Chel Posted September 21, 2002 Report Posted September 21, 2002 Hello there! I'd like to know the most effective way to mute my violin. To extend the practice time, I need to make the sound as quiet as possible. Which mute is most effective? Biggest rubber mute, metal mute, or other? What else can I try to further lower the sound? Close F holes, change rosin, etc.?? Buying a silent violin is not my option. Anybody, please give me the advice. Thank you! Chel
Kevin Miller Posted September 21, 2002 Report Posted September 21, 2002 I've had good luck with heavy metal mutes on both violin and tenor viol, but I've been told they can slip off and damage the instrument. The heavy rubber "practice mutes" are probably the best option. Ultra Practice Mute
ttk Posted September 21, 2002 Report Posted September 21, 2002 I agree with a heavy rubber mute and push it all the way down--too much liability with a metal mute..
dick l graham Posted September 21, 2002 Report Posted September 21, 2002 i dont play well so wife requires a strong mute. best so far is the heavy rubber i agree but this makes the sound so sweet and mellow to my ears that the violin sounds funny without it. you may never play without it!
nemesis Posted September 22, 2002 Report Posted September 22, 2002 I knew one student several years ago who always played with the small two hole tourte rubber mute. He claimed the violin sounded better with it. His tone was great and indeed when he played without it he produced a more strident tone. I wonder if anyone had a similar experience.
Soundboot Posted September 22, 2002 Report Posted September 22, 2002 I made myself a piece of felt that fitted over the top of the violin - covering the f-holes (in addition to a rubber mute). At one time I bound most of the body with soft material and got the violin virtually silent. In addition to your rubber mute you could put a couple of clothes pegs on the bridge. Nemesis. I quite often use a sliding mute as a kind of acoustic tone control. I find that if it is only slid near to the bridge I can take a bit of the top off without affecting the volume too much and I feel the tone is improved. Well worth experimenting with I'd say.
Kevin Miller Posted September 23, 2002 Report Posted September 23, 2002 Another option may be to make a practice violin. I recently saw a violin made by Rhythm Band. The neck (which had a ukelele-type peghead) had an extension that ran to the bottom end. The "body" was two pieces of Masonite screwed to this. The top piece was cut in the shape of a violin outline; the "back" was a teardrop shape that gave you enough of an area to attach a shoulder rest. The chinrest was screwed in place from the underside. The tailpiece was a piece of aluminum screwed directly to the top, and the bridge was just a piece of 1/4" Plexiglass with the right curvature on top. I doubt it would take more than a weekend to make one if you can get access to a bandsaw. Actually, I just noticed one for sale on eBay: Practice Violin
fubbi2 Posted September 23, 2002 Report Posted September 23, 2002 Another option is not to actually touch the instrument, but to close your eyes and think really really hard about playing it.
altogirl7 Posted September 23, 2002 Report Posted September 23, 2002 On my first fiddle, I played almost exclusively with a one-string tourte mute. Without the mute, the vio was too brash, and its sound towered over anyone else I played with. But I don't play professionally--far from it! altogirl
Minuet Posted September 24, 2002 Report Posted September 24, 2002 i use metal mutes (pretty heavy) yes they can slip off only if thy are not on properly and the violin is used upside down (lol) but otherwise theyre great. rubber mutes really suck just to tell you oh yes another way to really mute ur instrument alot is to Removr the soundpost! Hehe im sure u wouldnt wanna do that...
Steve_W Posted September 25, 2002 Report Posted September 25, 2002 Minuet, I have to say my experiences are quite different to yours and more in line with other posters. I have a heavy brass mute that I've pretty much stopped using because even when pressed solidly onto the bridge it has a tendency to work loose after a while and has fallen off the fiddle several times (and I was NOT holding it upside down), fortunately not doing any damage. It scared me enough that now I mostly use a big rubber practice mute which I find to be pretty good at cutting down the noise; better than a performance mute but not as effective as the brass mute, but a whole lot less nerve-wracking to use! -Steve
Kevin Miller Posted September 26, 2002 Report Posted September 26, 2002 I'll bet filling the instrument with some of that expanding foam insulation would also cut down the sound quite a bit!
