      Whole Site SSL   03/08/17
sinebar1
shellac sanding sealer and spirit varnish
52 posts in this topic
My book "The Art of Violin Making" says that comercialy available sanding sealers containing shellac can be used as a ground. Can I apply spirit varnish over this type of sanding sealer? I can get the sanding sealer from Lowes.
shellac is spirit varnish...
in my opinion there is an excellent store bought product that is a very good "base" for making
violin varnish
it is called
"seal coat"
it is made by zinnser
it is a 2 lb cut of dewaxed shellac...
i along with jack bostwick and bill price helped to develop this product for use in the flooring industry
shellac is a by product of the lac beetle
it is natural, and the bugs have a natural wax within their secretions, similar to termites and bee's
shellac will adhere to anything, and anything will adhere to it, AS LONG AS the wax has been removed
shellac with wax can be used on top of other finishes, but should not be coated with other dissimilar product's
finish adhesion will be compromised
you can make custom finish with seal coat as the base
various resins can be added, as well as being easily thinned with denatured alcohol
many are under the assumption that only "pure" grain alcohol should be used to thin shellac
this is a falsehood, the type of alcohol available at paint stores is fine for use
the "contaminant" added to this product is "methanol" ie. wood alcohol...
it makes it poisonous to drink, yet is a natural wood by product, it does not effect the quality of the final product at all, "ever-clear" is a myth
"they" do not want to poison the alcohol so people won't drink it as much as manufacturer's NEED to put it the alcohol because if they did not it would be subject to taxation as a alcoholic beverage
zinnser makes many products with shellac in it, when you go to purchase, make sure you ask for it by name, and say "the dewaxed shellac"....
the exact same product is availible under the label "parks universal sealer" it is availible in gallons at the home depot and such...
this is a very economical way to make your own finsh
violin varnish
it is called
"seal coat"
Jezzupe ,i agree makers are forced to put methanol in their polishes ,etc,, but i would advise to try to avoid methanol .Its well known for its effects of destroying the optic nerve ,it doesnt have to be drunk,its absorbed through the skin and inhaled .Ive heard of French polishers losing their sight.I would try to get IMS (industrial methylated spirits) if at all possible when making spirit varnishes.Effects may be slow to show but is the risk of losing your sight worth it.My father has glaucoma, and its made his life hell and methanol does similar damage .
Industrial meths often has a small percentage of methanol(maybe 0.5%) but some types of standard denatured alcohol can have as much as 10%.
Usually the reason why methanol is allowed in denatured alcohol is because ethanol is supposed to interfere with methanol absorbtion in the body,and is so seen as a negligable risk but i dont neccessary agree with that.
As stated shellac is spirit varnish, but I suppose there could be many things added to it.
As far as sanding sealer goes, isn't that a pore filler for carpentry, or something that penetrates the wood fibers to harden the surface?
I like shellac because it is a good base coat, a good source of color, a good clear coat, and they all meld when applied.
Would somebody please address a point ? I used to hear that the French school (Gand, Viullaume etc) had strident tone because of shellac or spirit varnish sealers. Or is it just that when I read this (50 years ago) the market could not sell French violins so well as today?
I don't know. I'm a bit confused about varnish and sealer and grounds. I just want to add some color to my spirit varnish that got from Stew Mc and apply it to my fiddle and not have to worry about blotching.
I'm far from an authority but I think it goes,
french violins are strident
french violins have spirit varnishes
therefore spirit varnishes are strident
That may have been the reasoning, it was not mine, but that of "experts".
Leif Luscomb sells many appropriate (I like the botanicals) colorants for spirit varnish on his website.
Also, his 1704 spirit varnish is a good spirit varnish, if you like making your own.
It's not my reasoning, either. It seems too simple, and ignores the much more likely possibility that construction differences account for tone differences.
Spirit varnish is very temperamental, and your results will vary radically depending on the cut. If the cut is too thin, coats will dry too quickly and vigorously dissolve previous layers resulting in streaking or rippling of the finish. If the cut is too thick, or if you try to apply a second coat too early, the varnish will leave dark lines of color or the brush will skip over the surface causing the varnish to “gum” up and unevenly shift the pigment around unevenly. If the cut is just right, it will apply fairly easily with only a few coats (if a ground is already established) and meld with previous coats. Many people talk of doing many coats (about 10) in one day, but I’ve never needed to go beyond just a few coats (I brush, not spray).
