Thicknessing calipers
doug
Hello everyone!
Could someone please tell me where I can find a relatively inexpensive set of thicknessing calipers? I don't have the $250 to shell out for the .0001" accuracy model at the present. I would like a set that is large enough for violin and cello though. Thanks a lot!
Doug
: Hello everyone!
: Could someone please tell me where I can find a relatively inexpensive set of thicknessing calipers? I don't have the $250 to shell out for the .0001" accuracy model at the present. I would like a set that is large enough for violin and cello though. Thanks a lot!
: Doug
Doug,
I faced the same problem long ago. I solved it by buying an inexpensive dial indicator from Harbor Freight Company ( about $20) and mounting in on a wooden arm directly above a 1/4 inch dowel with a rounded off point on it. Set the indicator to zero with its stylus resting on the dowel and you have a very effective way to measure anything inserted between. By making the arm long, it serves for anything from a bass to a 1/32 violin. If you are handy with metal, you can make a more sophisticated version almost as easily. There is absolutel;y no reason for accuracy beyond .01", so don't worry about a high quality indicator. After all, Strad and his contemporaries were much more severely limited in their measuring ability. I use a conventional instrument caliper now, and it is handier, but if I hadn't traded for it, I'd still be using the homemade job. Something in me rebels at the obscene prices asked for simple tools. My first finger plane was a 32mm wooden bodied one that I made. I'd still be using it, too, if I hadn't lost it. Now I use brass-bodied professional tools that I don't like nearly as well.
Jake
:Jake has the right approach for those that find merit in this kind of thing. You might want to try another source for your dial indicators such as; MSC Supply, Production tool Supply or even Enco manufacturing. They offer a wider range of these "import" indicators and they also offer them in inch or metric format.
Best of Luck, Greg
: : Hello everyone!
: : Could someone please tell me where I can find a relatively inexpensive set of thicknessing calipers? I don't have the $250 to shell out for the .0001" accuracy model at the present. I would like a set that is large enough for violin and cello though. Thanks a lot!
: : Doug
: Doug,
: I faced the same problem long ago. I solved it by buying an inexpensive dial indicator from Harbor Freight Company ( about $20) and mounting in on a wooden arm directly above a 1/4 inch dowel with a rounded off point on it. Set the indicator to zero with its stylus resting on the dowel and you have a very effective way to measure anything inserted between. By making the arm long, it serves for anything from a bass to a 1/32 violin. If you are handy with metal, you can make a more sophisticated version almost as easily. There is absolutel;y no reason for accuracy beyond .01", so don't worry about a high quality indicator. After all, Strad and his contemporaries were much more severely limited in their measuring ability. I use a conventional instrument caliper now, and it is handier, but if I hadn't traded for it, I'd still be using the homemade job. Something in me rebels at the obscene prices asked for simple tools. My first finger plane was a 32mm wooden bodied one that I made. I'd still be using it, too, if I hadn't lost it. Now I use brass-bodied professional tools that I don't like nearly as well.
: Jake
