magginicello Posted May 25, 2005 Report Share Posted May 25, 2005 I am relatively new to violin making and I have a chance to buy a variable speed 16inch scroll saw at a reasonable price. Is this a useful tool? Thanks Quote Link to comment Share on other sites More sharing options...
TSENGLO Posted May 25, 2005 Report Share Posted May 25, 2005 As I know, the scroll saw is not necessary for the violin making. However, you could not cut the plates right on the line anyway, you will have to use other hand tools to finish it. A 14" bandsaw is a much useful tool. I will see what other to say about this scroll saw. Quote Link to comment Share on other sites More sharing options...
ken_barlow Posted May 25, 2005 Report Share Posted May 25, 2005 I recently bought a vintage "Beaver Tools" scrollsaw off Ebay that I have used to cut out moulds, plate outlines and scroll blocks. It works extremely well, and I'm very pleased I bought it. I have access to a very high quality industrial bandsaw at work, and haven't felt the need to use this since I got the old beaver! Very important to select the right blade for the job,though. Quote Link to comment Share on other sites More sharing options...
David Tseng Posted May 25, 2005 Report Share Posted May 25, 2005 It would be more difficult to saw thicker piece of wood such as a neck block. I also would consider a 14" or larger band saw a necessity. Quote Link to comment Share on other sites More sharing options...
HongDa Posted May 25, 2005 Report Share Posted May 25, 2005 What's the cut-depth on it? Quote Link to comment Share on other sites More sharing options...
TSENGLO Posted May 25, 2005 Report Share Posted May 25, 2005 David tell that all, scroll saw will have difficulty on thick block such as neck. Bandsaw could do a lot of things and make life much easier. By the way, could anyone here tell me if I could use 14" bandsaw to cut my seasoned back to be a matched 2 pieces? What is the tips? or I have to send the maple back to a local lumber? Quote Link to comment Share on other sites More sharing options...
ken_barlow Posted May 25, 2005 Report Share Posted May 25, 2005 Sorry to disagree, but I found it easier to cut a neck block (a bit slower but much more accurate and therefore less clean-up) with the scroll saw. And the cost of a >14inch bandsaw is surely prohibitive for many (most?) amateur makers? I think the scroll saw is a highly underrated tool. Quote Link to comment Share on other sites More sharing options...
HongDa Posted May 25, 2005 Report Share Posted May 25, 2005 I was thinking the same thing for scrolls and that's why I asked the depth of cut.It would be handy having it around the shop if affordable. I recently bought a little 10 inch Rexon mini bandsaw for my shop. I was really surprised at it's cutting power and even got through a scroll with some struggle, but that's apparently because of the very low quality blades that come with it.with a proper blade I think it'll handle anything accept sawing ribs out of a larger piece of wood. Has anyone else here used one of these saws? [image][/image] Quote Link to comment Share on other sites More sharing options...
fiddlefaddle Posted May 25, 2005 Report Share Posted May 25, 2005 I favor a bandsaw. all the outline cuts are rough and MUST be finished with hand tools. power is the advantage , to enable the art of the knife . It is a mistake to cut the final outline with a power tool. I wondered why my scrolls were lifeless, until I began finishing that outine with a chisel and rasp Give me a 14" bandsaw with a 3/4" and a 1/4" blade. corner blocks are cut with a gouge. Quote Link to comment Share on other sites More sharing options...
DarylG Posted May 26, 2005 Report Share Posted May 26, 2005 Personally my choice would be a bandsaw. I've never seen a scroll saw with a fence or mitre gauge. Those things are very useful, especially for all the other stuff you end up making to make a violin. IMO with a bandsaw and drill press your all set in terms of machinery. Of course you can always cut out scrolls and resaw backs with hand tools but in my experience that's more like work and less like fun. TSENGLO: You can resaw violin/viola backs with a 14" bandsaw no problemo. With a riser kit and a bigger blade you could do cellos, but most cello wood already comes sawn. I use a 1/4" 6tpi blade for everthing. HongDa: My first bandsaw was just like that. I was able to resaw ribs with it after upgrading the blade. Quote Link to comment Share on other sites More sharing options...
nertz Posted May 26, 2005 Report Share Posted May 26, 2005 I have a scroll saw and a small bandsaw in my workshop, and a large bandsaw in a shed at the bottom of my garden. I bought the scroll saw some ten years before I ever owned a band saw because of very limited space, and have never regretted that choice. My scroll saw is far quieter then the band saw and for violin and viola scroll blocks much more accurate, for cello neck blocks you’ll not get away with a small bench top bandsaw anyway. It’s not great for cutting out plates, but nor would the little bandssaw be and I find doing that with a coping saw by hand is no problem and plenty fast enough. I still use the scroll saw over the band saw for making molds but where the band saw knocks the socks of the scroll saw is when it comes to opening up backs and cutting rib stock from a raw lump. In the end it will come down to space, noise and what you want a power saw for, but I’d say don’t underestimate the use of a scroll saw, for me when I had a very small work space it was a far better first buy then a band saw. Quote Link to comment Share on other sites More sharing options...
