Ribs & thickness scribe
Rich
I made this thickness scriber for marking the thicknesses on my ribs, having seen Michael doing something similar. Then I got my ribs in the mail today and they already are between 1.1 and 1.27 mm in thickness...so I won't even probably need to use it. What do you think of the concept...and is it normal to receive the ribs already that thin?
The plan was to adjust the depth first and lock it with the lock nuts, then pull it through. This is assuming the ribs are not too thick. I was going to use a toothed blade to bring it almost as deep as the scratches, then scrape the rest. I think Michael also ties his punch closed and does a similar thing...dragging the ribs through to scratch a mark. I saw a picture of him doing that.
Go to Michael's website and look up his photo journey on making a viola. Then look at the pictures on marking the rib thickness. The second picture that says something like "close up of the markings" will show you what I intended to imitate in my own way. Also, notice the flat plate the ribs slide on underneath. Now, keep in mind I have not tried this yet.
Rich.. the concept is right. But...The scribe is not only used for rib. It should be designed to handle all thickness markings, such as plate graduations. Michael's version will allow to punch little holes at the intended depth for plate graduation as well as thickness marking for ribs. Yours is a single purpose scribe: for rib only. You might want to modify your design a little to handle both jobs.
I'm actually going to make one like Michael's for thickness punching. I had intended to do that from the beginning. I just liked the idea of the flat plate for the ribs and am hoping it will hold the ribs flatter. I will try to make my punch out of metal also.
I see what you are saying now. Please allow me for a design suggestion here. How about adding a "sliding guide" for the rib? The guide's purpose could be holding the rib stock down and direct the rib movements. The sliding guide should also have the compability to adjust the thickness to handle different rib thickness.
