Music for violin and flute?
Elfrida
I'm looking for music for violin and flute with or without piano. So far I've found a small piece by Suk, Two Interludes and an Aria by Ibert, and two duos, one by Telemann and one by C Ph E Bach. Martinu's Madrigal Sonata is out of reach right now. Surely there must be more repertoire -- any suggestions?
A viola instead of the violin would be OK, too, if that helps. Thanks in advance!
Here are a few I pulled off a list for you:
Violin/flute
Berbiguier Duo concertant op. 76 #1
Boismortier 6 Sonatas, op. 51#'s 1-3
Boismortier 6 Sonatas, op. 51#s 4-6
Cambini 6 Duos op.14
Campagnoli Duet #1 in E
Campagnoli Duet #2 in A
Campagnoli Duet #3 in D
Gebauer 3 Easy Duos
Rolla 3 Duets
Flute/viola
Cambini 6 Duos, op 4
Devienne 3 Duos, op 5
There is the well-known trio by Beethoven for Flute, violin and Viola as well, of course.
Thanks!
I've found some Kuhlau works for two flutes and piano now. Thom, could you give me the name of a publisher or something for the pieces you were thinking of?
Omobono: great list! It turned out a friend had the Devienne pieces hidden somewhere, so I'm going to try them ASAP.
