Left-handed Violins ...
JimMurphy
Dunno, but I saw a violin ad in the Strad mag for a modern antiqued violin which was set up left handed even with a left headed chin rest.
I thought I was seeing things, perhaps it was just a printing error.
Since the orchetra is generally set up for right handed players, I doubt that Strad had in mind the leftie market.
Good question though.
Well in that time there wasn't a whole lot to change to make it left handed since the chinrest wasn't in use. The only changes would have been to put the pegs in differently and switch the positions of the bassbar and soundpost. I think that a normal righthanded pegbox configuration would work with unwound gut strings if strung up lefthanded. I also think that a normal righthanded bassbar and soundpost would work pretty well if strung up left handed you would just need to try different string gauge combinations to balance the strings with each other. So I think that a baroque style violin is naturally ambidextrous if you don't mind cutting a new bridge.
The question that I'm more interested in is whether a musician at the time would have played lefthanded in public.
The harpsichord, virginal, organ, piano, violin, viola, 'Cello, Bass, all are right handed beasts.
If one person out of 25 in an orchestra played left handed on a left handed set up, you'd have asymetry,
and the sound would not project into the audience.
Here's a leftie from the Strad mag.
As you can see, there is a printing error in the photo of the front, since the photo of the violin from the side is correct and as normal.
Thanks, I hear you about the Orchestral righthanded performer scenario.
Back in the day they had Soloists, Court Jesters, etc. too ... perhaps
lefthanded.
I'm thinking more along the lines of an authentic instrument
brought in for internal repair [years later] with either:
lefthanded bassbar installed; or righthanded bassbar
installed and visible glue-line suggesting a lefthanded bassbar
may have been previously installed.
Only the fortunate few [sacconi, Hill, Jeffrey Holmes ???] who have
examined the inside of these fine instruments may know.
Jim
lefthanded.
Jim
In those days left handed people were labeled as heretics and burnt at the stake. :) :)
I presently know left handed violinists and knew a few old left handed violinists - I actually learned from a lefty. They all played "over the base" or left handed strung standard. It always amazed me how they do it but all left handed violinists I have known played a standard violin. I have never seen a left handed violin.
Very interesting question.
Lefties are cool :)
I have tried to play the violin left handed, it's a nightmare, it's like driving in Ireland.
I can cut f holes, badly, left handed, I try to use the left hand and the right side of my brain,
it's good for the mind and the left hand....actually.
My right hand is like a baseball mit compared to my left hand, these days.
Ok, if a client asked me specifically to make a leftie fiddle and gave me a deposit would I say yes ?
Ummm, yes.
Being left handed and having studied violin to a fairly high standard (playing it the normal traditional way) I always felt I had a positive advantage over my right handed colleagues..After all it’s the left hand that has to be most agile.
Like Ben says holding and playing the other way around real mucks up the look of an orchestra and would make it a nightmare to share a desk with someone playing backtofront.
When I worked with Roger in Germany we built two left handed instruments for professional classical musicians who had had to totally relearn playing because of injury, one was a rank and file viola player and the other was the baroque violinist Reinhard Goebel.
Both instruments where totally back to front from bas bar position through to peg positions.
neil
Of all the hundreds of historic violins made by these four Great Masters
[including both Andrea & Nicolo Amati], has any one Model ever been
authenticated as an original 'lefthander' ?
I'm not sure how we'd know one of these instruments was originally left-handed, unless something unusual could be noticed about the peghole bushings. Left-handed violins seem to work fine with the bass bar and soundpost in the normal, "right-handed" locations. Wear wouldn't necessarily be an indicator, because a normal violin might have been played left-handed, even if the peg locations interfered somewhat.
Much more radical alterations, such as "cutting down" the size have been done on many valuable instruments to make them more acceptable to the mainstream market, so it would surprise me if an original left-handed instrument from that period survived.
... My right hand is like a baseball mit compared to my left hand, these days.
Hi Ben,
Bowing with my lefthand, fingering with my right just seems natural to me.
Then again, my violin playing is about as good as my singin' in the shower
[not too bad] :) :) :)
When I worked with Roger in Germany we built two left handed instruments for professional classical musicians who had had to totally relearn playing because of injury, one was a rank and file viola player and the other was the baroque violinist Reinhard Goebel. Both instruments where totally back to front from bas bar position through to peg positions.
Thanks Neil,
I had heard about Goebel's situation [injury]. Interesting, that Roger 'did' make the lefty changes.
Jim
I'm not sure how we'd know one of these instruments was originally left-handed, unless something unusual could be noticed about the peghole bushings. Left-handed violins seem to work fine with the bass bar and soundpost in the normal, "right-handed" locations. Wear wouldn't necessarily be an indicator, because a normal violin might have been played left-handed, even if the peg locations interfered somewhat. ...
Thanks much, David. That all makes a lot of sense.
My next trip to the Library, I'll see if I can find that book I read
about the lefty bassbar glueline. Don't recall whose instrument it was.
[P.S. What's goin' on with that 'Symmetry' thread ... is it the car-buffs or blue&white scooter aficionados
running-up the "Views" ? It's just crazy, Man ... CRAZY !] :)
Here's an example of a lefty using a standard strung fiddle.
http://www.youtube.com/watch?v=E7Q8V1F1zSQ...feature=related
I've read that handing a left-handed violin to a right-handed player is an excellent technique for demonstrating the difficulties of the new student of the instrument, and may make teachers (and others) more sympathetic to, and aware of, the inherent difficulties.
For all the techniques that you may have developed for playing the "right" way will be of no use at all. It does not translate to a body that has never attempted such a feat. Perlman will be instantly transformed into, well, me, for example.
You can only carry on a discussion of symmetry vs. asymmetry so far before attention spans are exceeded.
[P.S. What's goin' on with that 'Symmetry' thread ... is it the car-buffs or blue&white scooter aficionados running-up the "Views" ? It's just crazy, Man ... CRAZY !] B)
Whoa, I hadn't noticed....... 28 thousand "views" of that thread? :)
I wonder if a bunch of "scooter trash" sites linked to it? :)
Or the people from www.HillmanImps-can-kick-your-azz.com :)
Might be Yacey's jet truck too. Are you bringing that to the VSA convention, Bill? It could go in the "innovation" exhibit. Might get an award too.
Maybe Jeffrey has access to web stats like "referrers" and can find out.
A lot of Cape Breton fiddlers play this way; Ashley MacIsaac is probably the most famous (or infamous) of the bunch but there are a lot of others. It's a solo fiddle tradition so there's a lot of room for individuality. You can't tell from listening that they're playing LH but it sure looks odd to watch them! -Steve
