celticcello Posted September 18, 2007 Report Share Posted September 18, 2007 Hi My mind is always curious about stuff that matters to virtually no one but me (ha!) Question: why would, say, a small 1/4 'cello sound different than, say a large 21" vertical viola? Is it the string length, the scale length, the string gauge, the rib depth? Maybe this is a question for the builders out there, but I started wondering what actually makes an instrument's tone different assuming the body length is equal. Thanks Jill San Francisco Quote Link to comment Share on other sites More sharing options...
Joseph Sellers Posted September 18, 2007 Report Share Posted September 18, 2007 I don't think I entirely understand your question but I think that you should note that there is an octave difference between a cello (regardless of size) and a viola (regardless of size). Also a cello in the fractional sizes never truly has the "cello sound", that requires the full length of string and the full size of body. I hope this helps if it does not answer your question. Joseph Quote Link to comment Share on other sites More sharing options...
celticcello Posted September 18, 2007 Author Report Share Posted September 18, 2007 Hi Joseph, So, I guess to clarify. Given two instruments of the same body length, why don't they sound the same? Perhaps the answer is: the string gauges are different so as to be able to tune the "small cello or large viola" to the appropriate octave? I guess it's a crazy question. I sort of have the mind of a physicist with the knowledge of an amateur musician! Jill Quote Link to comment Share on other sites More sharing options...
Joseph Sellers Posted September 18, 2007 Report Share Posted September 18, 2007 The difference is just that, there is an octave difference in the same size of body. Quote Link to comment Share on other sites More sharing options...
JCHungerpiller Posted September 20, 2007 Report Share Posted September 20, 2007 It is my understanding that an instrument sounds like....well "what it is" because of its particular and specific "overtones." Sound is nothing more than vibrations in the air. However the sound heard is a combination of the: fundamental (frequency-->vibrations per second or hertz) that determines the pitch of the note and the overtones which may be in perfect integer ratios (ex. 4th,5th, octave above) in which case they are called harmonics or non-perfect integer ratios--> inharmonic. The combination of all the overtones extending from the fundamental upwards out of the range of human hearing, (the overtone series) heard simultaneously, creates what we hear as a trumpet or oboe or violin. It is also what would make one violin sound different from another. So while the octave tuning makes the cello and viola "sound" different due to the pitch...playing the identical pitch would still sound different. I find this material a bit complicated and I am sure that there are others here who can explain it in different and perhaps more clear language. I hope this helps (it has helped me in forcing myself to write it down:-)) John Quote Link to comment Share on other sites More sharing options...
Joseph Sellers Posted September 21, 2007 Report Share Posted September 21, 2007 Hats off to you John, your reply was better written and more informative than mine, thanks a lot. Joseph Quote Link to comment Share on other sites More sharing options...
JCHungerpiller Posted September 24, 2007 Report Share Posted September 24, 2007 Thanks Very neat stuff this...I still think we have much to learn re why one violin sounds so different from the next. Cheers Quote Link to comment Share on other sites More sharing options...
Joseph Sellers Posted September 24, 2007 Report Share Posted September 24, 2007 Yes its neat, I suppose that's why we're here, right? Always learning, there is so much to learn! If you think about it there is so much to learn about sound, music, violin, wood, and varnish. The possibilities are endless. Thank you John Quote Link to comment Share on other sites More sharing options...
