Ferrara Posted November 16, 2004 Report Share Posted November 16, 2004 The angle of the violin F/B should be such that the G and E strings can be easily reached. Some advocate planing the fingerboard itself at a slight slant and some say you may plane the neck at a slant. Any opinions Quote Link to comment Share on other sites More sharing options...
MANFIO Posted November 16, 2004 Report Share Posted November 16, 2004 I don't use any slant on my violins. Quote Link to comment Share on other sites More sharing options...
Michael Darnton Posted November 16, 2004 Report Share Posted November 16, 2004 Me too. Most of the players I've asked prefer it flat, not tilted either way. Quote Link to comment Share on other sites More sharing options...
obsessed Posted November 18, 2004 Report Share Posted November 18, 2004 Michael, I recently took my violin to a luthier who told me that my fingerboard did not have enough of an angle. What should the proper measurement be between the end of the fingerboard and the violin? Also how far should the strings be above the end of the fingerboard? Do you not put any angle on the fingerboard in relation to the violin, or are you talking about just the fingerboard itself? I hope you understand what I am getting at! I am not a violin maker, just a beginner violinist. Obsessed Quote Link to comment Share on other sites More sharing options...
Michael Darnton Posted November 18, 2004 Report Share Posted November 18, 2004 The topic here is whether the E-string of G-string side of the fingerboard should be higher--something you probably didn't even know to think about. :-) You're looking at the height of the board. At it's most basic, if your bridge is between about 32mm and 34mm high over the top at the center, that's about right. The strings, measured to the center of the string, should be about 3-3.5mm high for the E, and 5.0-5.5mm for the G. There's more to it than that, but that's it at its most basic. Quote Link to comment Share on other sites More sharing options...