You should be able to add many kinds of colorants to shellac without issue. Most things that work for oil will work for you.
If you don’t want blotching, take your time. Work quickly when applying the coats, but take your time between coats. If this is your first time, expect to screw up, and come to terms with cleaning up the varnish, and trying again.
Pardon the dumb question....is strident a good thing for a violin?
as per the dictionary...
making or having a harsh sound; grating; creaking: strident insects; strident hinges
you decide :)
Equating type of varnish with sound is silly... amount applied is the bigger factor, along with a host of other more pressing issues. Factory violins often have quickie varnish jobs, a few coat of over thinned shellac, which might result in this "strident" sound.
John,
Lots of violin lore like this comes from one person saying the wrong thing over and over, based on some superficial observation. In my experience the strident sound results from a couple of other things that are straightforward to fix, and consistently reliable (and don't involve stripping the varnish). Then those "strident" French violins can be exceptionally nice. For instance, based on the number of them I see with really bad necksets, 50 years ago ripping out one of their necks and setting it right was probably financially equal to me ripping the necks out of Chinese violins to make them sound, and so it didn't get done, and the varnish got blamed.
FWIW, doing a varnish job with shellac alone is very different from using a normal spirit varnish, and the usual rules don't apply--you can get away with a lot more, because dried pure shellac doesn't really redissolve easily. A few months ago I shellacked a quick replacement top for one of my baby violins in about two hours, total, start to finish, with a brush. You'd never be able to get away with that with a normal spirit violin varnish.
The resulting violin was not strident, by the way. :-)
Jezzupe,.
I've seen the 'seal coat' before but never used it, can you say how it is different from Zinser's regular shellac?
I thought their regular shellac was supposed to be a good sealer.
Thanks,
don
don, the seal coat is 99.9% wax free, and is a 2 lb cut....the "regular" stuff is a 3 lb cut and has wax naturally in it....
waxed shellac should not be used as base coats...the succeeding coat{unless shellac} will have an adhesion failure
there are some exceptions whereas 2 part isocyanate , polyfunctional azridine, and carbodimide waterbase finishes will adhere based on some "deep" macro molecular chemistry, but in general its not a good idea....
related to "spirit" varnish...as mich....er' i mean strado stated....it would be better to term it that "alcohol based shellac is the main body of spirit varnish....
MANY things can be added, sandarac, copal, saps, sugar, drano etc, etc...
related to colorant....
shellac is very easy to color naturally...
virtually anything natural with color can be extracted into alcohol....some example's are
coffee, tea, plum leaves, flowers, bark,sawdust, dry grasses, tar, hemp resin, tobacco resin, tobacco, etc...
just soak whatever in the alcohol for a day, and then strain it to clean it and then mix it with the shellac...
if you want quick standard colors,universal colorants{available at art stores} will mix well in alcohol based
spike lavender oil will give some more open time...i use tea tree oil with good results....its cheap and easy to find
related to safety....
wood alcohol poisoning can be had from inhalation, the cure is to drink regular alcohol....however that being said
anytime you are doing work that is considered dangerous, you should be taking precautions
safety is #1!
eye protection, ear protection, hand protection, dust protection, vapor protection....AO chemical respirators will eliminate virtually all concerns with fumes
be professional, use saftey gear
anytime you use flammable liquids, shellac has a 20 degree flash point, have fire extinguishers available and extinguish all sources of open flame...
safety is #1!
Is this what you are refering to? http://www.zinsser.com/product_detail.asp?ProductId=72. Do they sell this stuff at Lowes?
What are you using for color?
I never use any of the Zinsser products. You should be using HOCK shellac flakes or something similar, dewaxed. I never use any liquid canned shellac product, because you can't be sure that it contains only stuff kosher for violin work. When people complain about orange shellac, it's usually this prepared liquid stuff.
You can use garnet, blonde or orange flakes for color. If you need to punch it up, I use light fast silk dye for slight shifts, and haven't had any problems with fading, leaching, or discoloration contrary to some.
