Should I be concerned?
larkascending
Hello, I just received a viola today which I had commissioned by a
very well known American maker.
It is exquisite. However, the varnish is a bit smudged on the upper
and lower back as a result of being in it's case. I guess it was
put in the case before fully dry. (?) It isn't really "smudged" so
much as - well, under certain lights there is a slight imprint from
the cloth of the case.
Should I be worried, or do anything about it?
Thank in advance for your esteemed advice!!
Hmm, come to think of it, I tried out an instrument form the maker
before, and noticed the same thing. Just some teeny imprints -
nothing major, but noticeable to the trained eye. This was a newer
instrument but wasn't brand new like the one I have now. Can this
occur from using a certain kind of varnish or polish? If it's
softer than others will it more likely occur?
Thanks, Lark
