henrypeacham Posted August 17, 2006 Report Share Posted August 17, 2006 As an informal poll, how many, apart from the 4-fine-tuners-on-a-tailpiece folks, use an A-string fine tuner in addition to the E string one? Or perhaps better stated: How many use two fine tuners? Quote Link to comment Share on other sites More sharing options...
FINPROF Posted August 17, 2006 Report Share Posted August 17, 2006 I have one violin that uses two fine tuners and one that uses one fine tuner. Each came that way when I bought them and didn't change the fine tuners. I bought the one with two fine tuners in Bulgaria. The one with one fine tuner was made in the USA, or at least finished by an AMerican luthier. I think that two fine tunders is common in Eastern Europe as are steel A and E strings combined with gut or synthetic G and D strings. Quote Link to comment Share on other sites More sharing options...
FutureConcertmaster Posted August 17, 2006 Report Share Posted August 17, 2006 I used 4 for a long time but they aren't extremely useful on the G and D string. So I took of those, but then after a while I took of the A (for what reason I dont know.) But now I only have the E. I couldn't imagine tuning without it. What fun it must be to have a baroque violin . Quote Link to comment Share on other sites More sharing options...
Winston Posted August 17, 2006 Report Share Posted August 17, 2006 That set-up (using fine tuners on both the E and A strings) was very common prior to 1970 or so, especially with students. Unless you were using all-metal strings, the G and D were gut wound --and a fine tuner wasn't needed. The metal E always needed one, of course. But in the case of the A string, a few old-timers would still use plain gut, otherwise, it was either a metal A or a gut wound A. The gut wound A's typically had a short life span and required constant tuning. As a student in the 1950's, I started with all steel strings and four tuners for the first year, and then switched to the 2 tuner set-up. It was only after I was quite advanced before using a gut wound A. I still have one instrument with this set-up, but I usually now use a Tonica A with gut wound D and G. The sound that I want can come only from gut, in the case of the D and G strings. But for the A string, the difference seems less critical. Quote Link to comment Share on other sites More sharing options...
Poppiviola Posted August 17, 2006 Report Share Posted August 17, 2006 One of the violinists at my university uses a fine tuner on the A string, he's from Bulgaria, so I would tend to think along with FINPROOF that this is more common in Eastern Europe. Quote Link to comment Share on other sites More sharing options...
Danielle Posted August 18, 2006 Report Share Posted August 18, 2006 I think its not always where your from, but what string combos you use. Its not nessesary to have to fine tuners if you use a gut or synthetic A, it tunes fine with the pegs. with steel or metal string, the fine tuner is almost crucial Quote Link to comment Share on other sites More sharing options...
FutureConcertmaster Posted August 18, 2006 Report Share Posted August 18, 2006 I agree with Danielle it is based somewhat on the type of strings you have. But it is also based on personal preference. I know one person that refuses to use ANY fine tuners. But I think that is their loss and they are crazy. Quote Link to comment Share on other sites More sharing options...
DutchViolins Posted August 18, 2006 Report Share Posted August 18, 2006 Henry, This question does not say so much because it's totally dependent on what type of string you have. As Danielle said: gut strings don't need a fine tuner. What is left are steel strings: and all that have these strings use a fine tuner mostly four. The answer on the initial question when only steel strings are taken into account must be: hundreds of thousands. Quote Link to comment Share on other sites More sharing options...
Andrew Victor Posted August 18, 2006 Report Share Posted August 18, 2006 The A tuner is helpful in orchestra (and performance) situations to quickly retune slight changes that may have occurred. There are a few female viruosi who use them (Mutter and maybe Chang). I was always a one-tuner (E) violinist, but I did switch to Bois d'Harmonie tailpieces as I approached age 70 to make small tuning changes easier when my joints hurt. I probably still do 90%+ of my (non-E) tuning with the pegs. But those other fine tuners have come in handy under tho hot stage lights. Andy Quote Link to comment Share on other sites More sharing options...
Danielle Posted August 18, 2006 Report Share Posted August 18, 2006 chang doesn't use one, I saw her last year Quote Link to comment Share on other sites More sharing options...
Violon Posted August 19, 2006 Report Share Posted August 19, 2006 I use none and I'm not crazy! I have 'perfection' pegs, (gear driven) which renders tuners useless and I love them! Quote Link to comment Share on other sites More sharing options...
gypsky Posted August 20, 2006 Report Share Posted August 20, 2006 I only use a tuner on my e string. The other strings, dominants, don't need a fine tuner. One trick is to put the string on the same way each time; so the fingers lay on the flat part of the peg, then it is very easy to turn with the left hand. Quote Link to comment Share on other sites More sharing options...
johnny34 Posted August 22, 2006 Report Share Posted August 22, 2006 Knilling perfection pegs on all 4... nothing else.... works perfect 34 Quote Link to comment Share on other sites More sharing options...
Steve_W Posted August 23, 2006 Report Share Posted August 23, 2006 quote: Originally posted by: Winston That set-up (using fine tuners on both the E and A strings) was very common prior to 1970 or so, especially with students. Unless you were using all-metal strings, the G and D were gut wound --and a fine tuner wasn't needed. The metal E always needed one, of course. But in the case of the A string, a few old-timers would still use plain gut, otherwise, it was either a metal A or a gut wound A. The gut wound A's typically had a short life span and required constant tuning. I began learning in the 1960s and used that setup for many years. It worked well but because of the steel A I never learned to tune my A string "properly" i.e., with the violin in position, manipulating the peg with the LH fingers. Still can't do it, but I use a Pusch tailpiece with 4 fine tuners with my synthetic strings so it's not typically an issue! Quote Link to comment Share on other sites More sharing options...