In this particular case, I used aniline dyes.
Do no use sanding sealer on a violin. :)
Aniline... which is the same as fabric/silk dye :)
i would have to disagree with you....
there is a company by the name of RPM
they are a parent company of MANY companies...behlen for example is owned by them...as is zinnser
and a hundred other companies....
i would say bout 95% of the worlds lac forest's are owned by rpm via zinnser and have been since the 1860's
almost ALL lac beetle products that are distributed to any smaller "mom and pop" lac resin producers came from zinnser to begin with...
purity or contaminates is generally not a issue
the product "seal coat" is 100% lac beetle resin and metholated alcohol only....
zinnsers process for wax removal is very "clean" and state of the art...
i believe their products are top rate...i may be biased however
here is the "story" of shellac as authored by a associate gene hoyas from zinsser
Shellac, as the word is commonly used, refers to all forms of purified lac - a natural resin secreted by the tiny lac insect on certain trees, principally in India and Thailand.
“Lac” is derived from the Sanskrit word “lakh” which means 100,000 and refers to the vast swarms of insect larvae that inundate lac trees during brood season. There is a connection between the word “lac” and the Indo-European word for salmon, “laks”, very likely a reference to great numbers of the fish observed in spawning shoals.
Not much is known regarding the very early history of shellac. In the Vedic period about 3,000 years ago it was called “Laksha.” One of the Vedic books contains an account of a whole palace constructed entirely out of lac resin.
Ancient Chinese and Indian civilizations used the dye extracted from lac for dyeing silk and leather and as a cosmetic rouge and a coloring for head ornaments. The superior adhesive quality of the resin made it useful for setting jewels and sword hilts as well as repairing broken pottery. The residue left after the extraction of the dye was made into a grinding wheel for jade – a technique still in use today.
It was in the field of medicine, however, that the most extensive applications for lac were discovered. It was prescribed either as an emollient, or as a stimulant to tissue growth or in the treatment of gum hemorrhages and menstrual disorders. In veterinary medicine lac was mixed with lard and the paste used to fill the cavities in the hooves of horses and cattle.
Europe Discovers the Wonders of Shellac
Following the historical journey of Marco Polo to the Orient in the late 13th century, shellac and its by-products began to make their way into European commerce and industry. Accounts dating as far back as 1534 describe the cultivation, harvesting, processing and use of lac in extraordinary detail.
By the mid-17th century shellac resin, shellac dye and shellac wax were used with increasing frequency by painters not only to create their masterpieces, but also to provide them with a protective finish.
Shellac became the preferred finish for craftsmen and artisans; it was the coating of choice for fine furniture, woodcarvings, and turnings. To this day some of the finest museum pieces still have their original shellac finish.
The Golden Age of Shellac
Ironically, it wasn’t until the mid-19th century that shellac was commonly used as a clear finish. Until that time it was processed mainly for the dye that was extracted from the lac after it was harvested. This rich, reddish-purple colorant was highly prized and much sought after by the textile trade in both Europe and America because it was an excellent substitute for Cochineal, a dye imported from Spanish colonies in Mexico.
In 1856 an English chemist named Henry Perkin succeeded in synthesizing a mauve-colored dye from an aniline derivative of coal tar. His discovery forever changed the future course of the shellac industry. As the demand for natural lac dye declined, the demand for shellac varnish began to increase. Production plants began springing up throughout Europe, most notably in Germany, which soon developed a reputation for manufacturing the finest shellac in the world. Efforts were also being concentrated on producing colorless shellac. As far back as the 1830’s shellac chemists discovered that by chlorinating an alkaline solution of shellac they could remove almost all of the color and then precipitate the resin. The result was a pale, straw-colored varnish that excelled any oil-base varnish for clarity.
1849: Shellac Comes to America
By the middle of the 19th century, Germany was the center of shellac bleaching for all of Europe. One such bleachery, located in the town of Mainz, employed a man named William Zinsser as one of its bleaching foremen. Confident of his technological skills and convinced that a good market for bleached shellac either existed or could be created in the United States, Zinsser and his family emigrated to America. Zinsser settled in New York City in 1849 and built a home in Manhattan on West 59th Street. Almost immediately he set up a workshop in a building next to his home and began to bleach small quantities of shellac that were sold to fellow immigrants. From this humble beginning arose the first shellac bleachery in the United States.
