TomCumpston Posted April 23, 2007 Report Share Posted April 23, 2007 I bought a nice piece of wood at an antique shop. Finding sides to match has been a problem. So I'm trying to coax sides out of the interior of the back. Has anyone ever done this and if so do you have any pointers? So far My plan go like this. I'm using a 1/8 down cut bit from stew mac and have routed a 3.5mm deep channel 2 7/8 wide by 12 1/16 long next i'll remove the wood outside of the rectangle then use a thin blade saw to cut out the sides out THEN i'll have to saw/split the 3.5mm thick slab into the sides proper. it sounds ambitious but i think it's possible in theory, i hope. Quote Link to comment Share on other sites More sharing options...
andrew weinstein Posted April 23, 2007 Report Share Posted April 23, 2007 Inspired thinking, but I can't see you'll have much room at the upper/lower block area. You may destroy the back in the process. You ought to be able to find ribs to use, even if they don't match perfectly. Quote Link to comment Share on other sites More sharing options...
MANFIO Posted April 23, 2007 Report Share Posted April 23, 2007 I think it's risky, you may loose that fine wood... Perfectly matched wood for back, sides and neck is a modern obssession, I think. Del Gesù rarely did that, in most of the cases the ribs and scroll were made with different (and less figured) wood. The use of a long one piece rib for the lower bouts (longer than the back wood and quite commom in Cremonese violins) may point out to the use of a wood different of that used in the back in most of the cases. Quote Link to comment Share on other sites More sharing options...
TomCumpston Posted April 23, 2007 Author Report Share Posted April 23, 2007 thanks for the input andrew. For better or for worse the deed has been done. There is enough room to fit the end blocks however there is no gentle slope to those platforms its a straight drop off. Do you think this will be an issue? if so i guess i could add some plan wood to thos areas Quote Link to comment Share on other sites More sharing options...
fiddlecollector Posted April 23, 2007 Report Share Posted April 23, 2007 It sounds like a mad idea, i cant possibly figure out how your going to get the wood out.If it is possible to get the wood out , a slight deviation in grain parallel to the plane of the back and you,ll end up withfire wood. Ive never heard of anyone attemping to do this. Quote Link to comment Share on other sites More sharing options...
COB3 Posted April 23, 2007 Report Share Posted April 23, 2007 As you have already proceeded, this will not help much; but I helped/watched Michael Klein once, as he cut a viola back out of a cello back. He placed one half at a time of the cello back in a vise, and used a frame-saw to cut a curve out of the area that would become the interior. He just stayed inside the projected pencil lines that described the interior of the cello, and sawed out a viola that not only matched, but was the exact same piece of wood. It was a lot of work, and risky, as others have pointed out. But it did work-- You have gone about it in a different way...I hope it works out for you-- that is a really lovely piece of maple. I would have simply sent that photo around to a number of wood suppliers, and asked whether they had a set of matching ribs, and a neck. Quote Link to comment Share on other sites More sharing options...
TomCumpston Posted April 23, 2007 Author Report Share Posted April 23, 2007 My measurments seem to be ok and there is a little extra room at the block platforms but not much. I rigged up a little saw to do the work. but it is going to take a long time if i go this route. appreciate all the comments. I think I'll stop now before I really mess something up. can someone direct me to a supplier that would be able to match this wood. please!!!!! p.s. here's a kicker I only paid $25.00 for it Quote Link to comment Share on other sites More sharing options...
COB3 Posted April 23, 2007 Report Share Posted April 23, 2007 Do you have any idea what kind of maple it is supposed to be? European/American? There are a number of possibilities, but it would help if you knew that much. Bruce Harvie of Orcas Is. Tonewoods might be a good start, just because he has a very good eye for wood...if he doesn't have anything himself, he may be able to tentatively identify the wood, and give you a list of possible suppliers. If I were doing it, I would send that photo to several suppliers, and ask if they can match it, for neck and ribs. I'd ask them to send me a photo of what they have, then make a choice, and get going. You have the beginnings of a gorgeous violin there. It does not have to be a perfect match..."close" is nice, though. I have some sets where the neck, sides and back were all cut from the exact same board (I know because I cut them)--but you can't tell for sure by looking-- the grain/flame variations within the single board were enough to make them not really "match". Good luck with it. Quote Link to comment Share on other sites More sharing options...
TomCumpston Posted April 23, 2007 Author Report Share Posted April 23, 2007 thank you cob3 i'll get a hold of him and find out. Quote Link to comment Share on other sites More sharing options...
fiddlecollector Posted April 23, 2007 Report Share Posted April 23, 2007 Looks like American bigleaf maple Quote Link to comment Share on other sites More sharing options...
fiddlefaddle Posted April 23, 2007 Report Share Posted April 23, 2007 I can't count the times I have tried to get two pieces of wood from one piece, and ended up with no pieces Quote Link to comment Share on other sites More sharing options...
NewNewbie Posted April 23, 2007 Report Share Posted April 23, 2007 "Finding sides to match has been a problem." - tommyc This would appear to also have been the case with Stradivari and Lads Inc., so some of the time, he just used what he had kicking around. Seemed to work okay for him. When I first saw your picture, I thought this was about inside arching first. Quote Link to comment Share on other sites More sharing options...
ChrisBurt Posted April 23, 2007 Report Share Posted April 23, 2007 quote: Originally posted by: fiddlefaddle I can't count the times I have tried to get two pieces of wood from one piece, and ended up with no pieces Ouch, that brings up bad memories. I second the vote to get wood from another source. Uhm, how much wood is left at the router cuts near the end blocks? Quote Link to comment Share on other sites More sharing options...
TomCumpston Posted April 23, 2007 Author Report Share Posted April 23, 2007 21mm of platform. 3mm of overhang. 1mm for sides. leaves me 14mm for the upper block. with 3mm to spare. I imagine that's pretty tight. Quote Link to comment Share on other sites More sharing options...
ChrisBurt Posted April 24, 2007 Report Share Posted April 24, 2007 Actually, I was thinking about the wood that remains between the surface at bottom of the router bit to the outside surface of the plate-- the thickness of the back plate just in from the end blocks. Have you carved the back arching yet? If not, The depth of the router cut near the blocks may influence how far you extend the long arch of the back before cutting the recurve. Quote Link to comment Share on other sites More sharing options...
catnip Posted April 24, 2007 Report Share Posted April 24, 2007 Very interesting and challenging idea. If you can separate the back into two pieces again you might have chance to cut out your strips. I would mount each piece in a machinist drill vise so the the piece is perfectly vertical and find a small drill that is long enough to drill down into your channel . Then carefully drill holes along the line to the depth of your routed channel. The smaller the drill the better, but it must be long enough. Also instead of drilling you can try to use a FEIN multi-master tool that can do this kind of cut (vibration cutter) You just have to set up a jig so that you can cut it perfectly parallel. I would not trust my hand although I have seen craftsmen make this kind of cut by hand. By the way the Fein multi-master tool is not cheap... (rent or borrow one if you can) Quote Link to comment Share on other sites More sharing options...
