MingLoo
What kinds of things cause a buzzing sound?
If a student approaches me with this, what other difficulties besides these five listed, might be causing the buzzing sound?
1. loose fine tuner
2. too low nut, with the string buzzing against the fingerboard
3. seam that has come unglued
4. crack in the instrument somewhere
5. chin rest rubbing against the tailpiece
These are the things I can think of, out of hand. I also tell them that, aside from making sure it's not a problem with a loose fine tuner, they should have the luthier examine the instrument, as only a luthier can do the repairs.
What else might cause the buzzing sound?
TIA
Some more:
- open seams - (knock all over the instrument over the purfling so see if there is something loose);
- unglued fingerboard,
- loose purfling;
- dirt in the f holes;
- loose soundpost;
- loose collar or pin on decorated pegs;
and many more!!! They can drive you mad!!!
Yes; the "seam that has come unglued" is the one I knew about which I omitted. The others never occurred to me.
The problem with the fine tuners, I have fixed myself more than once, but I'm not sure how to describe it. One of the little metal doughnuts (??) is loose. That I can fix. How would I describe that..?
I would just add; a high spot on the fingerboard or a loose lining inside the instrument
gap between bassbar and plate{one has opend up due improper or "sprung" fitting}
the string slot on the nut has been filled too deeply
the bridge protectors are floating on the strings in the afterlength area
Sometimes an intermitant buzz can be caused by an object in the room buzzing in sympathy with a certain note. Obviously that is not a problem in itself but sometimes can be mistaken for a buzz in the instrument causing great worry!....Other causes of a buzz that is not the instrument's fault can be the players personal effects, jewelry etc.
TIA
The absolute worst (most difficult) buzz I have ever encountered, was a lable that was half loose and at a certain frequency, it would buzz like mad...
Like a reed.
hmmm... my favorite instrument smashing topic.
string buzzing flat fingerboard, improperly cut or worn out nut slot, tailpiece buzzing chinrest, usually quiet resident dust bunny protesting living conditions, dead string falling apart, shoulder rest buzzing back of fiddle or having fit problems. buzzing most often accompanied by mental breakdown...
I keep waiting for the other shoe to drop; no jokes about string players "catching a buzz"?
I have the following:
(17) Why is my Viola making a buzzing sound?
A buzzing sound could be caused by any or some of the following:
1. loose fine tuner (loose metal doughnut)
2. lowest point of fine tuner pivot, barely touching top plate
3. string slot on the nut too deep, causing open string(s) to buzz against the fingerboard
4. seam that has come unglued
5. crack in the instrument somewhere
6. chin rest rubbing against the tailpiece or saddle
7. loose chin rest hardware
8. a high spot on the fingerboard
9. unglued fingerboard
10. loose purfling
11. loose lining
12. top and/or bottom block poorly glued
13. dirt in the f holes
14. loose sound post
15. loose collar or pin on decorated pegs
16. misplaced tailpiece
17. gap between bassbar and plate (one has opened up due improper or "sprung" fitting)
18. the bridge protectors are floating on the strings in the afterlength area
19. problem with endpin cork, ring, tip or screw
20. a label on the inside of the instrument can come loose, and buzz at a certain frequency
21. dead string falling apart; loose winding
22. loose string end in the pegbox
23. shoulder rest buzzing back of fiddle
24. loose sliding mute
25. loose wolf eliminator
26. buzz caused by an object in the room buzzing in sympathy with a certain note; sometimes can be mistaken for a buzz in the instrument
27. buzz caused by player's personal effects, jewelry or a button, etc.
28. check the bow; a screw loose on the threaded post can buzz
Aside from making sure it's not a problem with a fine tuner (#1-2), or some problem extraneous to the instrument, (#21-28), you should take it to a luthier and have them examine the instrument, as only a luthier can do the repairs.
Thanks to all!
Except note that items 3 and 4 are the same thing.
I thought about that, but isn't there a distinction between a nut which is too low, and the grooves, which are too deep?
No?
3. too low nut, with the string buzzing against the fingerboard
4. the string slot on the nut has been filed too deeply
5. seam that has come unglued
6. crack in the instrument somewhere
7. chin rest rubbing against the tailpiece or saddle
8. loose chin rest hardware
9. a high spot on the fingerboard
10. unglued fingerboard
11. loose purfling
12. loose lining
13. top and/or bottom block poorly glued
14. dirt in the f holes
15. loose sound post
16. loose collar or pin on decorated pegs
17. misplaced tailpiece
18. gap between bassbar and plate (one has opened up due improper or "sprung" fitting)
19. the bridge protectors are floating on the strings in the afterlength area
20. problem with endpin cork, ring, tip or screw
21. a label on the inside of the instrument can come loose, and buzz at a certain frequency
22. dead string falling apart; loose winding
23. loose string end in the pegbox
24. shoulder rest buzzing back of fiddle
25. loose sliding mute
26. loose wolf eliminator
27. buzz caused by an object in the room buzzing in sympathy with a certain note; sometimes can be mistaken for a buzz in the instrument
28. buzz caused by player's personal effects, jewelry or a button, etc.
Aside from making sure it's not a problem with a fine tuner (#1-2), or some problem extraneous to the instrument, (#22-28), you should take it to a luthier and have them examine the instrument, as only a luthier can do the repairs.
Thanks to all!
Here is a short list:
Something nearly and unintentionally touches something..
Most of you likely find what I have found.. Loose glue joints at the plates/ribs seldom buzz.
Off the topic: Isn't it interesting that almost never does a loose edge seem to be pushed against the rib or to pop up? That is in a reasonably shaped arch.
This should say something about the normal component of force or stress in the plate at the edge. At least in the bouts. For those interested in an ideal arching, maybe something can be said.
No?
The grooves are the operative parts of the nut. When we say that the nut is too low, what we really mean is that the bottoms of the grooves are too low.
Insect infestation?
(For Bluegrass instruments only) - Rattlesnake rattle loose within instrument.
And the always-popular Auditory Hallucination.
Did anyone say that the buzzing went away with stopped notes? If the fingerboard doesn't have lumps, discussing the nut should be considered a waste of time.
Okay; I'll fix it.