At that time Americans had never before seen bleached shellac, shellac varnish, or so-called French varnish and therefore were unaware of the many uses for this versatile, natural product. Initially, shellac sales were confined to fellow immigrant artisans and craftsmen. As word of this marvelous new varnish spread among tradesman of all nationalities the demand for shellac grew from a few pounds per day to thousands of gallons by the turn of the century; up to that point Zinsser shellac was sold to vendors who packaged the product under their own label and name.
This practice ended in 1908 when Zinsser’s sons (shown standing on either side of him in the photograph on the right) took over the company and began to package their shellac under the Bulls Eye® label.
By the 1920’s there were several other shellac manufacturers in the U.S., including Bradshaw-Praeger, Haeuser, Gillespie, Rogers and Mantrose to name a few. Most of these companies either imported shellac or prepared and packaged pre-mixed solutions of shellac and alcohol.
The next eighty years witnessed a veritable explosion in the commercial applications for shellac. It was used extensively as a binder in the manufacture of gramophone records from the turn of the century well into the 1950’s, when manufacturers began using vinyl to press record albums. Shellac was used to make shoe polish, felt sizing for men’s hats, hair spray, floor wax, pharmaceutical, candy and fruit coatings; printing inks, adhesives, grinding wheels, paper and foil coatings and electrical insulators.
From the turn of the century through the 1950’s home builders and painting contractors used shellac as a sealer for plaster walls and a fast-drying varnish for interior woodwork, trim and floors. Today this beautiful original finish can still be seen in many older homes.
The Rise of Lacquers and Polyurethane
The development of synthetic resin compounds early in the 20th century together with advances in varnish formulation heralded the end of shellac’s industrial and architectural dominance. Ironically, many of these newly developed resins – such as Bakelite and similar phenolic-base compounds – were created by researchers attempting to synthesize shellac.
Following World War I chemists discovered that nitrocellulose dissolved in a powerful solvent mixture produced a crystal clear coating that dried as fast as shellac, thus giving rise to the widespread use of lacquer as a furniture finish. After World War II alkyd varnishes were developed and by the 1950’s the public was introduced to the first oil-base polyurethanes. As these finishes displaced shellac as the standard finish coating for interior woodwork and floors, one-by-one America’s shellac manufacturers either closed their doors or merged with others.
From the 1960’s until the early 1990’s shellac seemed forgotten by everyone except those who manufactured it and the contractors, hobbyists, and knowledgeable devotees who used it. All of the largest makers of shellac were out of business or existed as subsidiaries of the one remaining manufacturer: William Zinsser & Co.
How Insects Make Shellac
Shellac has the distinction of being the only known commercial resin of animal origin. It is produced by a tiny red insect (Laccifer lacca) which, in its larval stage, is about the size of an apple seed. Swarms of the insects feed on certain host trees, commonly called "lac trees," in India and Thailand, the main lac-producing countries.
Their whole life cycle spans six months and is devoted to eating, propagating and creating lac as a protective cocoon for their larvae.
During certain seasons of the year, these tiny red insects swarm in such great numbers that the trees at times take on a red or pinkish color. When settled on the twigs and branches, they project a stinger-like proboscis to penetrate the bark.
Sucking the sap, they begin absorbing it until they die. In shellac lore this is the 'feast of death." While they eat they propagate, with each female producing about one thousand eggs before dying.
In the body of the lac insect the digested tree sap undergoes a chemical transformation and is eventually secreted through pores. On contact with the air, it forms a hard shell-like covering over the entire swarm. In time this covering becomes a composite crust for the twig and insects. Only about five percent of the insects amassed on the trees are males. The female is the main shellac producer.
While she is secreting lac, she is preparing herself to die after providing a fluid in which her eggs will mature and from which the future supply of bugs will come, to repeat the process of swarming, propagating and creating the next season's shellac harvest.
The males, having fertilized the hordes of females, also begin their life-ending feast. Although they contribute relatively little more to the shellac crop, they have already assured an ample supply because the females vastly increase their output of lac after being fertilized. The great mass of male and female bugs on each tree gradually becomes inactive as the shell-like covering forms over them. In the sixth or seventh months, the young begin to break through the crust and swarm to new feeding grounds.
