 42 mm apart? what? that would require using a measuring device of some sort. We have rules around here you know. The wood is my minion Quote Link to post Share on other sites
iburkard Posted June 23, 2010 Report Share Posted June 23, 2010 I terms of design/rhythm alone, I wouldn't add the second serif/nick going toward the center of the plate. Quote Link to post Share on other sites
jezzupe Posted June 23, 2010 Author Report Share Posted June 23, 2010 I terms of design/rhythm alone, I wouldn't add the second serif/nick going toward the center of the plate. pic? link? Quote Link to post Share on other sites
David Burgess Posted June 23, 2010 Report Share Posted June 23, 2010 Not that my opinion is worth anything much;Chet Chet put up some good stuff, worth looking into. Quote Link to post Share on other sites
jezzupe Posted June 23, 2010 Author Report Share Posted June 23, 2010 Hey Chet, thanks, I value your opinion highly. Thank you for the compliment. Actually its really not that bad, its just the G and D are a little thinner than what like. It actually sounds pretty good. The highs are great, its the open G that I find the weak spot. I'll try to put some samples up soon. It could be as simple as changing out the G to a heavy gauge. yes, more head stocks, please, I want more sir Quote Link to post Share on other sites
jezzupe Posted June 23, 2010 Author Report Share Posted June 23, 2010 Chet put up some good stuff, worth looking into. Well whats your opinion? everyones got one. Quote Link to post Share on other sites
David Burgess Posted June 23, 2010 Report Share Posted June 23, 2010 Well whats your opinion? everyones got one. Opinions tend to be limiting. I'll try to put up broader food for thought. Quote Link to post Share on other sites
jezzupe Posted June 23, 2010 Author Report Share Posted June 23, 2010 Opinions tend to be limiting. I'll try to put up broader food for thought. Ah yes, limited, well I would not want you to limit or confine yourself, in the traditional sence of the meaning, or otherwise. "We" { I and the others} always appreciate your illumination and ability to cast light where it does not traditionaly shine. Quote Link to post Share on other sites
David Burgess Posted June 23, 2010 Report Share Posted June 23, 2010 Ah yes, limited, well I would not want you to limit or confine yourself, in the traditional sence of the meaning, or otherwise. "We" { I and the others} always appreciate your illumination and ability to cast light where it does not traditionaly shine. Ah yes, well, uh, Quote Link to post Share on other sites
COB3 Posted June 23, 2010 Report Share Posted June 23, 2010 Well whats your opinion? everyones got one. Just a thought... Quote Link to post Share on other sites
jezzupe Posted June 23, 2010 Author Report Share Posted June 23, 2010 Ah yes, well, uh, David, your losing your flair for the subliminal Quote Link to post Share on other sites
jezzupe Posted June 23, 2010 Author Report Share Posted June 23, 2010 Just a thought... I like it, maybe a wee thinner, but its worth consideration. Really, if yoor a good "photoshpper" I welcome any and all suggestions.... No, David not that. Quote Link to post Share on other sites
David Burgess Posted June 23, 2010 Report Share Posted June 23, 2010 David, your losing your flair for the subliminal Naw. Lessons semi-discovered are often more powerful than lessons forcefully injected by enema. Was that subliminal, subtle, or what? Quote Link to post Share on other sites
jezzupe Posted June 23, 2010 Author Report Share Posted June 23, 2010 Naw. Lessons semi-discovered are often more powerful than lessons forcefully injected by enema.Was that subliminal, subtle, or what? Hmm, I'll have to sit on that one for awhile, let it absorb Quote Link to post Share on other sites
David Burgess Posted June 23, 2010 Report Share Posted June 23, 2010 Hmm, I'll have to sit on that one for awhile, let it absorb Hey, thanks for hangin' in there with a sense of humor. Quote Link to post Share on other sites
COB3 Posted June 23, 2010 Report Share Posted June 23, 2010 I didn't have photoshop--just MS Paint--so it's kinda crude. Quote Link to post Share on other sites
jezzupe Posted June 23, 2010 Author Report Share Posted June 23, 2010 Hey, thanks for hangin' in there with a sense of humor. My chad can hang with the best of em' Quote Link to post Share on other sites
