Stew Mac "Friendly Plastic"
Terry Maurice
Quote:
what is the temperature required to alter the shape?
One of the ads said 160 degree (F I believe). I use similar to hold silver/gold pieces togather for soldering (when no other mechanical holding will work). Softens in hot water. Takes oxy/acetelene well.
Regis
It looks like it functions very similar to “Dental Compound” which restorers have been using for making small counter forms with for years. I still have an unopened box of the stuff I bought when I left Machold almost fifteen years ago.
Get some. Looks just like this stuff I have and use quite often. I kept this one bisquit intact because it looks so nice!
I boil a pan of water, then let it set about 45 seconds.Throw in the compound until the water cools enough to reach in.Then work the compound in the water until it's soft enough.Working with those pellets the first time could be tricky until you get them built into a mass maybe.
[image]compound9xf.jpg[/image]
My experience with the stuff tells me that it's very resistant to crumbling or deforming, unlike the previously mentioned dental compound which is brittle. When it has hardened, its consistency seems similar to the white translucent plastic that is used for milk jugs. I've never tried pounding on it though.
Quote:
That stuff looks interesting, how hard would it set if used for large moulds (full violin plate sizes etc) and is it capable of standing up to heavy impacts like those in metal plate forming, without crumbling or deforming?
I have never tried but don't think you could make a very large cast with it. It starts setting quite fast after pulling it out of the water and you don't have alot of time to position it.....unless it were still very hot and I don't know if that's something you'd want to be laying over a violin top or back. It's also very brittle so wouldn't take an impact.
These are the properties of the stuff I have anyway. Maybe the "Friendly plastic" acts differently.