Shellac cultivation yields a large crop by helping the larvae find better locations for their feast. This involves simply cutting lac-bearing twigs from an infested tree a few days before the emergence of the larvae. A bundle of such twigs, known as 'broodlac," is tied to an un-infested tree on which there are many tender new shoots. This results in a higher survival rate of insects and a greater yield of lac since only a little broodlac gives forth sufficient larvae to infest a tree thoroughly. No further attention is needed until shellac is harvested.
How Lac Is Harvested
Shortly after the young have swarmed at the end of the adults' life cycle, natives begin to harvest the lac encrustation from the trees. Only one crop is taken per tree. Young are hatched, however, twice a year. Natives gather millions of encrusted twigs, called "sticklac," for transport to simple factories or refining centers where the lac crust is scraped off and processed. The resin is also collected in the forest or orchard by smacking the branches with a wooden mallet. This material is called "grainlac." In either case, this is the first step in the harvest of shellac resin.
At refining centers, sticklac is scraped to remove the resin from the twigs and then it is ground (as is grainlac), usually in a primitive, hand-cranked mill. At this stage, the ground lac contains a mixture of resin, insect remains, twigs and other impurities. This is now passed through a coarse screen to remove the larger size twigs. After the lac is ground and the chaff sifted out, it is soaked in water for several hours in large cup-shaped jars. These are about two feet high and have rough serrated inner surfaces.
A ghasandar jumps into the jar and rubs the lac with his feet against the rough surfaces. This action causes the lac seeds to break open, releasing dye and insect remains. The ground lac is rinsed to remove the dye and then spread out on a concrete floor to dry in the sun. The dried resin is called "seedlac" because of its grain-like appearance and ranges in color from pale lemon to dark red.
Commercial shellac falls into three categories that reflect the processes used in their manufacture: hand-made, machine-made and bleached.
Hand-Made Shellac
This process involves a primitive method still used by small local factories to produce flake shellac. Generally, three workers carry out the process from start to finish. They begin by packing seedlac into a long round bag about the shape of a section of two-inch fire hose. These bags vary from 25 to 40 feet in length. Small sections of the long bag are heated uniformly by slowly rotating them over a charcoal fire in an oven called a bhatta. While a helper twists the far end of the bag, the operator, called a karigar, holds the hot end of the bag and squeezes the molten lac through the pores of the bag. The helper at the far end continues to pinch the bag by twisting it, forcing more lac toward the karigar.
The karigar lets the oozing shellac fall on the hearth stone, which has been moistened with water, and scrapes the surface of the bag periodically with a spatula. To prepare for the next step, he repeatedly picks up lac from the hearth-stone with an iron spatula and puts it on the rotating bag, basting it back and forth to get a viscous, uniform melt.
This soft lac is then turned over to a bhilwaya, who works it into thin sheets. With a strip of palm leaf, he spreads the molten lac over a ceramic jar filled with hot water, and then pulls off a piece about two feet square and a quarter inch thick.
Standing before the fire with the sheet, the bhilwaya manipulates it to soften it uniformly. At that point he uses his hands, feet and teeth to stretch it into a paper-thin sheet about 5 feet by 4 feet. This is laid aside to cool and harden, after which it is broken into flakes.
If there is a demand for it, the bhilwaya will opt instead to make button lac. Instead of stretching the molten lac into sheets, the bhilwaya takes the lac from the twisting bag with a spatula and spreads it out in the form of a circular disk or button about one to three inches in diameter. Before it hardens completely the button is stamped with the seal of the manufacturer.
Machine-Made Shellac
Shellac manufactured by modern mechanical methods is called machine-made shellac, mainly to distinguish it from shellac made by the indigenous – and, frankly, more fascinating – hand technique. There are two processes - one based on melting (heat process) and the other on solvent extraction.
In the heat process, seedlac is melted on steam-heated grids. The molten lac is forced by hydraulic pressure through a fine wire screen. The filtered shellac, still molten, is collected and transferred to a steam-heated kettle from which it is dropped onto rollers. It is squeezed out on the rollers, coming off as a thin sheet to be broken into flakes. The thickness of the flake is controlled by adjusting the roller pressure. All flake shellac produced by this process contains wax.