AMORI Posted May 26, 2005 Report Share Posted May 26, 2005 I use my scroll saw a lot. I have a furniture factory full of major machinery and seldom use a band saw for violin making. I do however use an overhead router to cut the outer shape of my plates. Quote Link to comment Share on other sites More sharing options...
HongDa Posted May 26, 2005 Report Share Posted May 26, 2005 Daryl, my Rexon came with very thin blades.I don't know if this was because they are cheap or because they need to be so thin for the smaller wheels. Will normal thickness blades work on these mini-saws? Quote Link to comment Share on other sites More sharing options...
violins88 Posted May 26, 2005 Report Share Posted May 26, 2005 The great thing about my 8 inch bandsaw is that the blade is very thin. This means that I can get many more ribs out of a piece of rib stock than I a 14 inch bandsaw would produce. Unfortunately, when you try to cut the outline of the plates on this little saw, you cannot move the plate like you need to for the whole outline. So, I now have a 14 inch bandsaw too. Quote Link to comment Share on other sites More sharing options...
DarylG Posted May 26, 2005 Report Share Posted May 26, 2005 HongDa: It's hard to find good blades for that saw as most of the good aftermarket blades don't come in sizes that small. Instead try finding someone to make you a blade, usually places that do tool sharpening will also make bandsaw blades. Quote Link to comment Share on other sites More sharing options...
Hackzaw Posted May 26, 2005 Report Share Posted May 26, 2005 I've got a 16" Delta variable speed scroll saw, and a cheap 8" Delta bandsaw. For years and years I only had the scroll saw and did lots of neat little projects (not violin related). But I got good at using the scroll saw. I found my scroll saw very useful for making lots of jigs and fixtures (often in the shape of a violin outline). With a good scroll saw, once you become talented and confident with it, you can dramatically reduce how much hand work you'll end up doing. I was able to cut my outlines in my fixtures to within 1/2 a mm or better. How's this for craziness....I cut my f-holes with my scroll saw. First I drilled the holes on a thicknessed plate, and then scroll sawed to join the holes. It was a bit nerve racking, especially when close to the thin wings. I would NOT do it again, as I'm sure I wasn't far off from breaking a wing off. My bandsaw is equally effective, but I find it's really only good for straight cuts. For example, you can zap off a million little blocks in no time flat for making the likes of little clamps. My true love is with the scroll saw (even though straight cuts are rather difficult. Quote Link to comment Share on other sites More sharing options...
tomroth Posted May 26, 2005 Report Share Posted May 26, 2005 I use this since ... well a very long time and found it very exciting. Not so easy to master it at the first time but when you succeed it's a real pleasure. Quote Link to comment Share on other sites More sharing options...
John_Jesseph Posted May 26, 2005 Report Share Posted May 26, 2005 Nice bowsaw Tomroth. Did you make it or buy it? How long is the blade? I have meant to make some bow saws, it's about time I do it... Quote Link to comment Share on other sites More sharing options...
tomroth Posted May 27, 2005 Report Share Posted May 27, 2005 John, To be honest, it's a pic I grabbed from the net as I do not have a digital camera yet, but mine is close to that one. If you are interested by making your own go here, you will find cool designs http://216.106.57.170/~dielle/designs.html other links http://www.hyperkitten.com/woodworking/frame_saw.php3 http://www.geocities.com/plybench/index.html Quote Link to comment Share on other sites More sharing options...
Michael_Molnar Posted June 14, 2005 Report Share Posted June 14, 2005 A bandsaw cannot negotiate tight turns like a scroll saw. A bandsaw is great for large cuts, but when you need detail work, a scroll saw cannot be beat. Quote Link to comment Share on other sites More sharing options...
AMORI Posted June 15, 2005 Report Share Posted June 15, 2005 I use my scroll saw a lot and it is especially handy for sawing neck blocks. After working with woodwork machinery for 30 odd years I still find the scroll saw one of the most difficult to use. But it sure is a handy tool. Quote Link to comment Share on other sites More sharing options...
