polkat Posted May 6, 2007 Report Posted May 6, 2007 I've been using this ground successfully for a while now, so this is not a technical question. Rather, from the (admittedly limited) research I've done, it seems that only Sarconi's (sp?) book references VB as a ground used specifically by luthiers during the golden period. Has anyone seen other references to this ground as used by past luthiers (not painters)?
MANFIO Posted May 6, 2007 Report Posted May 6, 2007 Sacconi had the opinion that Stradivari used it. He identified a substance inside well preserved Stradivari instruments that is water soluble. Sacconi's ideas about varnish changed every week, according to many. I use VB inside my instruments . Egg white was used as a painting medium known as "tempera". The ground subject is a highly controversial one.
polkat Posted May 7, 2007 Author Report Posted May 7, 2007 Are there any other older texts that mention it? Just Sacconi?
mcarufe Posted May 7, 2007 Report Posted May 7, 2007 I question the soluability of egg white once it has cured. Other components of a vernice biancha i.e. honey, gum arabic would be more so. Mike
Magnus Nedregard Posted May 7, 2007 Report Posted May 7, 2007 It has to be remembered that the "vernice bianca" is just a variation on egg tempera, on of the most widely used mediums in the world since ancient times up until today. Egg tempera in various forms is mentioned hundreds, probably thousands of times in old texts and recipes, and in modern artists books' too. Only some violin geeks in their little dark workshops thinks "vernice bianca" is some magic recipe only for violins.
Bruce Tai Posted May 8, 2007 Report Posted May 8, 2007 Sacconi believes that Stradivari used vernice bianca in two places: between the color varnish and the ground, and inside the plates. I don't think he had very solid analytical evidence. AFAIK, the only chemical analysis performed on the unvarnished side of the plate is by Tove and coworkers. They were looking for inorganic elements and did not look into protein coatings. Condax and Baese have reported protein interlayers above the ground and under the color varnish, but what exact experiments they performed I am not sure. What protein is used is also uncertain. Condax has obtained mixed results from amino acid analysis: collagen glue or egg white. It is quite likely that the protein interlayer is real, but the evidence for gum arabic, sugar and honey seem to be missing. As for the historical use of egg white by artists, I can't remember all the details right now. I will consult the books of Eastlake, Thompson, Cennini, Theophilus and Laurie again to refresh my memory.
Dean_Lapinel Posted May 8, 2007 Report Posted May 8, 2007 Bruce! I had no idea you collected those books. Nice selections. Are you planning on increasing your collection? Are you an artist? PM me - I can tell you about other books if you are going that route. Dean
Dean_Lapinel Posted May 8, 2007 Report Posted May 8, 2007 Magnus states correctly the fact that there are many variations of tempera but most of them include the yolk as the primary ingredient since the egg white dries too fast. If you use the white as well, other modifiers were usually used.
MANFIO Posted May 8, 2007 Report Posted May 8, 2007 During the Renassance in Italy it was quite fashionable for artist's publishing "tratatti" about their craft. Cellini did that, as well as Ceninno Ceninni and Lionardo da Vinci. There is a shop in Florence called "Zecchi", they sell artist's products, I remember they advertise they have ALL products mentioned in Ceninno Ceninni's "Il Libro dell"Arte", dated 1437, I think.
Bruce Tai Posted May 8, 2007 Report Posted May 8, 2007 quote: Originally posted by: Dean_Lapinel Bruce! I had no idea you collected those books. Nice selections. Are you planning on increasing your collection? Are you an artist? PM me - I can tell you about other books if you are going that route. Dean I got these books in order to write my review of scientific studies on Cremonese varnish. Cremonese varnish is related to oil painting in many ways, and that's why I got interested in the early development of oil painting. Unfortunately, there seems to be just about as many controversies surrounding Van Eyck's painting technique as Stradivari's varnish. The oil-varnish mystery in old paintings is even more hotly debated than in old violin varnish, which I found extremely intriguing.
Bruce Tai Posted May 8, 2007 Report Posted May 8, 2007 quote: Originally posted by: MANFIO During the Renassance in Italy it was quite fashionable for artist's publishing "tratatti" about their craft. Cellini did that, as well as Ceninno Ceninni and Lionardo da Vinci. There is a shop in Florence called "Zecchi", they sell artist's products, I remember they advertise they have ALL products mentioned in Ceninno Ceninni's "Il Libro dell"Arte", dated 1437, I think. The store you mentioned sounds incredible. Cennini's book made multiple mentions of vernice liquida, which literally means liquid resin. Vernice meant amber originally, then other resins resembling amber. Because resins are solids, resins dissolved in oil are called vernice liquida. I would love to know what the Florence store puts into its vernice liquida, is it amber, copal sandarac or turpentine?