The solvent process produces three types of shellac:
1. For the wax-containing grade, raw seedlac and alcohol solvent are charged into a dissolving tank. The solution is refluxed for an hour or so and then filtered to remove insolubles. The filtered shellac is fed to a series of evaporators where it is concentrated into a viscous melt, which is then dropped onto rollers that sheet it out for removal in flake form. Darker, wax-containing flake shellacs such as Garnet are made this way.
2. Dewaxed shellacs are made by dissolving seedlac in either cooled alcohol of a very high proof or heated alcohol of a lower proof. The resulting solution is then passed through a filter press to remove the wax, after which the filtered shellac is then concentrated in evaporator tanks. The viscous shellac is then rendered into flakes. Dewaxed Lemon and Dewaxed Garnet shellacs are manufactured using this process.
3. Dewaxed/Decolorized shellacs are made by the same process as dewaxed grade, except that after dewaxing the solutions are forced through activated carbon filters to remove the darker coloring constituents from the shellac. By varying the amount of carbon, contact time and quality of the seedlac, one can obtain grades of shellac ranging in color from light amber to extremely pale straw. Examples of these shellacs include Blonde, Super Blonde and Ultra Blonde.
Bleached Shellac
Although most of the bright red lac dye can be removed with activated carbon, some shade of red-orange remains. For many applications, however, a nearly colorless film is preferred. Kusmi shellac, while extremely light in color, is very expensive and not available in commercial-scale quantities.
The development of shellac bleaching in the early 19th century solved this problem with a relatively inexpensive process that could produce enormous quantities of very pale-colored shellac.
Since establishing the first U.S. shellac bleachery in 1849, Zinsser has made significant advances in bleaching tech-nology. Today our MBZ division bleaches seedlac in its Attleboro, MA facility. From this bleached resin we make Bulls Eye Clear Shellac and B-I-N®, our white-pigmented stain killing primer.
The bleaching process involves dissolving seedlac, which is alkali-soluble, in an aqueous solution of sodium carbonate. The solution is then centrifuged or passed through a fine screen to remove insoluble material.
The next step is bleaching the cooled solution with dilute sodium hypochlorite to the desired light color. The shellac is then precipitated from solution by the addition of dilute sulphuric acid, filtered off, washed with water, ground and dried in vacuum driers.
The final product has a granular consistency and is dissolved in alcohol to give a milky, creamed-honey colored solution. Both Clear and Amber Bulls Eye Shellac contain from 3% to 5% natural shellac wax, which gives them their somewhat milky appearance in the container but does not affect the clarity of the dry film.
While more efficient equipment and machinery have replaced much of the work that was done by hand in the 19th and early 20th centuries, the bleaching process itself has not fundamentally changed in over 100 years.
What Does the Term “Pound Cut” Mean?
Bulls Eye Shellac is manufactured in a 3-lb. cut. "Pound cut" is a term unique to the shellac industry. It refers to the number of pounds of shellac dissolved in one gallon of alcohol. A 3-lb. cut contains approximately 29% shellac; a 2-lb. cut contains about 21% shellac.
As a rule the following pound cuts are used:
1-lb. – Pre-stain sealing, French Polish finishing
2-lb. – Pre-finish sealing; general wood finishing
3-lb. – Floor finishing; sealing knots & sap streaks
4-lb. – Sealing tough knots & sap streaks, stains*
* The 4-lb. cut is generally used by professionals
Does Shellac Have a Shelf Life?
Freshly made shellac dries very quickly to a hard, durable and water-resistant finish. However, because it is a natural material, shellac is also perishable and after six months an ordinary solution of shellac and alcohol begins to undergo a chemical change: it gradually takes longer to dry; the dried film is softer and more prone to scratches and water damage. This change is even more pronounced for bleached shellac. After 18 months it may take hours to dry or not even dry at all and is considered to have expired. Exposure to heat also accelerates the expiration process.
