fidleir Posted June 29, 2006 Report Share Posted June 29, 2006 I've recently repaced a top on a fiddle which was always too dull and fuzzy. The new top has brightened the fiddle a little.The other day I tuned up a half tone (a practice common amoung Irish players when playing alone,) the subsequent brighter tone is often preferred to concert pitch.I was very very pleased with the resultant tone on this fiddle. bright, sweet and ringing.My question is this is there a way by changing gauge or certain strings that give this effect at concert pitch?I'm using helicores (medium gauge) Quote Link to comment Share on other sites More sharing options...
andy989 Posted June 29, 2006 Report Share Posted June 29, 2006 Yes--try heavy-tension strings. Helicore strings are available in heavy tension. Quote Link to comment Share on other sites More sharing options...
vmhuang Posted June 29, 2006 Report Share Posted June 29, 2006 Thicker strings have higher tension. Adjusting string after length can also affect the tension. Quote Link to comment Share on other sites More sharing options...
Andrew Victor Posted June 29, 2006 Report Share Posted June 29, 2006 Changing string afterlength would affect tension only because of increased or decreased distance from nut to bridge. But it is a thought! Andy Quote Link to comment Share on other sites More sharing options...
Selim Posted June 29, 2006 Report Share Posted June 29, 2006 "--The other day I tuned up a half tone (a practice common amoung Irish players when playing alone,) the subsequent brighter tone is often preferred to concert pitch.I was very very pleased with the resultant tone on this fiddle. bright, sweet and ringing--" I think your violin is good and still has more potential then revealed now. Increasing tension may help, but still It will be brighter and better when you tune it up half tone or so. Playing the violin with heavy bowing after It is tuned up by a full note for a while might help or thinner bridge may help too, I may be wrong. I am sure break in will help a lot. Over thinned violins will choke or loose quality in sound when they are tuned up by half note. Quote Link to comment Share on other sites More sharing options...
