Stradivari's golden ground varnish
9 hours ago, Peter K-G said:
Never mind the varnish (wich  is impossible to see from images). look at the purfling work, unbelievably perfection! I have looked at some Amati images lately and they(Strad & dG) should have slowed down a little.
Yes, the color of the images can be very misleading. This is a shot of the Andrea Amati, taken freehand by me in the darkness of the Museum lighting behind the glass of the showcase. Just to show how much color can vary in different images.
The Amatis remain unsurpassed as a workmanship.
  • Replies 242
10 hours ago, WalterOB said:
Wow! What a resource, with only 250 views!
For those with less time, skip to the 55 minute mark.  General summary is lower stratum is protein based without evidence of a mineral pore filler.
It seems to me that he clearly says that the lower stratum is just oil, isn't it?
Assuming it is oil... is it stand oil, runny oil, or something between them, or super-standy oil, or stand oil with a volatile thinner that evaporated?  Seems to me that unless you know ALL of the details of the material AND application methods, you can get a huge range of results with "oil".  (and to be annoyingly redundant, even if you did know all of that, what you get off-the-bench is I don't think will be all that similar to what it will be in 300 years or so.)
This is a stunning photo, thanks for sharing. I've had the good fortune of seeing half a dozen or so Andrea Amati's - I'm convinced the ground (a form of gesso perhaps?) applied below the varnish to support the painted layer contributes to the unique and (stunning) appearance of the varnish. There really isn't anything else like these!
We do know some detail regarding the oil but I agree.  I also suspect that things can and do happen much more quickly than 300 years.
Re it being oil, Echard has said that this is what he was able to detect.  (An obvious statement but one he has said needs to be acknowledged.)  He seems open to the possibility that other things could be involved that, for various reasons (e.g., masking, production and ageing effects, limitations of analytical techniques etc.,), are currently unable to be detected.
After listening to Echard's lecture, I reread the work of Barlow and Woodhouse.  Their Stradivari sample with the particulate layer has no date--in other words, they do not know what instrument it came from.  Maybe the early Strad instruments used a particulate ground and Strad moved away from it.  I was thinking there was a connection between Amati and Strad, and thus, the Amati instruments might show this particulate ground.
Barlow and Woodhouse did examine a Nicolaus Amata of approximately 1660, and they found no particulate layer.  But the varnish did not penetrate the wood, either, causing them to suggest that some type of sealer was used.  So, no particulate connection with Amati.
I have no problem with using gesso as a ground, but it would leave clear evidence of a particulate layer.
So, we are left with more confusion, but we now have many methods of sealing the wood, and sealing is the important point.  I hope Echard directs some attention to Amati instruments.
regards
Mike D
This type of picture is so much better than the other one,  Thank you!  Saved it in my violin folder!
This thread creates a lot of noise by suggesting that there is a canonical Cremonese varnish system. I have said innumerable times that the old varnish system is a moving target even within Cremona. If you agree, then you should not be comparing different makers’ instruments. Nor should you be comparing a maker’s early instruments to later ones, if you are trying to determine a system. You will go nuts doing that. So, I focus only on the Strad Golden Period and might even see within these some variations.
Next, as for the issue of aging which is a real one, I see that when the top color varnish is worn away, the aging process accelerates probably from UV and oxygen. The process accelerates even faster when the ground is exposed. However, a lot of what we attribute to aging is not just chemical but really mechanical wear and tear. The Messiah is a case in point because it has retained its protective top coatings.
BTW, if my version of the golden yellow ground is not properly made, it is fugitive and can change to chestnut brown which can be very pleasing. I think I see this effect on later Strad’s. The stable  version is my target.
Now, I want to make a plea for the sake of science. Brandmair must be convinced to publish her section of B&G in an inexpensive digital file. If anyone can influence her, please contact her and make this case. I am tired of reading ideas that are not aware of her great work. Her book is beyond the finances of most makers.
12 hours ago, Advocatus Diaboli said:
Crappy iPhone4 photos, but here are some shots of other A Amati instruments.
Still,  very useful photos.  In fact, I like them.
Keep in mind that a good camera is a necessity just like any tool. The newer iPhones take magical photos, so they are worth the expense.
Does "Strad Golden Period" refer to the time period Stradivari started making golden color grounds or does it refer to the time period when Stradivari finally made some good violins?
it sounds like you have had the opportunity to study a great number of Cremonese instruments. Out of interest, how many of the instruments featured in the B&G book have you seen in real life?
These are from several years ago.  Normally I take photos with a decent camera.
I think it refers to the period when everyone wanted a red one.
So it should be "Strad Red Period"
Maybe "Golden Period" is more catchy?
I happen to be re-reading the Hill's book right now.  They qoute Hart as coining the phrase Golden period as starting ca. 1700. I prefer the Hill's way of breaking his making into periods or epochs usually spanning 5 to 10 years based on the construction of Strads instruments. An amazing book that is actually cheap. Free even, as there is a PDF version online.
11 minutes ago, Mat Roop said:
Well used & Clean ...wine stains are OK! New ones will leave lint behind
Thanks Mat, I'm glad I asked.
Grazie Davide, felice gimondi campagnolo nuovo record brevettata.  Is that a red colophony over a yellow ground?
6 hours ago, Davide Sora said:
Felice gimondi - Bianchi Campagnolo
No, it's my linoxin varnish on a casein ground, of course.;)
Perhaps I should translate for those who don't understand  1960s/70s Eastern Lombard dialect?
felice gimondi campagnolo nuovo record brevettata. Translates literally as: happy other-worldly countryman (you have attained) new heights of excellence and everyone knows it.
In American slang the equivalent would be:
Hey, that's far out man.
I did not know we were countrymen. Careful, you are revealing your identity:ph34r:
In any case I have never heard that way of saying of eastern Lombardy, what the heck, I'm not from those areas, I'm from Cremona and it's well known we don't have good relations with neighbors...
However, I doubt the accuracy of your translation :
Felice Gimondi : italian cycling champion, professional from 1965 to 1979
Campagnolo nuovo record : a renowned brand of bike gearbox, a specific model in this case (nuovo record)
Brevettata : Patented, referring to the gearbox above
Maybe you need to improve your Italian...or your english:)
