Bracing blocks
Fiddlefun
I have recently acquired a 1957 Frederick Weller.  There is a
nice write up on Weller in Henley's but it does not really describe
much of his work.  My question is that this violin has a brace
on each of the upper and lower blocks.  The braces are
attached to the tops of each block and then diagonally down to the
back.  The braces are about 3  inches long,  I've
never seen or read of any such braces.  The instrument has no
damages that would explain this.  The instrument is nearly
mint with almost no wear.  The fingerboard shows no signs of
any use at all, so I suspect that someone recently attempted a set
up.  I don't know how it sounds as it has not been set up
since I acquired it.  But I can only imagine that these braces
are going to have a negative affect on tone.  Does
any one have any knowledge of this practice or any information on
Weller?.
