adzarkos Posted February 11, 2007 Report Share Posted February 11, 2007 I'm having some issues with my lame 4th finger lately. The vibrato on that finger has never sounded consistent with other fingers, all notes I play with the 4th finger seem to "smudge" into others, if that makes sense at all. I'm constantly re-working fingerings to avoid the 4th finger, but I'm ready to attack it. Any suggested etudes, etc? Any tricks, practicing techniques that anyone can suggest? It's driving me crazy, and I'm ready to put it behind me. Quote Link to comment Share on other sites More sharing options...
oldgeezer Posted February 12, 2007 Report Share Posted February 12, 2007 Those pinkie trills in Kreutzer No.16 are good for you. It makes that pinkie work. It's your weakest finger. There's a tendency to not give notes played with your pinkie enough bow so watch that you don't combine a weak finger with weak bowing. Quote Link to comment Share on other sites More sharing options...
Shirl Posted February 12, 2007 Report Share Posted February 12, 2007 Ad - a fantastic professional violist once told me that it acceptable to use the third finger along with the "pinkie" for vibrato, if necessary. Only this does not address your question regarding the weakness in your fourth finger. Quote Link to comment Share on other sites More sharing options...
Valoe7 Posted February 12, 2007 Report Share Posted February 12, 2007 I read that on some magazine too, but sadly I don any books. I only know that help you get used to it or get it in tune. Quote Link to comment Share on other sites More sharing options...
technique_doc Posted February 12, 2007 Report Share Posted February 12, 2007 Hi adzarkos, I know this problem all too well. The technique I teach is for the hand to be set quite high on the neck of the violin (the base of the 1st finger is level with the top of the fingerboard*), so when the fingers curl over to play notes the 1st is a tiny bit downwards, the second approx level to the f'board and so on. The "attitude" of your hand to the fingerboard is crucial. With my young players, I often get them to bring (turn) the hand more in towards the f'board and tap a few pinkies (roughly in place) before playing scales or the 4-5 notes patterns that all my pupils are drilled in. Try, if possible to maintain the arched shape in the pinkie and actually watch it go down when practising a few notes out of a passage. Having a small surface area means you have to be really accurate putting the finger down. Do whatever you need to get some "wiggle" even if it's not textbook vibrato and don't forget that many good players swap the 4th for 3rd when resting on long expressive notes high on the violin. T_D * good/experienced players know the value of not having the fingers too high, I know, but more arched = more clean press. Quote Link to comment Share on other sites More sharing options...
DocFidlStix Posted February 12, 2007 Report Share Posted February 12, 2007 I too have labored under a weak pinkie. I've strengthened mine a lot by squeezing the exercise balls you can buy from sports stores and the sporting goods sections of places like Wal Mart. Don't expect results overnight. If you set up a schedule of squeezing several times a day, with emphasis on pushing the pinkie into the squeeze ball as hard as you can, you should start tp see results in a month. Good luck! Quote Link to comment Share on other sites More sharing options...
pandora Posted February 12, 2007 Report Share Posted February 12, 2007 There are great "hard" etudes out there for fourth finger work, but I also like using easier ones played faster -- or even simple etudes that were originally meant for open strings, with fourth substituted in. Wohlfart is great -- start with the third one in the Schirmer Op.75, the one that starts gbed cbag #fgag #fdef.... Play it wicked fast and really get that fourth finger clicking. If you do it with slurred bowings, you won't be able to hide mushy fourth action with a bow change. Actually, pick any etude or even a fiddle tune you like -- find something with that you truly know, with lots of eighth notes that run along at a good clip, that flows easily from your mind so you have mental/physical room to work on the 4th finger issue. One of my students licked this by playing celtic tunes with NO OPEN STRINGS for a solid week. Sorta torturous but it worked. Quote Link to comment Share on other sites More sharing options...
Bill Merkel Posted April 10, 2017 Report Share Posted April 10, 2017 I agree with Dounis that the concept should be to acquire the "feeling of balance" between all the fingers, instead of directly trying to strengthen weak fingers. I think Dounis Op. 23 is good for that, if you follow his instructions exactly. Also those exercises where you leave some fingers down and raise and drop others are good. There are many of them. Some of the more strenuous ones you should only do once a day, and last thing of the day. A 4th finger that works is very handy! Quote Link to comment Share on other sites More sharing options...
Omobono Posted April 11, 2017 Report Share Posted April 11, 2017 On 2/12/2007 at 0:04 PM, Shirl said: Ad - a violist once told me that it acceptable to use the third finger along with the "pinkie" for vibrato, if necessary. This was the way I was going to address the question too. It doesn't mean you will have to use the two fingers in tandem indefinitely but may just give you a sense of support and security. (I presume we are talking violin here? It's more an issue for me on viola.) I would like to here a cellist or bassist's view on this because it occurs to me it is more a part of their regular technique? Am I right? Quote Link to comment Share on other sites More sharing options...
Rue Posted April 11, 2017 Report Share Posted April 11, 2017 If it matters ...this is a 7 year old thread. Quote Link to comment Share on other sites More sharing options...
Rue Posted April 11, 2017 Report Share Posted April 11, 2017 Double post. Quote Link to comment Share on other sites More sharing options...