Zinsser research chemists have succeeded in prolonging the shelf life of shellac in two ways: the first involves a specially formulated solution; the second involves a patented process (U.S. Patent No. 6,348,217 issued 19 February 2002) for the production of the resin itself.
Bulls Eye Shellac is the only pre-mixed shellac in the world guaranteed to dry quickly to a hard, durable, finish for 3 years after the date of manufacture. However, since storage conditions can greatly affect the shelf life of our shellac always check the manufacturing date to find the freshest Bulls Eye Shellac and apply some of the product to a test surface to check the dry time and film hardness.
To ensure the long life of Bulls Eye Shellac keep the container tightly closed and store in a cool, dry place where the temperature does not exceed 75o F. Extreme heat can ruin shellac in less than a week. There is no need to worry about cold weather: since shellac is alcohol-based it is unaffected by freezing temperatures.
Common Shellac Myths
Myth: Shellac is made from bugs or bug droppings.
FACT: Shellac is a resin secreted by the lac insect to form a cocoon, much like a silk worm. It takes about 100,000 lac bugs to make 1 lb. of shellac resin.
Myth: A shellac finish turns white when water touches it.
FACT: Fresh shellac is remarkably water-resistant and, in most cases, will stay clear after hours of exposure to water, making it a great finish for most interior surfaces, including woodwork, trim, doors, cabinets, paneling, floors (yes, floors!) and furniture.
Myth: Shellac scratches easily and is very brittle.
FACT: Shellac is a durable finish that is much less brittle than lacquer and does not scratch as easily. Unlike polyurethane, a damaged shellac finish can be easily touched up or renewed by applying another coat.
Myth: Shellac is incompatible with other finishes.
FACT: Shellac will adhere tenaciously when applied over almost any other type of finish. When used as a sealer under certain polyurethanes, however, regular shellac may not be compatible because it contains a small amount of natural wax. To seal wood before applying polyurethane and other finishes we developed Bulls Eye® SealCoat,™ a shellac-base universal sealer that is 100% wax-free.
Myth: Shellac turns an ugly dark color as it ages.
FACT: Shellac is UV-resistant and does not yellow or darken with age. The dark shellac that people see in older homes is a less-refined version of shellac that either was naturally dark or was tinted by contractors when dark wood colors were preferred in the early 20th century.
Myth: Shellac is an old-fashioned, outdated finish.
FACT: Shellac has more modern features and benefits than any other wood finish in the world.
Shellac's Great Properties
Shellac has such remarkable properties that if it were just recently discovered it would be hailed as a miracle finish of the 21st century.
All-natural – Shellac is an all-natural resin of insect origin that is harvested regularly and is therefore a renewable resource.
Fleeting alcohol odor – Shellac is dissolved in denatured ethyl alcohol. It has a fleeting, antiseptic odor that dissipates quickly as the product dries.
Easy to use – Shellac is user-friendly and virtually goof-proof. It can be applied with a brush, pad, sprayer, or wiping cloth.
Super-fast dry time – Shellac dries to the touch in MINUTES and, in most cases, can be sanded or recoated in a little over half an hour.
Cold temperature application – Unlike other finishes shellac can be applied in cold temperatures (40o F. and below) without concern over proper drying and curing.
Non-toxic/hypoallergenic – The U.S. Food & Drug Administration has certified shellac as a protective glaze for candy and pharmaceuticals.
Non-yellowing/non-darkening – Shellac is UV resistant and will not yellow or darken with age – unlike oil-base finishes.
Enhances the beauty of wood grain – Shellac brings out the rich warmth of wood grain. Finished surfaces look soft and natural, not plastic-coated.
Sticks to glossy surfaces and finishes – Shellac is prized by everyone who uses it for its incredible adhesion. It will stick to just about anything.
Dried film is impervious to odors – Two or more coats of shellac will seal in any kind of odor in any type of porous surface.
Stain sealer – Shellac is arguably the world’s most effective stain and knot sealer (another reason why we use it to make B-I-N® Primer-Sealer).
Easy to touch up and recoat – Unlike other finishes shellac can be easily touched up if it is scratched or worn; a new coat of shellac melts itself into the existing coat.
Easy to clean up or remove – Shellac is dissolved by household ammonia as well as alcohol, making it very easy to clean brushes and other tools.
