"Search Maestronet" function not working for me
Josh Henry
Hi,
Whenever I try to do a search on the "Search Maestronet" function, I get an error page as a result. I use Firefox (version 3) as my browser, but I've tried searches in IE7 as well, but get the same result. I've read in posts from other people to "search" this or that topic. Is the search function working properly, or could the problem possibly be something on my computer?
Thanks,
Josh Henry
I've copied the error message below so you can see what I get returned for a search for "strad."
<start of error message>
___________________________________________________________________________
Error Occurred While Processing Request
The collection maestronet does not exist.
The collection you specified does not exists or is not registered with the ColdFusion Search Service.
The error occurred in C:\www\www\searchresults.cfm: line 17
15 : <cfsearch name="Search1"
16 : collection="maestronet"
17 : criteria="#searchstring#">
18 :
19 : <cfif nextstart lt search1.recordcount>
Please try the following:
* Check the ColdFusion documentation to verify that you are using the correct syntax.
* Search the Knowledge Base to find a solution to your problem.
Browser Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9.0.1) Gecko/2008070208 Firefox/3.0.1
Referrer http://www.maestronet.com/index.cfm
Date/Time 13-Sep-08 09:32 PM
Stack Trace
at cfsearchresults2ecfm319809866.runPage(C:\www\www\searchresults.cfm:17)
coldfusion.tagext.search.CollectionDoesNotExistException: The collection maestronet does not exist.
at coldfusion.tagext.search.SearchTag.verifyLocale(SearchTag.java:775)
at coldfusion.tagext.search.SearchTag.doSearch(SearchTag.java:200)
at coldfusion.tagext.search.SearchTag.doStartTag(SearchTag.java:159)
at coldfusion.runtime.CfJspPage._emptyTag(CfJspPage.java:1908)
at coldfusion.runtime.CfJspPage.invoke(CfJspPage.java:152)
at coldfusion.tagext.lang.IncludeTag.doStartTag(IncludeTag.java:343)
at coldfusion.filter.CfincludeFilter.invoke(CfincludeFilter.java:65)
at coldfusion.filter.ApplicationFilter.invoke(ApplicationFilter.java:210)
at coldfusion.filter.PathFilter.invoke(PathFilter.java:86)
at coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:50)
at coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePersistenceFilt
er.java:28)
at coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:38)
at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:38)
at coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22)
at coldfusion.CfmServlet.service(CfmServlet.java:105)
at coldfusion.bootstrap.BootstrapServlet.service(BootstrapServlet.java:78)
at jrun.servlet.ServletInvoker.invoke(ServletInvoker.java:91)
at jrun.servlet.JRunInvokerChain.invokeNext(JRunInvokerChain.java:42)
at jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java:257)
at jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java:527)
at jrun.servlet.jrpp.JRunProxyService.invokeRunnable(JRunProxyService.java:204)
at jrunx.scheduler.ThreadPool$DownstreamMetrics.invokeRunnable(ThreadPool.java:349)
at jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.java:457)
at jrunx.scheduler.ThreadPool$UpstreamMetrics.invokeRunnable(ThreadPool.java:295)
at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
<end of error message>
Hi,
Thanks,
Josh Henry
18 :
Stack Trace
er.java:28)
I get the same error message when I use the "Search Maestronet" field on the home page. If I go to a forum and use the search for that forum it works :)
I get the same error message no matter what page I'm on. Could this error have something to do with 'cookies' enabled or disabled from the website?
  • 1 month later...
The Search box under the Maestronet log on the upper left side of the page does not work. The Search in the upper right drop box works fine.
  • 1 month later...
Hard to keep everything working right on a complex Web site ...
"Cold fusion" was a physics scam. Could never understand why they used it to name a programming language :)
  • 3 weeks later...
Late to the party, but: I always search using the 2nd 'more options' search page. You get to it by clicking the 'more options' link on the main 'search' dropdown, then on the resulting page click the similar link at the bottom, and you end up at a page that works fine and allows you to specify poster, although you don't have to use that field.
  • 9 months later...
