Patrewski Posted May 28, 2004 Report Share Posted May 28, 2004 Here is a question -- I have not yet learned vibrato. However...I am working on a piece on my own this summer, with lots of whole notes (an easy adaptation within my ability!!). As I am practicing, I am finding these long notes without any colour or interest. However, I dont know how do vibrato yet. Any tips as to how to make these long notes interesting without vibrato?? Thanks! Pat Quote Link to comment Share on other sites More sharing options...
Andrew Victor Posted May 28, 2004 Report Share Posted May 28, 2004 You have to use your right hand to get the sound out and you must bow in such a way that the bow does not dampen the resonance. This means that the bow is not pushed down hard into the string. The strings vibration must be able to persist through the pressure of the bow hair that tends to dampen it. Experiment with long, light bow strokes. start with slow bows, then try faster bows. Carefully study the sound you get. Try changing the force of the bow into the strings (what is often called "pressure"). You can make big changes in sound this way, but you will never engage the range of overtone frequencies you could with vibrato. Andy Quote Link to comment Share on other sites More sharing options...
Austen Posted May 29, 2004 Report Share Posted May 29, 2004 Try Using trills. But chances are, if you dont vibrato, then you dont trill..... Quote Link to comment Share on other sites More sharing options...
D_A Posted May 29, 2004 Report Share Posted May 29, 2004 Quote: Try Using trills. Not good advice if it's classical music and the trills aren't called for in the score. Go with what Andy said. Quote Link to comment Share on other sites More sharing options...
Austen Posted May 29, 2004 Report Share Posted May 29, 2004 Who are you to tell him that my advice is bad? Just try it, and see what you some up with. Quote Link to comment Share on other sites More sharing options...
Patrewski Posted May 29, 2004 Author Report Share Posted May 29, 2004 Thanks guys. I will try all the suggestions as well as any more that are posted.!! Methinks I really need to learn vibrato soon. Quote Link to comment Share on other sites More sharing options...
Victor_Zak Posted May 30, 2004 Report Share Posted May 30, 2004 I agree -- it's time to learn vibrato. There are (at least) two reasons for vibrato: 1. To add emphasis to music, as an alternative to an accent in the right circumstances; and 2. As you realize, to warm up longer (and as you get better at it, even shorter) notes. I would suggest that, rather than try to warm up the notes in some other way, learn the real thing. Quote Link to comment Share on other sites More sharing options...
rufviol Posted May 30, 2004 Report Share Posted May 30, 2004 It's time to start learning vibrato. Typically you can spend a year learning and start to use vibrato the following year. Keep doing vibrato free scales though, so that an obsession with learning vibrato does not interfere with your intonation. You'll need to try several exercises to develop vibrato along with the close observation and instruction of a good teacher. Books also help, - Simon Fischer 'Basics' has exercises specifically for learning vibrato. Like practicing long bows on open strings with say a smooth, controlled half inch slides at the beginning, gradually reducing the amplitude of the slides to get your wrist familiar with the motion. Vibrato is a tough one but a major achievement/milestone in violin once it clicks for you - and it will with enough practice! Quote Link to comment Share on other sites More sharing options...
HoosierGirl Posted May 31, 2004 Report Share Posted May 31, 2004 Quote: Who are you to tell him that my advice is bad? D_A is one of the few full-time professional musicians on the board. Quote Link to comment Share on other sites More sharing options...
