      Whole Site SSL   03/08/17
polkat
Nut height over fingerboard?
19 posts in this topic
What's the average on this? I've seen some nuts almost even with the firgerboard, and I've seen some nearly 2mm higher. I try to cut mine so they are about 1mm over the board, but what is considered standard?
Thanks!
For violin I use about 1.5mm on the G side and about 1mm on the E side.
For violas I use more like 2mm on the C side and 1.5mm on the A side.
Measurements are as taken before making the string grooves.
I do it by eye though, and those measurements are by eye.
You can use feeler guages to help get consistency and accuracy.
I finish 98% of the nut before gluing it on to the neck.
I use digital calipers for setting string spacings, a kife to mark them, and files to cut them.
First I set the string height by filing the string grooves. Then I file enough off the nut so that the depths of the G, D and A string grooves are about a third of the string diameters. (The E string is so small that more of its groove remains.) I don't pay attention to the nut height; I pay attention to how much of the string groove remains.
Do you have equal spaces between the strings, or equal spaces between string centers?
Can you say what string heights you set?
"Can you say what string heights you set?"
I do it by eye; I've never measured, but here's how I've heard it explained: I set the height of the G string so that my business card will fit underneath. My competitor is a cheapskate and his business card is printed on thinner stock, so I use his card under the E string.
I think I need to get my calipers out and start measuring business cards.
Is there a comfort zone sorta like Goldilocks for error or is this pretty stringent?
How can you know if you got it right? Will the player tell you or will it buzz or sound bad?
Ditto to what Brad said.
I use a 0.013" (0.33mm) feeler gauge for all four strings, some go a little lower on the E-string but I think it eventually digs in a little so I don't . Mark the position with a knife then file the slot holding the feeler gauge against fingerboard, stop when you hit the feeler gauge. I like to finish with a little steel wool to soften the edges of the slots a bit.
BTW...I measured my business card and it's 0.3mm
"How can you know if you got it right?"
If I look under the string and see space -- not too much space, but not too little space -- between the string and the fingerboard, I figure I have it right.
"Will the player tell you or will it buzz or sound bad?"
Too little space can cause buzzing on the open string. Too much space makes it hard to finger the string near the nut.
This is essentially what I do; the strings look like they are just laying on top of the nut when I'm done. The finished crown of the nut is perhaps 1mm above the fingerboard.
Dito what Daryl does with the feeler gauges. When I can't find them, I have a couple metal rulers that are as thin, and use those.
That's too funny... Love it!
Thanks guys! Lots of good stuff here. It seems that the general concensus is that the string height over the fingerboard at the nut is more important then how high the nut stands. Makes sense.
Equal spacing between the string grooves, centre of the string.
I used to do it according to string tickness and final spacing between the strings, but not now.
I pretty much go along with what Brad said. I've seen 2 mm under the string at the nut on some VSO's (before I fixed it), but that's just about unplayable.
Any reason why you changed?
Was it at Newark School that you were taught to have equal string spaces?
Dburns,
Newark school taught me to do equal spacing for string centres.
I set the string spacings on the nut equally, and mark them with a knife, and cut grooves with a file.
I make the shape of the nut sloping so there's more nut of the G side, and less on the E side.
It's important to use the proper size file for grooves, and to make the groove NOT too deep,
about 1/3rd of the string thickenss, according to Strobel.
If you make the grooves too deep, then the string will eventually vibrate in the groove and cause a buzz.
So, to recap, I measure the height of the nut BEFORE cutting the grooves,
then I cut the grooves using the methods descrived above.
The result is a good playing height, and a new violin nut takes about 30 minutes to make.
Cheers.
No, it was my choice, I give myself player feedback.
It makes no sense accounting for different string thicknesses just to get equal spacings between the strings, when it's actually the string cnetre that the player uses, not the spaces in between.
