racerex Posted September 7, 2004 Report Share Posted September 7, 2004 I have two bridges for my violin, one is evenly rounded across the top and the other is higher on the left side and slopes downward on the right. Is there an advantage (for playing or sound) or disadvantage to using either one? Quote Link to comment Share on other sites More sharing options...
DougP Posted September 7, 2004 Report Share Posted September 7, 2004 Bridges are usually cut to give less string clearance at the fingerboard on the A and E side. Makes playing the A and E easier. The bridge needs to match the fingerboard extension. Some fingerboards are lower on the E side, and some warp downward. I would install the bridges and see which, if either, gives the best match with the fingerboard. A common string height is 5mm on the G and D, 3mm on the A and E. A mm less with steel strings. Quote Link to comment Share on other sites More sharing options...
racerex Posted September 7, 2004 Author Report Share Posted September 7, 2004 Very helpful information, thank you. Quote Link to comment Share on other sites More sharing options...