Magnus Nedregard Posted May 8, 2007 Report Posted May 8, 2007 I think the Colorificio Zecchi is quite open about these things, you could probably just call them, as far as I am aware of they aren't on the internet. They have very nice linseed oil! It is true that egg yolk was favoured in the tempere for painting, it is fattier so it dries more slowly, and makes colours more opaque. But I think egg white also was used when the coat needed to be clear, and in combination white pure white colours. Just to mix it with water makes it dry a little slower, but some mixed it with a little bleached linseed oil as well. I never use honey in the VL, I don't think it is needed at all, and honey is a substance that varies wildly, you never know what it does.
polkat Posted May 8, 2007 Author Report Posted May 8, 2007 Well, the term vernice translates directly to varnish, without specifying amber. Vernice bianca in Italian translates directly to varnish white, or white varnish, without specifics on varnish ingrediants. Since the art of making varnish from amber didn't gain widespread use until just about the time Strad died, I'm not convinced that the word vernice always means amber varnish. The word vernice goes further back, and I think the idea of egg white as a varnish, regardless of how used, goes further back as well. I think the words vernice bianca may have started as a general term for one kind of tempera. I've never thought of vernice bianca as a violin only medium (which is partially why I started the thread). But, in fact, violin work is the only place I've ever heard the term.
MANFIO Posted May 8, 2007 Report Posted May 8, 2007 Ferbose, Zecchi has the raw materials mentioned by Ceninni, not ready made products. It's a charming place indeed Magnus, many many art restorers getting so many different products, Florence is a marevelous place indeed. By the way Magnus, there is an interesting discussion in the violin making Italian forum (Claudio Rampini) about varnish, tempera, etc. Ferbose, what about learning Italian? Ciao!
fiddlecollector Posted May 8, 2007 Report Posted May 8, 2007 There are English recipes for `white varnish `,from the 16th century, that are basically spirit varnishes with several resins in.
MANFIO Posted May 8, 2007 Report Posted May 8, 2007 I think that the translation for "vernice bianca" would be "colourless varnish", the oposite of "vernice colorata", but I may be wrong.
fiddlecollector Posted May 8, 2007 Report Posted May 8, 2007 Manfio, i think the term white,when applied to varnish is the same has colourless.
MANFIO Posted May 8, 2007 Report Posted May 8, 2007 Yes fiddlecollector, I was trying to say that: bianca=colourless.
Bacon Posted May 8, 2007 Report Posted May 8, 2007 "There are English recipes for `white varnish `,from the 16th century, that are basically spirit varnishes with several resins in." fiddlecollector,could we have a source on this please.
fiddlecollector Posted May 8, 2007 Report Posted May 8, 2007 I`ll try and find the reference on the web, i recently lost my hard drive so dont have the link any more.
DarylG Posted May 8, 2007 Report Posted May 8, 2007 quote: Originally posted by: polkat Since the art of making varnish from amber didn't gain widespread use until just about the time Strad died... What evidence do you have to support this? There are many recipes for amber varnish that pre date Strad's death. I'm not claiming that amber varnish was used by Stradivari, just that it did exist. Ferbose, According to Donald Fels: "...amber or hard resin varnishes is representative of a number of versions of varnish listed under the heading of Vernice Liquida E Gentile. This term is used to separate amber varnishes of this type from the common varnish listed as Vernice Liquida made using the softer resins Sandarac, Juniper Gum and Frankincense."
Bruce Tai Posted May 8, 2007 Report Posted May 8, 2007 The evolution of the word vernice is studied in great detail in Eastlake's book (Methods and Materials of Painting of the Great Schools and Masters). It is a very complex subject, and reading hundreds of pages of discussion by Eastlake really clarifies it. He clearly explains why vernice liquida means a vernice (some kind of solid resin) that is liquefied (dissolved in a liquid). The best discussion concerning egg white, honey and gum arabic I have seen is in Thompson's book (The Materials and Techniques of Medieval Painting). He goes into practical details and rationales. Beating egg white to perfection was considered a specialized craft in those times. BTW, from everything I have read, I find the amber (I mean real amber, the fossil resin) varnish debate to be as hopeless as it was 200 years ago. There are always historical documents to say that it was available and used. But all practical considerations indicate that it was expensive, difficult to make and rarely available. Experimental evidence showing it in Italian varnishes is not available. Only Baese showed one electron micrograph (in the newsletter to his book) of a varnish sample claiming that it contains amber. In my opinion there is no way that the electron microscopy could identify amber. I really wish to be enlightened on this subject a bit more.
DarylG Posted May 8, 2007 Report Posted May 8, 2007 Hi Ferbose, I agree with much you have written, and it's well known to most Maestronetters that you are well read on the subject of varnishes. I myself am most certainly not an expert on classic Italian varnish and will likely never have the opportunity to become one. Very few have the regular exposure to these instruments and the educational background necessary to make any real claims. However, I would like to say that I don't agree with your notion that amber varnish is difficult to make. I make amber varnish and it's no more difficult than many other varnishes. I agree that amber was likely very expensive and prized pieces scare (not much has changed!), but amber varnish can be made from the smallest of pieces that surely would have been far less valuable. Again, I'm not trying to make any claims about amber being used in classic Italian varnishes, however I can say that it makes an excellent varnish and is superior to many of the other varnishes I've experimented with thus far. It's also fun to make something today using something that is prehistoric. Cheers,
Oded Kishony Posted May 8, 2007 Report Posted May 8, 2007 Hi Daryl, I've been making varnishes for many years but have never had success making an amber varnish, can you give us an outline of how you do it? My vote is that amber was not widely used, mostly because of the expense and the readily available and excellent alternatives. Oded Kishony
Magnus Nedregard Posted May 8, 2007 Report Posted May 8, 2007 Hm, I suspect many believed they used amber varnish...
